Question about Homedics SC540 LCD 400 lb180 kg Capacity Bath Scale with Body Composition
Manual how to read the scale?
Just replaced batteries in the scale. The picture shows what the scale reads. It will not shut off or do anything except give this constant reading. How do I fix this?
Remove the batteries, count to 10 and reinsert. It is possible that when you put in new batteries, you have to set up the scale.
google
make model manual
Jul 12, 2016 | Health & Beauty
My scales show 3.5 kg lighter than actual reading. What can I do?
check at the back of the scales for an adjustment screw or knob
to make the adjustment you will need items of known fixed mass over say 2 lb to 40 lb
you can do this by accurately measuring 1/2 gallon , 1 gallon 2 gallon 4ga;;ons of water as it is 10 lb to the gallon
there may be a pdf version download on the net if you go google and type in--- user manual for (make and model ) scales
May 05, 2016 | Health & Beauty
MY SCALE READ 202 AND THEN STEPPED ON IT AGAIN AND IT READS 333 LBS AND NOW STAYS THAT WAY WHEN I STEP ON IT AND HOW DO I FIX THE PROBLEM.
you most probably need to reset scale to factory settings, as you did not give what model and manufacturer, therefore you need to find your manual or google on line howto reset your scale
do not forget to vote...
Dec 31, 2014 | Health & Beauty
How do you calibrate, it's a body fat scale, can't find model #?
It's important to find the model number to be able to find the correct manual. Below is a link to FAQ's about Taylor body fat scales.
If you do a google search for "taylor body fat scale" you will see a list of a few models. Examine each to see if one of them is the same as yours.
Taylor USA FAQs Scales
Searches related to Taylor body fat scale model number location
taylor body fat scale model 5741 manual
taylor body fat scale model 5761bf
taylor body fat scale model 5731f reviews
taylor body fat scale accuracy
taylor body fat scale 5731 review
taylor body fat scale athlete mode
taylor body fat scale readings
taylor body fat scale5758f manual
Aug 01, 2014 | Taylor Health & Beauty
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
What does de-scale mean?
To de-scale anything in relation to water means to remove the mineral scale buildup on the walls or where ever. That's the usually white chalky stuff that you might see around nozzles etc. Follow yu manuals instructions to de-scale. Usually involving white vinegar, or possibly a product like CLR for removing minerals and rust stains. I AM NOT SAYING TO USE CLR IN YOUR MACHINE, just indicating an example of a product that manages mineral scale. Read the manual to do it correctly.
Nov 26, 2010 | Keurig B100 Coffee Maker
Lost the manual how do i read the scale
After doing an online search and coming up with nothing, I search my files for my manual. I have uploaded into photobucket. See this link:
http://s1125.photobucket.com/albums/l587/landofnarnia/Taylor%205568%20Scale/
Nov 14, 2010 | Taylor 5568 Fat Scale Stainless Steel ()
How can change the lb to kg scale
how do I get the scales to read in pounds?
Dec 07, 2008 | Omron HBF-400 Fat Loss Monitor with Scale
Weight watcher scale not calibrating weight correctly
Press the scale once with your foot. All screen options should display to initialize and then go to 0.0. Now step on the scale. It should read out your correct weight. If not, first remove and replace the battery for reset. If still not, replace the battery. If still not it's ready for return or replacement. Hope it works! Dave - CA
Aug 12, 2008 | Irons
Homedics SC540 LCD 400 lb180 kg Capacity Bath Scale with Body Composition Logo
48 people viewed this question
Top Homedics Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
