Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch Classixx start problem
Hi got a machine about 4 years old. It will not start. The power is going through and the lights are on but instead of starting all we get is a constant quiet clicking noise. Hope you can advise. Cheers Rich
  • 909 Answers
Very possibly your wash motor is jambed. listen carefully when the water is in the unit for a hum. this is the motor trying to start.pull plug from socket then remove R.H.S cover to gain access to motor.at back of motor are cooling fins. if rotor is stuck, try and rotate untill free to turn.
Posted on Oct 08, 2007
SOURCE:
Bosch Classixx 1000rpm. Trips out RCD each time turned on. Am able to use other appliances in same power point. Only 3-4 years old
If the RCD is tripping then the appliance has an earth leakage fault. You should remove the plug from the power point and not use it until you get it repaired. This is a potentially dangerous fault, and the RCD is telling you it is faulty.
May 19, 2016 | Bosch Washing Machines
Bosch classixx 1200 express lights flashing
Bosch 1200 classixx express washing machine. Upon switching on my machine, a little while later all of the lights on the control panel were flashing except the Start button. I tried to push the buttons but there was not the usual sound made upon depression of any of the buttons. They continued to flash. I switched the power off and cleaned out the pipes at the front of the machine to eliminate any obvious problems. Please help
Dec 05, 2011 | Bosch Washing Machines
Bosch classixx 1200 express spin light flashing water wont drain pump is running water draining very slow i checked for blockage none found help... thanks
Sounds like the blockage is closer to the drum, Tilt the machine as far back as you can to access underneath. Make sure to have a basin and remove the pipe going from the drain pump to the tub and see if anything is obstructing the pipe or stuck in the tub, is usually a sock. Hope this helps.
Feb 28, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Hi could you possibly supply the operating instructions for a Bosch Classixx 1200 Express washing machine please,thanks.
Go to this web page:
http://www.bosch.com/content/language2/html/2394.htm
Enter all "required" information and they should send you a link to your manual via email. They are usually very good about manuals unless they are more than 8 years old.
Kelly
Aug 24, 2010 | Washing Machines
I have a Bosch washing machine /classixx 6 12 Express and the key sign is on and cannot programme wash
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently.
Pl rate me 'very helpful' for the free help, thanks
May 21, 2010 | Bosch Classixx WFL 2066 Front Load Washer
Got the Bosch Classixx 6 1400 Expresswashing
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks!
May 14, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Got the Bosch Classixx 6 Express 1400 washing machine cant
Feb 22, 2010 | Bosch Classixx WFO 2466 Front Load Washer
Bosch Classixx 1200 red wash light flashes but doesn't start
Could still be the water inlet valve. What you need to do is pull the washer out where you can get to the valve and the plug. Unplug the inlet valve and start the washer and when you start it as normal check the volts of the plug and see if its 110 if it is you know that the valve is getting power to open but not,replace the valve. If you dont get any voltage then it could be the relay or control board
Sep 02, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch classixx 1200 washing machine stalling mid-cycle
I`ve just spoken with Bosch Product Advice service about this problem. This could be happen when door is open after programme has been started. I didn`t check yet is working.
Thanks, roman
Mar 31, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch Fridge Freezer Freedom Classixx
Hi there seems that the power supply unit has a fault and will need replacing suggestion to call an engineer.
Thanks J
Jan 01, 2008 | Freezers
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
480 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
