Question about Honeywell PRO 3000 Non-Programmable Thermostat
Honeywell pro 3000 battery died changed battery wont turn unit back on
2 Suggested Answers
  • 13 Answers
SOURCE: batteries died on my honeywell RTH230B replaced but furnace won't
you will have to reprogram it according to the operating manual.
The manual is available on www.manualnguide.com
Posted on Feb 02, 2010
I have a honeywell focus pro 6000 temp in house doesnt change unit runs constatly. thermostat says 78 thermomiter on other end of house says 72. changed batteries
It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Apr 30, 2017 | Honeywell Heating & Cooling
I took my Honeywell focuspro 5000 non programmable thermostat off the wall to change the batteries and I put new batteries in it and back on the wall and now my air conditioner wont come on do you kno
I can only suggest that you check and make sure all of the pins are straight and not bent over from trying to align the back plate with the back of the thermostat. Ive done it and its easy to do if you are not very carefull.
Sep 19, 2014 | Honeywell TH5110D1006 Focus PRO 5000...
Honeywell visionpro
Um...., you changed the controller and it worked, then put the old one back and it doesn't work >> replace controller!
Oct 16, 2013 | Honeywell Electronic Programmable...
How to setup honeywell th3210d1004
you need to change the differential pressure to 3 degrees.that means the unit will not kick on unit it is 3 degrees warmer then the setpoint
Mar 06, 2013 | Honeywell TH3210D1004 PRO 3000...
I am replacing a kenmore 3000 humidifier with a Honeywell HE360A. Can I use the same electrical wires for the hoenywell that are allready there from the kenmore?
How did your replacment turn out? I also have a 3000 and am looking for a replacment unit where I do not have to make a lot of changes.
Dec 11, 2010 | Honeywell HE360A1027 Whole House...
I have an old (14 years) honeywell thermostat, that showed 1bat lo message on the screen. I replaced the batteries, but it still shows the same message and I cannot adjust the temp. I recall earlier...
I subjest the honeywell pro 3000 is a very good stat it comes in programable and non programable their is also a pro 8000 that is great its touch screen and has many options but the 3000 is most cost effective
Sep 14, 2010 | Honeywell Programmable Thermostat Heater
Batteries died on my honeywell RTH230B replaced but furnace won't
Feb 02, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell control unit that has a corrosion problem in the aa battery compartment, When I change the batteries every 12 months I notice it is getting worse. I put a new set of batteries in and the...
Your problem is bad connections due to corrosion. If you would do something to correct that you wouldn't need to replace anything. Batteries ooze acid when they go bad, to counteract that you need to apply a paste of baking soda with water on a used toothbush and scrub all the funky stuff away. Paper towels are good to wipe it off with until it's dry. Take a small file or a small piece of sandpaper and dress or shine up the metal parts that contact the batteries and then spray the parts with contact cleaner from Radio Shack. Your batteries need to be changed BEFORE they purge their innards all over your good work next time - don't let it happen again.
For exact parts replacement you might find some honeywell numbers that may actually make a hit on Google. Even the most bizzare combo of Alpha and numeric gibberish in quotes will sometimes yeild pure Google gold. Other than dealing with a honeywell employee, I have no other suggestions on hunting down your part.
Sep 06, 2009 | Honeywell Heating & Cooling
Need wiring for honeywell pro 3000 in trane xe1200
the pro 300 is a single stage thermostat and can not be wired to control 2 heat stages seperately
May 16, 2009 | Heating & Cooling
Honeywell PRO 3000 Non-Programmable Thermostat Logo
101 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
