Question about Dishwashers
Kenmore elite dishwasher
Blue beam at end of cycle not working
    Master:
  • 966 Answers
I would try witching off power and then replug. It might re set. If not, Sears may help. Otherwise is the d/w working ok? If yes don't worry about the blue light.
Posted on Jul 26, 2013
SOURCE: Kenmore elite dishwasher
I had the same problem when I bought it and it just happened again; the problem is solved by ressting the control panel: Hi Temp ---> Heated Dry two or three times. It kind of goes into a testing cycle and the clean blinking light goes off.
Posted on Aug 22, 2008
SOURCE: kenmore elite dishwasher stopped in middle of cycle
My Smeg (never buying brand again) dishwasher UKSTX1 has error message e9 not covered in manual
Posted on Jan 26, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
buddymcl777
  • 67 Answers
SOURCE: Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
Posted on May 19, 2009
  • 1891 Answers
SOURCE: kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Posted on Nov 22, 2009
My kenmore dishwasher doesnt heat during drying
The heating element is burned out or the heating circuit is fubar.
Sep 08, 2016 | Kenmore Dishwashers
Should the inside of the elite dishwasher still be wet at the end of the cycle?
Martha,
If you are talking about having a small amount of water down in the bottom of your dishwasher, that is normal. There is a sump down there that needs to have water in it. If you are talking about having water on the walls, that is probably just condensation from the cycle when you run the heater. Try cracking the door after the cycle is done to let the excess steam out of the dishwasher and that may eliminate the water on the walls. Hope this helps!
Apr 03, 2015 | Kenmore Dishwashers
Kenmore elite dishwasher will not shut off
There is a timer inside the door, and if it is not working properly the timer can get stuck on a cycle and not end until you change the cycle yourself or turn it off. You will need to replace the timer for the dishwasher to work properley again
Apr 14, 2014 | Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore Elite: - Stale smell from dishwasher, won't go away, lingers on dishes, glasses. I tried a vinegar remedy suggested by a diy site - it helps for a cycle or two, but the smell comes right back. ...
try useing your heat to dry at the end of wash,or mabey take and blow your unit out with a compressor and attatchment especially the drain outlet. also run a cycle with just a little lime away then flush with a second rinse.
Oct 13, 2010 | Kenmore Dishwashers
Kenmore elite dishwaher 1646 not cleaning dishes.
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
jklfryyr
Jul 06, 2010 | Kenmore 24 in. 16462 / 16464 / 16469...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
