You are having a problem with the OSD lock on your ViewSonic E70f Monitor. Is that correct?
If so, please follow these instructions to unlock or lock your monitor.
On some display devices, there is an OSD Lock that locks all current control settings and prevents access to the control menus until this mode is unlocked.
The method for unlocking the OSD is different for different monitors, but will be one of the 2 below. If the first method doesn't work, try the second.
Method 1: Press and hold both the [1] button on the front of the monitor and the down arrow button for 10 seconds.
Method 2: Press and hold both the [1] button on the front of the monitor and the up arrow button for 10 seconds.
Note: These same buttons, when pressed for another 10 seconds, will lock the OSD
Please let us know if you require any further help with this matter.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt...
(More)
i cant install my monitor,its a view panel vg151, it only says ¨testing¨and doesnt get any signal
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no...
(More)
I have a view sonic vp2130b a square about 3'4 of an inch has started in the center. It stays no matter where I go, or on line. It does change colors to what ever I was doing last. Do you have any idea how to git rid of this? Thanks
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2...
(More)
my problam with view sonic monitir 17"inches crt ...every time it shows memory recall ok? hw 2 solve this problem pls help me....thank you
the problem with my view sonic moniter is that a popup appears very frequently saying RECALL MEMORY...
(More)
the problem with my view sonic moniter is that a popup appears very frequently saying RECALL MEMORY OK??
