Question about Cell Phones
Kx tga361bx I have a display message of dont use this battery. With new batteries also the same message appears. Why?
4 Suggested Answers
  • 1702 Answers
SOURCE: WHAT BATTERY MUST I USE FOR PANASONIC MOFDEL
Hi Just take the old one to the store and you may be able to buy a better one. Good luck.
Posted on Sep 26, 2011
sabumt2030
SOURCE: Help me to unlock "Dial
I have Panasonic cordless model : KX-TGA361BX ...my kids dial lock the phone and forgot the password. please tell me how to unlock it
Posted on Sep 24, 2012
SOURCE: My kids set Dial Lock
hi.I have Panasonic cordless phone KX-TG361BX, I forgot its dial unlock password
Posted on Nov 02, 2012
How to replace the 601 battery
  • If Primary (internal) Battery (601) appears in the alert message, it means the measured storage capacity of the primary (internal) battery is less than 25% of the original storage capacity. The number "601" denotes the associated error code that is recorded in the system log.
To resolve a Battery Alert message, you should perform the Battery Test in the System Diagnostics (F2) environment, and calibrate the battery for best performance.
To access the HP System Diagnostics Battery Test , turn on the computer and immediately press the esc key to display the Startup Menu. Press the System Diagnostics F2 key, and then select the Battery Test option.
if it shows bad health You might need a new battery.
Aug 07, 2014 | HP Compaq Presario CQ57-229WM Notebook PC
Where is the Battery life indicator
When battery charge is low, an icon and message will appear. If the
batteries are charged, the icon and message will not display.
Dec 29, 2013 | Canon PowerShot SX20 IS Digital Camera
Gateway NV5378u lap top, brand new battery installed and status says 100% charged. When I unplug the computer it shuts off as if there is no battery. Could the new battery be defective?
There are a few things to check. The LED lights can tell you a lot. This will tell you more about the battery:
  1. On the taskbar, double-click the power cord icon or battery icon to open the Power Meter dialog box. Note: If the power cord icon or battery icon does not appear on the taskbar, click the show hidden icons button.
  2. Press Fn+STATUS to view the power status box, which opens in the upper-left corner of the screen. The power status box shows the current power source, the battery charge level, and the power management mode.
  3. Look at the battery charge indicator (if applicable).
    • LED green - Battery is fully charged.
    • LED orange - Battery is charging.
    • LED blinking red - Battery charge is very low.
    • LED solid red - Battery is malfunctioning. Note: This LED only lights up when the notebook is connected to AC power.
  4. Press the battery meter button on the battery. The battery meter lights indicate the percentage of battery charge remaining.
  5. Wait for a Low Battery warning message to appear.
If your battery charge indicator displays what looks like an inaccurate charge, you may need to recalibrate the battery.
To recalibrate the battery as mentioned, try this:
  1. Connect the AC adapter and then turn on the notebook.
  2. As soon as it starts and you see a startup screen, press the F2 key.
  3. In the BIOS Setup utility, use the TAB key to select the Advanced menu.
  4. On the Advanced menu, select Battery Auto Learning, and then press the SPACEBAR to select Enabled.
  5. Use the RIGHT ARROW key to select the Exit menu. On the Exit menu select Exit Saving Changes, and then press ENTER.
  6. At the Setup Confirmation prompt, select Yes, and then press ENTER.
  7. The battery recalibration process begins and a screen opens showing you the progress.
  8. When the recalibration has finished, and the message "Press [Esc] key to exit" appears, press Esc. The battery charge indicator now displays an accurate battery charge.
Hope this helps!!
Oct 20, 2013 | Computers & Internet
Battery warning
Just ran into this problem. New 3rd party battery with the badly translated message:
"Battery Life Time in current state is not longer.
Because you may lose your data during using, please replace to new battery.
(honest goods)
Tip> Battery Pack is Cunsumerable device.
This pack is not working correctly or life time is not longer,
please use to replace to new battery (honest goods)."
What I did was when the message pops up, hot ctrl-ald-del > start task manager > right click on it in applications and click "Go to Process" > right click on the .exe file and "open file location" > and just changed the name of the executable file by just putting a 1 on the end of the name. No more pop-ups
Who the hell uses Easy Display Manager anyway? Stupid program.
Jul 19, 2012 | Computers & Internet
Rebel XS ERR99
This is something I found when googling your problem.
Thank you for contacting Canon product support. I'm sorry to hear that
your EOS 10D is displaying an "ERR 99" message.
To isolate the cause of the issue, we suggest that you do the
following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
Does the "ERR 99" message appear? If it does, then the camera should
be serviced. If it does not, then please proceed to the next set of
steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the "ERR 99" message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the "ERR 99" message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the "ERR 99" with a different Canon lens attached, then the
camera should be serviced.
May 25, 2009 | Canon Cameras
Is there any such thing as charging my mps nextar MA933a via the USB port? I just get sleepy z's on the display when I connect it to my computer.
Here is what I found:
Connected the player to the PC with and without prior power on successfully
OSD first displays message “Starting…” then:
Icon appears on screen with a picture of a computer monitor to right and mp3 player icon to left
When mp3 player is communicating with computer or sending information, an appropriate directional arrow appears between the two icons; when transferring files using Windows Explorer, the arrow reverses direction appropriately; when there is no activity either way, a series of “Z z z” ‘s appear on screen
Battery indicator icon also appears to right – new AAA battery resulted in a fully charged icon upon startup; no battery whatsoever resulted also in a fully charged battery icon appearing
-Tha Mp3 Doctor
Feb 02, 2009 | Nextar MA933A MP3 Player
Invalid Battery Message
i dont know much about cell phones, but im gonna say that maybe you should try and get a new battery for it and see if that works
Jun 23, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
