Question about Refrigerators
Frigidaire refrigerator error code
E and F error codes
3 Suggested Answers
SOURCE: EF error code on frigidaire
My Frigidaire also got the dreaded E-F error code and stopped cooling. Technician over the phone told me to unplug it for 5 minutes and then plug it back in to see if the control board would reset itself. Did that with no luck. Unplugged the refrigerator last night while I tranferred my food to a spare fridge in the garage. Plugged the fridge back in this morning (9hrs later) and it works fine with no error codes. It looks like the control board has reset itself but how long it takes...I dont know. 10.. maybe 15 minutes? Well more than 5 at least. Guy over the phone told me that you can buy DRY ICE at a local grocery store and put it some in your freezer and a little bit in the frigdge to keep the food cold for a day. I had a spare fridge but I thought that was a good tip for anyone that needs to buy time for a tech to come repair the fridge. I had just bought $300 in groceries the night before so that tip would have come in handy if I did not have the spare fridge. I have no idea what the EF error was for but it's been 5 hours since I plugged my fridge back in and it's running fine so I'll cross my fingers. Got around to cleaning the fridge and plugging in a surge protector too. Hope this post helps someone out there.
Posted on Jan 17, 2009
imufo2
  • 3773 Answers
SOURCE: error code 4 on a
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 11, 2011
How to fix error code H1
Frigidaire Refrigerator Error Code = SY CE
Condition = Communications error at power up
Repair or Check = Check wiring between control board and user interface
Parts Needed = Control board or User interface
Frigidaire Refrigerator Error Code = 4
Condition = Fridge and the control board goes through cycles but does not detect a damper connection
Repair or Check = Check air damper
Parts Needed = Air damper
Frigidaire Refrigerator Error Code = 5Y EF
Condition = Evaporator fan circuit failure
Repair or Check = Check wiring between evaporator fan and control board
Parts Needed = Evaporator fan or control board
Frigidaire Refrigerator Error Code = EF
Frigidaire Refrigerator Error Code = dF
Condition = No defrost circuit
Repair or Check = Check wiring between defrost circuit and control board
Parts Needed = Main control board or Wiring harness
Frigidaire Refrigerator Error Code = H1
Condition = Freezer sensor shorted in freezer display
Repair or Check = Check wiring between thermistor and board. If correct, replace thermistor
Parts Needed = Thermistor (temp sensor)
Frigidaire Refrigerator Error Code = 5y CF
Condition = Communications failure at power up
Parts Needed = Control board or user interface
Sep 28, 2016 | Refrigerators
I need to find all the error codes for FGUS2642LF0 It's a frigidare refrigerator that keeps sending an error code & completely shutting down. The first time I looked up the error codes, I found that it...
Good Afternoon Michelle Klein, thank you for your post!
From my understanding you need a list of all the error codes inside of your Frigidaire refrigerator, FGUS2642LF0. I was unable to locate a list of error codes. If you could provide me with your model number I can look up to see what your error code stands for. You can locate the serial tag (which lists your model number) on the inside wall of your refrigerator. With that information I can further assist you. -Matt
Feb 23, 2015 | Frigidaire Refrigerators
I am getting a code of 1H on the refrigerator. Just trying to figure this out
Good Afternoon friend, thanks for your post!
I see you are having trouble with your Frigidaire refrigerator and you are receiving error code "1H". However, it appears "1H" is an invalid error code. I would suggest a reset of your appliance and you can do that by unplugging the power cord or flipping the household circuit breaker to the off position for roughly ten minutes. This usually clears false error codes.
If resetting the power does not correct the issue, could you please inform me of the new error code or if your refrigerator continues to display "1H". I look forward to assisting you. -Matt
Sep 29, 2014 | Frigidaire FFHS2622MQ Side By Side...
What does the error code 5y EF mean on my Frigidaire refrigerator
Good Morning Friend,
I understand you are receiving an "SY EF" code on your Frigidaire refrigerator, model# FRS3R5EMB. The "SY EF" code stands for system error with the evaporator fan. This possibly means that there is something going on with your evaporator fan or it could possibly be a false error code. . I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
-Best Regards-
WP
Jun 21, 2014 | Frigidaire FRS3R5EMB Side by Side...
LGHC2342LF2 ERROR CODES
I understand you are receiving error codes on your Frigidaire refrigerator, model# LGHC2342LF2. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power. You will hear a beeping, and will need to press the "Alert Reset" button to stop your refrigerator from beeping. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. If further troubleshooting is needed, I ask that you please let me know the error codes displayed on your appliance. Hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire Refrigerators
Www frigidaire com.
Hello Friend, thank you for your post!
Generally, error code 4 means that your Frigidaire refrigerator is experiencing an issue with the damper. The damper is either not opening or closing properly causing the fridge compartment to not cool. One of the best ways to determine if this is a false error code is to reset the power to your refrigerator by either unplugging it or flipping off the breaker for about 30 seconds. If the error code persists, the wiring between the damper and Main Control Board will need to be diagnosed by a professional. Depending on the results, either the damper or Main Control Board will need replacing.
Best regards! - Z
May 21, 2014 | Frigidaire Refrigerators
What is error code 1 on a Frigidaire FFHS 2622 MBE?
Good Afternoon Laura,
I see that you are inquiring as to what an error code 1 is on your Frigidaire refrigerator, model# FFHS2622MBE. Error code 1 could possibly have something to do with the software that controls your refrigerator. I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Restore power to your refrigerator, and if you are still receiving an error code 1, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what is going on with your refrigerator. Hope this helps.
-Best Regards-
WP
Apr 28, 2014 | Frigidaire FSC23F7DSB Stainless Steel Side...
Frigidaire SY CF issues
Good Morning Jack, thank you for your question!
Typically error code SY CF indicates that your refrigerator has detected a communication failure after power up. The error code may possibly continue after replacing the part you have ordered. With this error code, a professional would need to check wiring between the main control board and user interface board. After proper diagnoses and if the error continues, the main control board may need replacing. Hope this information helps to some degree!
Dec 27, 2013 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire error code 4
Error code 4 usually means that there is a communication failure with the main control board and damper. Base on the intensity of the issue; contact a professional technician to diagnose the unit to assist with the repair.
Sep 12, 2012 | Frigidaire Side By Side Refrigerator 26...
Frigidaire side by side error code 4
I have Fridaire refrigerator model PLHS67EGSB5 and have electronic control flashing code 4 at the right side (Refrigerator side) . What that means and how can solve it.
Thanks, Anibal
Oct 30, 2008 | Frigidaire FSC23F7DSB Stainless Steel Side...
Refrigerators Logo
292 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
