Question about Dishwashers
My lamona dishwasher lam8601 has stopped working I switched it on and all the lights just flash on once then that is it you can't push any other buttons as they won't function
2 Suggested Answers
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
My Lamona dishwasher HJA 8650 lower spray arm wont rotate, water is spyaying out and nothing in place to stop it rotating, can you help?
Sounds like the pump that pushes the water up to the spray arm is going south on you.
Check to see if the pump or any of the piping, or sprayer arm jets are clogged.
Feb 23, 2017 | Dishwashers
How do I replace a faulty on/0ff button on a lamona integrated dishwasher
Dishwasher Push Button Switch Replacement - Bosch ...
? 1:56
https://www.youtube.com/watch?v=MSO3nXetiOM
Oct 8, 2012 - Uploaded by RepairClinic.com
This video provides step-by-step repair instructions for replacingthe push button switch (or on/off switch ...
Oct 26, 2015 | Dishwashers
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 | Dishwashers
My Frigidaire Dishwasher FDB1050RES2 gets stuck in a rinse cycle. The light on the front will be lit "clean" but the bottom of the washer is full of water. Opening the door does not turn off...
by the descrition you are giving you will need to replace the main control board.Part number 154568401.you may also need to check the float switch.The part will run about 110.00 dollars from a local parts store
Dec 29, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
My Lamona single fan oven. The problem is it always flashes to 'auto PO:OO' so the oven does not go on unless it stops flashing and then sets it self for two minutes, sometimes it stays on the flash mode...
can someone please tell me what is wrong with my Lamona single oven it will not turn off. you have to switch it off by useing the switch on the wall if you can help please email me
sarahnichols206@hotmail.com
Oct 17, 2010 | Microwave Ovens
All the lights on my dishwasher are flashing
I had this problem twice on my machine.Once about a year ago and again recently.
I found the problem was a switch which is located in the door.
It is activated by the steam in the vent.
The first time it happened i took the panel off and by sticking my finger in the vent ,was able to re-set the switch.
About a year later the lights started to flash again,but pushing the switch did no good.
It turned out to be a loose wire on the same switch.
Hope this helps someone.
Jul 29, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Clean light flashing
Sorry you are having trouble, I put together a quick check list and instructions on how to reset the control. Let me know if this works for you, if not I can dig a bit deeper to help.
http://www.fixya.com/support/r4628906-flashing_or_blinking_green_clean_light_7
Apr 25, 2010 | Kenmore 24 in. 16293 Built-in Dishwasher
Lamona dishwasher from Howdens. E1 code
we have a howdens dishwasher model number hja8630, which is full of water which hasnt drained . i have ladled it out checked filters are unblocked but it still fails to start. it does a click click sound and then nothing . only 18 months old and only ever used twice a week
Feb 21, 2010 | Dishwashers
Maytag dishwasher, no power, then flashing lights, now no power.
Had the same problem, removed the kick panel to find a set of instructions under the insulation, had to push a sequence of the panel buttons, its been running great for a couple of weeks now!
Jeff
Dec 23, 2008 | Maytag MDB7100AWB Dishwasher
Dec 29, 2007 | Dishwashers
Dishwashers Logo
528 people viewed this question
Top Dishwashers Experts
Owen Barnes
