Question about Belling Ovens
Oven turn off auto - Belling Ovens
How do I turn off Auto on oven
Hi Anita,
A quick search of Google for an answer to my question "Turning Auto Off on a Fisher and Paykel Oven"
With little more detail from you like model and if AUTO Off as with Timer I could pin point it, i..e.be more accurate.
So if my guess is correct than it should be on the Analogue/Analog Timer Knob OR if electronic somewhere on the keypad, electronic touchscreen? pad....meaning set it to MANUAL....have you tried that?
Cheers
Nov 02, 2014 | Fisher and Paykel Ovens
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven thermostat is faulty. needs replacing.
Feb 17, 2012 | Ovens
Omega OA 25 oven auto turn off?
Is there a way to change from "Fan Forced Oven" to normal conventional heating oven in an Omega OA25 model?
Jan 14, 2012 | Ovens
We had a power cut, now I can't get the oven to work the auto light is flashing but when I turn the knob for the oven it won't come on.
You need to reset the oven from auto to manual setting.
This is done by pressing 2 or more buttons on the timer at the same time to reset it, until you do this, the oven will not work
Feb 17, 2011 | Tecnik TKC8085 Electric Double Oven
Display is flashing0.00 and auto. oven won't work
Try turning the oven circuit breaker off for a minute then back on. Reset the clock and see what happens.
Nov 22, 2009 | Fisher and Paykel AeroTech - OS302M...
Electric oven will not switch on. No heat, no fan. There is a timer display that is counting up and has the word AUTO showing. The gas hob works normally. How can I turn the cooker on?
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Aug 22, 2009 | Tecnik Ovens
Oven won't work after cleaning
Molly,
"Auto Clean" means that the control thinks the door is locked. If you can open the door, it's obviously not locked. You can try turning the power off at the breaker. Leave it off for 20 minutes or so. See if this resets the control. If not, the high temps in "auto clean" may have fried one of the monitor switches on the door latch.
Let us know what happens.
SG
Mar 26, 2009 | GE Ovens
Oven wont turn on due to auto mode.Cannot cancel auto mode.
If you have followed instructions properly, and cannot get it off auto. then you will need a new timer, alternatively, the timer can be bypassed
Dec 07, 2008 | Ovens
Auto Timer
hi there switch your oven off at the mains switch for one minute thenswitch back on and set the time this will disable the auto on the timer.
Dec 09, 2007 | Neff U1661 Double circotherm super...
Ovens Logo
11 people viewed this question
Top Belling Ovens Experts
ashburton
Lawrence Oravetz
Are you a Belling Oven Expert? Answer questions, earn points and help others
