Question about Ovens
Flavel milano 100 oven power rating - Ovens
SOURCE: Flavel 100 finesse problem
Check the thermal fuse it is located on a bracket at the rear of the fan oven.
Posted on Oct 06, 2008
  • 106 Answers
SOURCE: i need to know the circuit breaker fuse size for a
If your power suply is 240V and the power rating of the ovenis 9.9kw then the expected current consumption is 9900w/240v = 41.25A. Therefore this needs a 8mmsq cable or if not available in your area then use 10mmsq cable. And for the fuse or circuit breaker use 50A
Posted on Jun 15, 2010
SOURCE: how do i turn on a flavel milano 50 oven?. Never
Turn on the gas knob for the oven (below the grill)
You will see an ignition button below the one that switches on the oven light,it is clearly marked.
Press in and hold the gas knob and press ignite button,you will see the safety bar flame light,when the safe to operate temperature is reached,the oven will stay lit after you release the gas supply knob.
Set oven temperate guage (gas mark 4 is approx electric 200 degrees,thats all there is too it
Hope that helps
yorkypaul@gmail.com
Posted on Dec 20, 2010
SOURCE: i have a flavel milano twin owen. but one half isn
hi i have got this problem any joy with urs?
Posted on Jan 14, 2011
ZJLimited
  • 17970 Answers
SOURCE: flavel milano 60 manual
Keep in mind that Flavel Ovens are built by Leisure CP. This link could helpfull: upl/26348-Range60Leaflet.pdf
If this information isnt help, this and other manuals could be find sending a request here.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Posted on Nov 17, 2011
Flavel milano e50. Why does everything except the oven work?
Check the circuit breaker for the oven. 220 volts are necessary for the heating element. 110 volts for the light and clock controls. The 220 volt breaker looks like two side by side breakers with their trip levers joined. Sometimes one will trip without tripping the other. Try resetting the breaker or better yet replace it.
Feb 02, 2016 | Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
Flavel milano e60 how to fit new fan oven element that is riveted
That is complete RUBBISH the screws are accessible from the rear of the oven. At the back remove the screws holding the plate and you will see the element housing. Remove the two screws and the spade connections. Get someone to hold the new element in place for you and attached the screws. Fiddly job so be patient. Connect the spade connections and replace all plates front and rear. Should be the job!!! Someone hold the element in the cooker whilst someone connects at the back. Whatever you do, DON'T TAKE A DRILL TO YOUR COOKER!!
Dec 13, 2012 | Ovens
Cooker flavel milano 60 4 years old Oven working fine, but grill makes problms.may be i am not using right method. Actually every thing is fine, but when i start grill and close the grill door its fir
Hello, you're probably not getting enough air in to keep the flame sustained, check for an outside air tube that might be clogged, if not than try keeping the door a crack open. Hope this helps
Oct 19, 2012 | Ovens
Flavel milano 60 manual
Nov 17, 2011 | Ovens
I need to know the circuit breaker fuse size for a flavel milano ML6CDS electric cooker and the cable rating
Jun 14, 2010 | Ovens
How do i turn on a flavel milano 50 oven?. Never worked with gas stoves before and no manual in sight.
Hope that helps
yorkypaul@gmail.com
Sep 05, 2009 | Ovens
I have a Flevel 100 and wish I had checked out all the problems everyone is having first as I would never have bought it...what a waste of money...already replaced the element on it...the ordinary cooker died weeks ago...now the fan one has died leaving me with no means of cooking in an oven...this is going to the nearest dump as soon as I can get to the shop to buy a very cheap standin...Flavel I hope you are ashamed!
Apr 22, 2008 | Ovens
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
