Question about Crosley CDG6000 Gas Dryer
Crosley Dryer Won't Stop When Door Open
My Crosley CDG6000 dryer won't stop when I open the door. Would this be door switch problem?
  • 183 Answers
Yes, however befor replacing just check it is not jammed on be abiuld up of fluff around microswitch Regards Advisor
Posted on Aug 30, 2007
SOURCE:
Rgx4634kq2
make sure push start switch is not stuck pushed in.Also sounds like the switch mounted on the motor could be stuck, which means new motor. Does motor start and stop with timer being moved to the off position ?.If so then not the motor.
Jul 01, 2013 | Dryers
My Whirpool LGB6000KQ1 Dryer -- The drum won't stop turning when I open the door and the light doesn't come on either.....
You have a faulty door switch. Here is the replacement switch.
There is a video on that same parts page to show you how to replace it.
Feb 10, 2013 | Dryers
Dryer won't turn off
won't stop automatically? = timer problem
won't stop when you open the door? = door switch
Feb 08, 2013 | Maytag Atlantis MDG8400AW Gas Dryer
Won't stop, have to manually open door
Sounds like a bad timer. Your dryer is a Whirlpool product.so a replacement timer should be easy to locate. If the timer is advancing but the dryer won't stop, the problem could be the control unit. Run another load of clothes and take notice of the timer's position. If it doesn't run out, then it's very likely the timer. The video below shows step by step instructions for replacing the timer unit.
Mar 30, 2012 | Estate TEDS740JQ Electric Dryer
My Maytag Neptune electric Dryer will not stop unless it is unplugged or door is opened.
check the door switch,when you open the door the dryer shouls stop,push in on the door switch and let it out,it should click when it pops out,if the switch broke pushed in it won't shut off.the part number is W10169313 and it's around 16 dollars,
Jan 10, 2012 | Maytag Neptune MDE5500AY Electric Dryer
My Dryer won't stop drying until I open the door.
If it does this in a Timed Dry setting the timer is bad. If it does this in an Auto dry setting it could be a bad moisture sensor or a bad timer.
Aug 21, 2011 | Crosley Dryers
Dyer won't come on
check the door switch. with the door open push the lever for the door switch. do you hear a faint click? if not you've found your problem. is the lever even there? if not you've found your problem. if both are o.k. lift the top of the dryer. you should see the switch mounted inside the front panel. remove both wires from the switch & put them together. make sure the wire ends are not touching anything. put the top down, close the door & try to start it. did it start? if yes, replace the switch. let me know if this helps
Oct 29, 2007 | Crosley CDG6000 Gas Dryer
Crosley gas dryer
the pilot should be located in close proximety to the main burner. the ignition may be one of two devices - an electronic spark type ignition or what is called a hot rail glo-bar. the flame detector has a millivolt generator which generates a 750 millivolt current after it detects the pilot flame and gives a signal to the main valve to open.
Aug 20, 2007 | Crosley CDG6000 Gas Dryer
Pressing door switch makes dryer stop...why?
The door safety switch has come loose or become misaligned. A little study will reveal how the switch works, & most likely why it doesn't. There should be a obvious way to adjust the switch, or call an appliance tech to do it for you. Unplug the dryer before attempting to work on this switch, as high voltage may be present.
May 17, 2007 | Crosley CDE6000 Electric Dryer
Crosley CDG6000 Gas Dryer Logo
99 people viewed this question
Top Crosley Dryers Experts
Archie Ferrarini
Archie Ferrarini
Craig Butler
Craig Butler
jasbo
jasbo
Are you a Crosley Dryer Expert? Answer questions, earn points and help others
