Question about Linksys RE2000 Selectable Dual-Band Wireless Range Extender
02 My re2000 keep on blinking continously and never green up steadily even when i reset its configuration...and i can't get a steady signal from the router though it's near the location of my ea4500... Please help thanks!!
5 Suggested Answers
  • 67 Answers
SOURCE: Internet cutting on and off
If you haven't done a firmware upgrade I think doing so will be of a benefit to your problem! Just remember to backup your router settings beforehand! Hope this helps!
--Joshua79
Posted on Apr 05, 2009
kakee
  • 1269 Answers
SOURCE: Blinking power light - router not working properly
Blinking power light on the Linksys routers indicate 2 things. 1st is firmware problem, 2nd is the worst one which is defective router. You can still revive it if you can reload the firmware. If not, it's a dead one and you need to purchase a new one. And man, your router is a very old one. You must switch to wireless G router, its 5 times faster than your wireless B and it only cost 30 or 40 bucks
Posted on May 09, 2009
  • 73 Answers
SOURCE: I have a Linksys modem with a netgear wireless
the ds light is for downstream which is your digital signal simply put...... if the light is not going solid to denote being :"online" there maybe signal related issues. rain will mess up the cable signals as the service is exposed to elements etc.....here is a trick i do with a modem that doesnt want to lock on to good signal.....reboot the damn thing...........give it a minute or two.. if the online light doesnt sync up solid....unscrew the cable connector on the back of the modem while it is powered up and wait 15 seconds////then screw it back on (needs to be hand tight, its like a water hose, if its loose you get signal loss) and give it 10 minutes......if it still doesnt lock up and go solid indicating online then call your cable company, you should not get charged for their service not working correctly..........it then would be something only a tech could fix. but if it does lock up and go solid ....hook up your router , power it up and give it a minute to sense the modem, restart the computer and you should be good to go...
Posted on Jan 22, 2010
govinda123
  • 2263 Answers
SOURCE: setup ea4500 router
You can also install this router without using installation program.
Reset the router.
Connect the modem to the Internet port on the router. Connect one computer to the port 1 on the router. Open the router setup page using 192.168.1.1 and configure it manually.
Check this article about Linksys EA4500 router
Posted on Nov 25, 2014
TV powers on, picture blinks once, screen goes dark with green power light remaining on steadily
What is the brand name and model number to your TV? Provide more details, please. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Mar 25, 2014 | Televison & Video
Canon bjc 3010 waste ink error
just clean your cartridge..align it properly when you it back..surely it put properly.
Feb 08, 2014 | Canon BJC 3000 InkJet Printer
Power led not blinking when is switch on the router
Are you sure it's supposed to be blinking? I'd imagine it should be steady. It'll blink when first powering on, or when you reset it. Once done booting up, the led should just glow steadily.
Jun 02, 2013 | Cisco 1841 HWIC3GGSM 64MB FL 256MB D...
Power Problem with 2Wire 2701HG-B
Sounds like a startup self test. All wireless devices go through a power on self test. Does it connect? You can connect to it and go online? I rarely turn mine off, only in a electrical storm.
Nov 22, 2012 | 2wire (2701HG-B) Wireless Router
Sharp lc-32sb220u lcd tv. Green Power LED flashes steady
Okay, I found the problem. There is a problem with the
ccfl (lamp) groung PCB. Mine is completely burnt through. I am going to attempt to repair it, but will likely need to extract it from a different unit. This board is on the front right of the lx in the lamp housing behind the
lcd panel. What is happening: The inverter circuit on the power supply is detecting that one of the lamps is not lighting and it goes into shut down.
Hope this helps!
~Seth
Feb 07, 2012 | Sharp LC Televison & Video
Projector screen turns off after 10-20 seconds
Is the projector receiving a source signal? if not it will power itself down after whatever time you have it set to do so when no signal is present.
Just an idea?
Jan 03, 2010 | NEC NP-1000 Projector
No internet connection
the problem would be your antenna, thats the only way it sends the wireless signal. you shoudl be able to get a cheap replacement. try the following stores:
www.tigerdirect.com
www.radioshack.com
Jul 25, 2009 | D-Link AirPlus DI-524 Wireless Router
Turning off flashing light
Install this app nueLED and check off disable Signal LED...no more annoying blinking light...
http://www.1800pocketpc.com/2008/02/25/nueled-15-configure-leds-on-any-htc-device.html
Jun 30, 2009 | HTC PPC-6800 Smartphone
Comp won't start
maybe there is something wrong with your power supply.. i think you need to change it
Mar 01, 2008 | Computers & Internet
Linksys RE2000 Selectable Dual-Band Wireless Range Extender Logo
265 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
