Question about Watches
Tissot t770 Setting second hand to 12 position
SOURCE: Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Posted on Feb 22, 2008
SOURCE: Ta Heuer Professional stopwatch minute hand reser to 12 position
pull the crown on first click and push the upper button until it reaches to your desired position.
Posted on Mar 20, 2008
escapement
  • 2334 Answers
SOURCE: The second hand on my luminox 8150 does not reset to 12 o'clock
Pull out crown to the first click. Push and hold pushbutton at 2 o'clock till the seconds hand reaches desired position. Push the crown back. You may need to operate pushbutton at 4 o'clock instead of pushbuttton at 2. Try both.
Rate me, please.
Posted on Mar 23, 2009
SOURCE: The second hand of my Tissot watch T870/970 starts and stops.
Hello!
Absolutely astonished by this "solution" from escapement.
This watch is working perfectly - it is simply giving its "end of battery life warning".
Posted on Dec 11, 2009
SOURCE: my Tissot Watches second hand jumps 3-4 seconds bursts.Why?
The second hand jumping three or four seconds .I have had this same problem and found out that its i sign of wanting a new battery.Mine is now perfect
Posted on Feb 26, 2010
Tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 | Watches
Set date on omega seamaster quartz 1425
When you pull the crown (winder) , you will notice it has two positions (two clicks). The first click is for quick date setting, the second click is for time setting (moving hands). Second click can be use for date setting as well, but for this you need to move watch hands forward for 24 hours to pass 12 o'clock.
Feb 25, 2011 | Omega Seamaster 300M wristwatch
I need the manual of breil milano shosholoza.the model is bw0480
The crown has 3 positions.
Normal screwed down.
First pull out position.
Second pull out position.
Setting the Time:
Pull out the crown to position 3.
Rotate the crown to set the exact time.
Ensure that you are in the daytime12 hour segment by allowing the hands to pass 12 o'clock and notice if the date moved on or not.
If the date changed, then you will need to advance at least 2 hours before moving on to set the date.
If you do not need to change the date, return the crown to position 1.
Setting the Date:
DO NOT DO THIS IF THE WATCH IS BETWEEN 8pm & 2am
Pull crown to position 2.
Rotate the crown clockwise to set to the correct date.
Return the crown to position 1.
Setting the Alarm [12 hour]
Pull the crown to position 2.
Rotate the crown anti clockwise to move the alarm hand to the desired time.
To activate the alarm, press the 8 o'clock button. You will hear 2 beeps.
To deactivate the alarm, press the 8 o'clock button. You will hear 1 beep.
NB If the alarm is not cancelled while it sounds the first time, it will repeat again in 2 minutes time. The alarm sound last for 15 seconds. If the alarm time coincides with 1 beep of the countdown, the alarm function will be cancelled.
Battery EOL [End Of Life]
The Swiss ISA 8270 movement uses a 395 cell and will signify a low power state by advancing the small seconds hand 4 steps every 4 seconds.
Setting the Countdown
You can specify a countdown of between 1 and 10 minutes.
Press the 4 o'clock button to enter setting mode. You will hear 1 beep.
Press the 4 o'clock button to move the central timing hand successively to the desired countdown time.
Wait 3 seconds for the watch to automatically exit the setting mode.
You can change the duration of the countdown [except in the last minute] at any time.
e.g. If the countdown is set to 10minutes, and you now want to change the countdown to 9 minutes, press the 4 o'clock button. The hours/seconds counter sub-dial will perform one complete turn and then stop at 60, before continuing.
Activating the Countdown:
Press the 2 o'clock button to start the countdown. You will hear 2 beeps.
When the countdown begins, the hour/seconds counter sub-dial indicates the seconds with 1 step every 2 seconds, and the central timing hand indicates the minutes with 1 step being 2.4 seconds.
Countdown tone:
There are 2 beeps every minute.
in the last minute:
50 seconds=1 beep.
40 seconds=1 beep.
30 seconds=2 beeps.
20 seconds=2 beeps.
10 seconds and less=1 beep every second with zero being 1 second long beep. Timer function automatically starts.
Timer:
After countdown has finished the timer starts automatically.
The central timing hand indicates the minutes with 1 step every 12 seconds. The hour/minutes counter sub-dial indicates the hours up to a maximum of 96.
Press the 4 o'clock button to see the timer seconds [display lasts up to a minute].
Press the 4 o'clock button to see the timer hours.
The timer has a maximum time of 96 hours [4 days] after which the hour/seconds sub-dial counter will stay at 0 and the central timing hand will stay at 12.
Start/Stop Timer:
Press the 2 o'clock button to stop the timer. You will hear 1 beep.
Press the 2 o'clock button to resume the timer. You will hear 2 beeps.
Setting the Countdown & Timer:
Countdown reset:
Press the 2 o'clock button to stop the countdown. You will hear 1 beep.
Press the 4 o'clock button to reset.
Setting the Timer:
Press the 2 o'clock button to stop the timer. The hour/seconds counter sub-dial will show the elapsed hours and the central timing hand the elapsed minutes.
Press the 4 o'clock button to view the seconds elapsed on the hour/seconds counter sub-dial.
Resetting the Hands:
If the hands do not zero correctly, which might occur after a battery change or a violent shock, you can make adjustments by doing the following settings as long as the countdown is not in operation.
To correct the hour/seconds counter sub-dial, pull the crown out to position 2 and wait 1 second.
Press either the 2 or 4 o'clock button; the central timing hand will turn and stop [not necessarily at 12].
Press the 2 o'clock button to increment the hours/seconds counter sub-dial hand to position it at 60.
To correct the central timing hand, press the 4 o'clock button to increment the hand to the 12 position.
If the battery had been replaced, the central timing hand defaults to the 10 minute position. If the battery had not been replaced, the central timing hand will return to the previously set position.
Oct 05, 2010 | Watches
Changing the hand time only w/o changing the digital time
For Casio Waveceptor:
--- A
( ) Button Reference
--- B
Set in correct order:
1) Hand Home Position
2) Digital Time Set
1) Hand Home Position:
Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
Press B to exit Hand Home Position mode and enter Timekeeping Mode.
2) Digital Time Set: (hands will self set when done)
Press and hold B for 5 seconds to enter setting mode.
Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
<Order of Items to Set>
GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
<Setting each Item>
GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
For each item, Press A to advance, and B to set.
Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
Good luck,
Techjoel
May 10, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Need instructions on National Geographic Men's watch #NG010GYSK
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Feb 13, 2009 | Bulova Watch
How do you set and deactivate the alarm function.
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Jan 05, 2009 | Bulova Watch
Tag Heuer Aquaracer reset red hand
THANK YOU THANK YOU THANK YOU!!! I had a similar issue and this saved me!!!!
Apr 14, 2008 | Tag Heuer Aquaracer Quartz Chronograph...
Mar 16, 2008 | Watches
Instructions for casio wave ceptor 4303
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
http://world.casio.com/wat/download/en/manual/
You will need a pdf reader on your pc, you will find all instructions in there.
If you don't have a pdf reader you can get one from
http://www.foxitsoftware.com/pdf/rd_intro.php
Nov 06, 2007 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
