Question about Garden
Hi i have a 6920s john deere on a potato harvester ,with a topper on front zuidberg23026459 pto.When switched on in cab pto light comes on but pto will not engage can you help me please
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
mickey813
  • 472 Answers
SOURCE: John Deere L120. Engine dies when PTO switch is pulled.
sounds like the seat switch is bad
Posted on Mar 02, 2010
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
John deere x495 tractor pto problem.
dami ko po pinag hirapan dito tapos mahahack lang pala Sana namn ma ibalik niyo plsssssssss mahawa na kayo sayng lang pera ko ito user:chageword12345 Pass:09464290212Angelica Inbox x
Jul 18, 2016 | John Deere Garden
John deere stx 30 pto wont engage
Check your fuse or for a broken wire( or shorted)
Jul 19, 2014 | John Deere Pto Clutch For Stx38 And Stx46...
Why wont john deere stx 30 pto wont engage
Most of these mowers have a safety switch between the PTO switch and clutch. A safety switch or relay is most likely the problem. Hope this will help ya.
Why does my John Deere 5425, Pto keeps shutting off?
Check all connectors going from switch to PTO engagement clutch. Check ground wire from PTO. This problem is either a bad connection or a faulty electromagnetic PTO.
May 12, 2014 | Garden
I have a john deere 420 that the pto will not engage. I do have power at the switch
You are going to need to Google John Deere 420 wiring diagram. There is a 30 amp fuse in the PTO power circuit. This provides the power to the Time Delay Control Module which has the solenoid in it. Any chance you can here the slonoid click? There, is a safety interlock switch on the seat. And everything goes to a common ground lug that may be corroded or loose. If the PTO light comes on but dim, then start with the ground. Quite a lot in this circuit.
Dec 14, 2013 | Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Garden Logo
12 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
