Question about Panasonic Heating & Cooling
F11 code showing panasonic inverter - Panasonic Heating & Cooling
Panasonic NN 9853 Microwave. Won't cook on Microwave but shows H97 in screen. What does this mean?
The code probably indicates a problem with the inverter board. The board can be tested, but the test procedure requires some knowledge of electronics.
Go here for instructions:
http://educypedia.karadimov.info/library/Inverter.pdf
Oct 21, 2016 | Panasonic Microwave Ovens
Code for 1100 watt panasonic genious premium H98
That code might mean there is a problem with the inverter board. To test it, use the procedure outlined here:
Sep 12, 2016 | Panasonic Microwave Ovens
Panasonic microwave default code H95? What does this mean?
The magnetron has failed. Likely the inverter needs to be replaced as well. Best to just replace the entire microwave oven with a new one.
May 06, 2015 | Panasonic Microwave Ovens
What does H97 mean?
It is an error code that means ether the magnetron or the inverter is bad.
Oct 16, 2014 | Panasonic NN-SD372S 0.8 cuft 950-Watt...
Panasonic inverter 900w microwave fault code h97
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
Apr 13, 2013 | Panasonic Genius Prestige Nnsd997s...
Error Code
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming2.gif circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
Sep 15, 2009 | Panasonic Microwave Ovens
Why doesnt my oven work?
H97 can mean that there is a problem with the Inverter Board, and you may need to take it to your local Panasonic repairer for assessment.
Mar 24, 2009 | Panasonic Microwave Ovens
Wont Start, Showed a code 98 I believe
Dec 21, 2008 | Panasonic Microwave Ovens
Panasonic Inverter 1200W - NN-SN676S
That code indicates a problem with the magnetron, inverter or control board.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
We're happy to help and we appreciate your thoughtful rating of our answer.
Nov 28, 2007 | Panasonic NN-SN657S Microwave Oven
Heating & Cooling Logo
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
