Question about SanDisk Sansa e250 MP3 Player
Will not start
After pressing the menu button I get the initializing message appearing briefly, then reverts to sansa screen and does not do anything else. Anyone have an answer
Try unlocking it
Posted on Aug 31, 2007
SOURCE:
Nabi jr has a green android laying on it's back with red exclamation make, want do anything. How do I fix it?
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the red Motorola logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up).
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons.
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections.
6. Use the volume buttons to move up and down through selection in this menu.
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option.
9. Scroll down to select "Yes, delete all user data".
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet
Oct 27, 2014 | Tablets & eReaders
Scan says all channels locked out
Please try this,
If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box.To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
Hope that helps!!
Happy Scanning
Nov 22, 2012 | Radio Shack Pro-97 Handheld Scanner
Reset scanner
Please try this:
Hope that helps.
Happy Scanning!!
Oct 24, 2012 | Radio Shack Pro-97 Handheld Scanner
My HP Photosmart C6280 asks me to replace the light blue ink cartridge and says it is unable to print until we replace the ink cartridge. We have replaced it three times and the same message appears. The...
Follow the below steps on the front panel of the All-in-One printer:
A. - Press and Hold the "Print Photos" & "Red Eye Removal" buttons. Release both buttons.
Display should say "Enter Special Key Combo"
B. - Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
(try both and see which one will get you to system config menu )
display says "enter special key combo"
1. Press and release in sequence "Red Eye Removal", "Print Photos", "Red Eye Removal"
2. Press and release the right arrow button until the display says "System Configuration
Menu".
3. Press and release the "OK" button.
4. Display should say "Hardware failure status". If not there already, Arrow Key over to
5. Press and release the "OK" button
6. Display should say "Hardware failure status: Clear. Press OK to clear".
7. Press and release the "OK" Button. Message changes to "Hardware failure status Cleared.
Press Cancel to continue".
8. Press and release the "CANCEL" button as many times as necessary, so that, either the
"Welcome to Photosmart Express" screen appears, or, the "Ink System Failure" screen appears.
PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the
printer and wall outlet.
it is now powered down and unplugged.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the
wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message "USE POWER BUTTON TO SHUTDOWN THE PRINTER" followed by "PRESS OK TO CONTINUE". Press OK.
12. If the printer has already initialized, then go to the next step. If not, the printer
will start the "ONE TIME INK INITIALIZATION PROCESS". Allow this process to complete and do
not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
13. To verify printer functionality print a SELF TEST PAGE.
Aug 31, 2011 | HP Photosmart C6280 Printer
My env3 takes about 8 to 10 seconds to load the messages menu, and load anything in that menu (such as starting a new text or opening texts). anything to help it?
Please try resetting the phone but this will reset the phone to factory default.
Steps to Reset Settings
This resets the phone to factory default settings.
  1. Open the flip and press OK [Menu].
  2. Press 9 or Settings & Tools.
  3. Press 6 or Phone Settings.
  4. Press 7 or Security.
  5. Enter lock code. The default lock code is the last 4 digits of your phone number.
  6. Press 5 or Reset Default.
  7. Press OK after reading the warning message.
  8. Press OK to select Revert. A confirmation message is displayed briefly before the phone resets itself.
http://www.resetcellphone.com/solution/LG/vx9200-env3
Feb 22, 2011 | LG enV3 VX9200 Cell Phone
How to re format with sandisk firmware?
  • FOLLOW THE STEPS OF INSTRUCTION GIVING BELOW IT WILL SURELY HELp
  • INSTRUCTIONS
  • 1Press the "Home/Menu" button to return the Sansa Fuze to the main menu.
  • 2
    Highlight "Settings" and press the "Select" button to bring up a list of adjustable settings on the Fuze.
  • 3
    Choose "System Settings" and "Format." A confirmation message will appear on the screen.
  • 4
    Select "Yes" to format the Fuze. It will take several seconds to several minutes before the player is reformatted.
    Sansa Clip
  • 1
    Push the "Home" button to return to the Clip's main menu.
  • 2
    Choose "Settings" by highlighting it and pressing the "Select" button.
  • 3
    Select "System Settings" and then "Format." A prompt will appear on the screen asking you to confirm the formatting.
  • 4
    Highlight "Yes" and press the "Select" button to confirm reformatting the player.
  • Oct 02, 2010 | SanDisk Sansa MP3 Player
    DM-10 reverted to japanese
    To reset the settings back to English:
    1. Set the DM-10 to Voice mode using the blue switch on the back voice recorder.
    2. Remove the DM-10 from Hold using the gray switch on the back of the voice recorder.
    3. Press and hold the DISPLAY/MENU button on the front of the DM-10 for at least 3 seconds. The menu list is displayed.
    4. Click the REWIND button six times to highlight the Format menu item.
    5. Click the PLAY button to select the Format menu item. A message will be displayed with Cancel and Start options.
    6. Click the REWIND button once to highlight Start.
    7. Click the PLAY to select Start. A message stating that the data will be cleared will display briefly. Then a message asking if you are sure will be displayed.
    8. Click the REWIND button once to highlight the Start menu item to continue with the format.
    9. Click the PLAY select the Start menu item and begin the format. The format progress bar will appear. When it is complete the menu items will be in the English language.
    Jan 09, 2009 | Olympus DM-10 Handheld Digital Voice...
    Clearing message after "replace photoconductor kit" message came on
    To reset the photoconductor page count:
    1. Turn off the printer.
    2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
    3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
    4. Release the buttons when you see either of these messages.
    5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
    6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
    7. When the display shows CONFIG MENU again, power off the printer.
    8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
      The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
      1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
      2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
      3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
      4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
      5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
      6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
      7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
      8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
      9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
      10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
    Jul 28, 2008 | Lexmark E342n Laser Printer
    "ALL CHANNELS LOCKED OUT' RADIO SHACK COULDN'T HELP.
    If the scanner's display locks up or does not work properly after you connect a power source, you might need to reset or initialize it. If you have problems with the scanner, first try to reset it to retain the memory. Warning: Initializing the scanner will clear all channel memories and reverts it the state it was in right out of the box. To Initialize the scanner, turn off the scanner then turn it back on. Press 0 when the welcome screen appears. 'Please select factory tests. Exit if no key is pressed' will briefly appear. Then quickly press 1. 'Initialization clear all memory Enter to confirm Clear to exit' will briefly appear. Quickly press ENT to initialize. 'Initializing, Please stand by' then appears. Do not turn off the scanner while it is initializing. The display should then show M000 on the top line and Bank 0 CH 00 when finished.
    Feb 28, 2008 | Radio Shack Pro-97 Handheld Scanner
    Sandisk Sansa e260
    u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
    Apr 03, 2007 | SanDisk Sansa e260 MP3 Player
    SanDisk Sansa e250 MP3 Player Logo
    Top SanDisk Audio Players & Recorders Experts
    Joe Negus
    Joe Negus
    Ekse
     Ben
    Ben
    Level 1 Expert
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
