Question about Sewing Machines
Brotherportable free arm machine JS1400 - Sewing Machines
How do I remove the free arm plate from my Bernina 830
Not sure I understand your question. Is that the old Bernina 830 Record? Removing the extension table will reveal the free arm. On the other hand, if you want to open the free arm to clean and oil, look inside the bobbin department and there is a little metal tab on the left top side that, when pushed, will release the cover.
BERNINA Sewing Systems
For the newer computerized 830, here's the manual:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&cad=rja&uact=8&ved=0ahUKEwjB0Z7Xyb_YAhVM8WMKHeXSB8MQFghIMAI&url=https%3A%2F%2Fwww.bernina.com%2FBERNINA%2Fmedia%2FSupport%2FSewing_Quilting_Embroidery%2F8_Serie%2FBERNINA_830%2FDocuments%2FEN%2F032299-53-04_1204_B830_EN_online.pdf&usg=AOvVaw3AHGuyLUld3qgcmW-8Fr-Q
Jan 04, 2018 | Bernina Sewing Machines
My featherweight 221 white machine seems to be running slow
Lubricate the motor and the gearbox on the underside . Unplug and cycle the sewing arm manually spreading the lubricant feel for the sewing arm to release from being hard to operate. Put it all back together. Plug the unit in and practice sewing arm movement on a piece of scrap material. Run it forwards and backwards if adequately lubricated it should free up of the excess traction on arm movement.
Nov 09, 2017 | Sewing Machines
How to get the free arm on a elna 9006 envisions
If you are looking for the Free arm storage that fits a Elna 9006 Envision, you can start by calling a Elna dealer near you for the storage box that fills in the front of the machine.
Cheers,
Embroidery Services
San Diego, CA
Jun 19, 2016 | Elna Sewing Machines
Will A 5530 free arm table fit my 534 Singer?
I would guess, probably not. (Unable to find any info on the 5530 table.) Wouldn't recommend buying it unless you can actually try it on your machine, the seller will guarantee that it will fit your machine, or the seller can provide complete free-arm insert measurements of the extension table and match them to your machine's free-arm measurement. Best bet would to get a guarantee to return for credit if it does not fit.
Singer machine models for Sewing Mates Tables Every Singer model will fit
Extension Tables SewingMachinesPlus com
Mar 11, 2016 | Sewing Machines
Yahoo group
Is your machine an Air Electronic SU? these were numbered 68 and 69, one was the standard base, the other a duplex base designed to go into a cabinet. The duplex base ones have a dished shape lower plate and the machine can be pivoted up out of the base to use as free arm, or lowered back down to use flush. The standard model has a flat base with four rubber feet.
So if your machine is a standard base Elna then you need to set it on a lowered platform so the top of the free arm is level with the top of your cabinet surface. You may have to rig up something suitable to achieve this different level rather than mounting the machine itself.
Horn sewing cabinets allow you to do this, you set the hydraulic lift platform to the right level so the top of the arm is level with the top of the cabinet, then they sold a persplex piece that would fit around the machine filling in the area between the free arm and the outside of the platform area giving you a flush platform.
Oct 24, 2013 | Elna Sewing Machines
Where is the button to activated the feed dogs
Convert your machine to free arm, and look on the back of the arm.
Oct 05, 2012 | Singer Quantum 7350 Mechanical Sewing...
Can the feed dogs be lowered on serial number 6510
Yes, take off the table (that makes it a free arm). Look at the back..on the under side of machine underneath the arm...there is a latch that when pushed to the left will drop the feed dogs.
Jan 23, 2011 | Singer 6510 Sewing Machine
''how do i remove the sewing bed part to use free arm'' brother ls2020 machine
If you pull from the end and lift up at the same time, it should disengage the top bed for free arm sewing.
Apr 26, 2009 | Brother Sewing Machines
Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Dec 31, 2007 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
15 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
