Question about Vacuums
Saeco fata morgana SV7000
UNABLE TO START THE VACUUM MOTOR OR THE STEAM FROM THE PUSH-BUTTONS ON THE HANDLE.
informatica
  • 1114 Answers
SOURCE: Black & Decker SV1000-4 SteamBuster Vacuum
You can download the manual from the link below: http://www.dewaltservicenet.com/ServiceNet/Logon.asp You will need to register but it's free. As you know there's not much to the spray function but you should hear a pump running when you push the switch. You may need to clean the dirt bowl & filter for better results this is described in the manual. Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 13, 2007
ThinkVacuums
  • 144 Answers
SOURCE: canister vacuum keeps turning off, can push
its sounds like the problem is either the power head wire which when your using it and twisting it left and right, turns it off.. Or it could be in the hose where the connect meets with the unit.
Here's a number to call to further assist you. 1-800-322-2965
Posted on Aug 14, 2009
SOURCE: motorized brush bar not turning on Dyson Vacuum
Apparent common failure is that either the thin yellow and or blue motor drive wires that run from the LH side of the vacuum where the "control board" is located down into the hinge / ball area become stretched and then fray and eventually break. Happened to my Dyson twice. First repaired under warranty, second took about 20 minutes. You need a Torx screwdriver to remove the LH panel ( 4 screws) and also an access panel (2 screws) at the side of the ball which permits access to the blue / yellow wire connectors. I replaced with a new wire and connectors having fed the wires through the access hole making sure sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
Posted on Oct 04, 2009
SOURCE: Saeco 00095 Piccolo Canister Steam Vacuum
Where do I go to get tech.spec's on 00095 Piccolo and where to buy one online?
Posted on Nov 18, 2009
SOURCE: I have the Oreck Sanapathic DMS2000 Handheld Steam
ORECK DMS2000 No Steam
First, tested tank and filter flow together using suction via
plastic tubing. Worked freely Second, removed pump
and disconnected hoses and terminals [watch location,
three terminals on pump, two plugs]. Pump has a slug inside
and I could blow water either way. Sucked white vinegar
both ways until check action returned. Use distilled water
in future!
Posted on May 04, 2010
Where can I get the support for Saeco - VS 5000 FATA Morgana multifunction?
http://www.manualsdrive.com/results.php?lang=en&search=SAECO%20FATA%20MORGANA%20LV005&#.U7eWC_mFV8E
Jul 04, 2014 | Saeco Fata Morgana VS5000 Steam Vacuum
Install upper control rod
Hi, it's Jeremy from Crucial Vacuum.
To attach the upper handle to your Hoover Steam Vac remove the clean solution tank (upper tank) from the deep cleaner. Then, attach the upper handle to the lower handle by pushing the upper handle down onto lower one. Use the provided bolts to secure the handles. Push the bolts into the accompanying holes on the front of handle. If the bolts do not go through the holes easily, your handle is not pushed completely down. When the handle sections are completely together, squeeze the trigger on the upper handle to snap the trigger rod into place.
If you require further help with your assembly, you can find a step-by-step manual at: http://www.searspartsdirect.com/partsdirect/user-manuals/f5865900-hoover-parts-steam+vac-manual
You can also purchase all of your Hoover Steam Vac replacement parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=hoover+steam+vac
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 10, 2014 | Vacuums
I have a vs5000 and no instructions know where i can get it or a phone number for it
Dear Friend , Here is a number that you might want to try, I have the same machine : Saeco USA, Inc. 7905 Cochran Road, Glenwillow, Ohio 44139 Tel. 1-800-933-7876 ( from Continental US only ) , E-mail : support@saeco-usa.com, Website: www.saeco-usa.com. Best of luck to you :-) Sylvia ~
Nov 15, 2010 | Saeco Fata Morgana VS5000 Steam Vacuum
I have a Hoover steam vacuum carpet cleaner Model
the lever on the handle should be pressed when you want to apply solution to the carpet
Dec 29, 2009 | Vacuums
How does it work?What do you push to release the steam?
Push and pull the handle like your mopping...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Nov 08, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
When I push the button to release steam on the handle it feels soft and no steam is released. It has been going out for a while now.
I didn't fix the problem but I did take the handle apart. There is a little metal piston that is pushed down by the button on the outside of the handle. It was very sticky and stuck in the off mode. I freed it when I took it apart but obviously it just stuck again. I am going to take the handle apart and see if a little WD40 will make it easier to push. Either that or glue it in the "on" position. I really love this appliance and if I can't fix it, I'll probably just buy something similar.
Jun 29, 2009 | Steam Fast SF-275 Steam Max Canister...
Where can I buy a Saeco 00095 Piccolo Steam Cleaner?
Hi!You can buy from the following links---Product 4 Homes website--http://www.products4homes.com/eh2.php?cat=Household_Cleaning&subcat1=Vacuum_Cleaners_and_Upholstery_Cleaning&subcat2=Saeco_Steam_and_Vacuum_Cleaner&page=0ebay website--http://www.products4homes.com/eh2.php?cat=Household_Cleaning&subcat1=Vacuum_Cleaners_and_Upholstery_Cleaning&subcat2=Saeco_Steam_and_Vacuum_Cleaner&page=0Please do rate the solution as FixYa and using FixYa as well.ThanksRylee
Jun 11, 2009 | Saeco 00095 Piccolo Canister Steam Vacuum
I have a Saeco Armonia Espresso Machine. The water pump was running when the tank ran out of water and when I refilled the tank, it wouldn't start again. I unpugged it and turned everything off overnight....
Common on Armonia...
There is no water in the system, so the pump is pumping air!!
you have to push on the usual button but make sure the hot water button (for tea for ex) on the right side (same as steam opening valve) of the machine is open. This will allow the water to re-flow through the system. Once water is coming out again, close hose, and stop water button. Once hose is closed, and you repush the water button, it will flow again through the coffee hole.
Voila
Nov 30, 2008 | Saeco Vacuums
Aug 13, 2008 | Saeco 00095 Piccolo Canister Steam Vacuum
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
