Question about Kenmore 16879 Built-in Dishwasher
Dishwasher We have a Kenmore Dishwasher that is about 7 years old.. it will not drain anymore. We have pulled the dishwasher apart and cleared any debris we could see, we also checked the hose for blockages... any other suggestions? What can we do?
  • 641 Answers
Check that the pump spins freely.
Posted on Aug 30, 2007
We have a Kenmore Elite 630.16304401 dishwasher, lately we are getting small black greasy spots on the plastic dishes, also same spots on the plastic parts in the sump where you clean the filter? We h
A couple of thoughts:
1) It could be a gasket somewhere starting to break down. Check your door seal.
2) Food particles could have gotten caught somewhere in the drain hose, or something, and then turned black with mold and bacteria, then when you wash, they get siphoned back into the dishwasher if the flap which composes the anti-siphon check valve on the drain hose is starting to stick open.
Try putting a cup of bleach in the top rack and run a complete cycle with no other dishes in it. Then, load up some plastic dishes and wash them as normal. See if that helps. If it does, replace your check valve.
Also, insure that your drain hose is looped up above the bottom of your sink to prevent debris from your garbage disposal backing up into your dishwasher.
Good luck and keep us posted!
Oct 22, 2014 | Kenmore Dishwashers
Dishwasher will not drain, have cleared very little debris, have removed blade, what should i look for next?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 03, 2011 | Kenmore 15529 Built-in Dishwasher
My dishwasher won't drain after my grandson put cardboard box in dishwasher. I cleaned out all the scraps and it will run through a cycle (noisy) but won't drain after the wash cycle.
Hi, you will have to take apart the pump from inside and clear out the rest of the debris. This should solve the problem. If after taking the pump apart you are still having a problem then take the kick panel off and where the drain hose attaches to the washer this is a check valve. remove the drain pipe and unscrew the check valve. Clear the debris from the check valve and you will be all set. If you have any other questions please feel free to comment. Mike
Dec 20, 2009 | Whirlpool 24 in. DU915PWP Built-in...
Elite will not drain
If the water doesn't drain from your dishwasher, check these:
  1. Drain line/air gap--A clog in this part is the usual reason that a dishwasher doesn't drain. Remove the drain line to clear any debris from the hose or hose connection at the household drain line connection. Reattach the hose before starting the dishwasher again.
  2. Pump--You can reach the pump from inside the dishwasher. Remove the lower rack, spray arm and support. Look for an impeller, a device that spins around and forces water through the spray arm. This is the wash impeller and beneath it is the drain impeller that pushes the water into the drain port. Replace it if found defective or worn out.
  3. Drain valve/solenoid---The drain valve may have a solenoid with lever that sticks or frozen and prevents the dishwasher from draining. Free up the solenoid and lubricate the lever.
  4. Belt---A certain brand of dishwasher uses a belt to drive the pump. Replace it if broken or worn out.
  5. Motor---Check it if turning or working.Turn the rotor manually to see if stuck and free it up. Replace if defective, it is not serviceable.
Oct 08, 2009 | Kenmore HE2 Plus Front Load Washer
Kenmore Model 587.15103800 dishwasher won't drain
dip water out take pump apart remove debris look for broken blades if so install pump kit thumbs up
Aug 11, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
I have Kenmore dishwasher type 575-0 it is leaking
did you pull the bottom cover off and watch it run it could be either thesupply line developed a leak or the drain tube has done the same or in most cases with dishwashers relatively old the pump has cracked in which case the washer is trash
Apr 07, 2009 | Dishwashers
Kenmore dishwasher, water not going through the jets
when you hear the motor running during the wash cycle, check to see if the washer is actually draining instead of washing. this would indicate a stuck open drain valve. (the same motor/pump that washes the dishes, also drains the unit)
Feb 07, 2009 | Kenmore Dishwashers
Dishwasher not rince & when cycle ends not clear water remains
check the drain connection where it connect to the sink these are bad to clog. In your case it may be a partial clog also check for any kinks in the drain line.make sure your line go above the connection point and then back down .This will stop water from flowing from the sink.
You can take apart the pump usually torx screws and remove any debris. Do this last
Dec 12, 2008 | Frigidaire FDB658RA Built-in Dishwasher
Kenmore dishwasher
Mine eventually "fixed itself". I think some debris got caught and eventually (5 cycles or so) got ground up and sent through the drain. The noise changed each time it got closer "flushing out"
Apr 01, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore 16879 Built-in Dishwasher Logo
73 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
