Question about Furuno FCV627 5.7" Color Sounder 50/200KHZ
Furuno FCV627 Will my furuno fcv627 share information (waypoints) with my raymarine rc435i chartplotter and if so how
    Sergeant:
  • 288 Answers
Yes, using a NMEA connection between the two units. Refer to you owners manual on how to set this up.
Posted on Sep 12, 2013
Unit will not power up. The fuse in the power line is good.
It is possible that their is a fuse inside the display. I would recommend sending the unit to a Furuno dealer to take a look at it. You can contact me: kevin@sun-me.net. We are a Premier Furuno Dealer that does bench repairs in house.
Apr 21, 2010 | Furuno 1650wf/Nt...
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
My furuno chartplotter is out about 2 km on the chart how do i correct this problem it is a furuno 1650wf
Make sure your time offset is correct and also make sure you have not accidentally offset the chart. Also keep in mind that there are places in the charts that you can overzoom which can also cause this problem.
Feb 25, 2010 | Furuno 1650wf/Nt...
Data cards for Fununo 1850w
Furuno just stopped producing these models about a year ago. They use a special chart card. You can still purchase the cards from Navionics or C-map if you need to. I will tell you from experience that you should get your internal battery changed out if you havent done so already to keep from losing your settings and waypoints. The dealer will have to save them for you though and put them back on. Furuno made a GP7000 to replace this one and it's uses SDcards and is nothing like the rest of Furuno's product line. The best replacement for this unit is the Garmin GPSMAP 700 series. You can use your old furuno transducer if you have one (with an adapter plug). This garmin unit also has a built in GPS or you can use an external one. The 700 series will be shipped in April. Check out Garmin's website or mid-shore electronics.
Aug 29, 2009 | Furuno 1850w/Nt Gps Chartplotter C Map Nt...
Can I use my furuno gps navigator to supply position data to my rdp-139 chartplotter and if so which wires need to be connected
Yes the output forom the Furuno GPS (like a GP31) will be yellow and green, hook these to theinput on the plotter blue (or black) and white. Use Data1 on potter as the input and select a nav source of "ALL" in setup menu.
Jun 05, 2009 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Raymarine st8002 wired to furuno
The st8002 is not compatble with rs232 data. You need to supply it with nmea 0183 data. You will need to wire it to the "NMEA port IN" on the pilot to NMEA out on your Furuno and turn on the mnea sentances "out" on your Furuno. You will need to turn on at least the following sentances GGA GLL RMB RMC.Hope that helps.
Apr 20, 2009 | Raymarine St8002 Smartpilot Autopilot...
Furuno 1833C/Dgps37 Plotter creeps
Try adjusting the GPS position offset in the GPS Sensor Settings Menu.
Jan 11, 2009 | Furuno 1833C/NT GPS Receiver
How can I connect my chartplotter to my flatscreen tv
absolutely not! sorry that is the answer, no video out available period
Dec 19, 2008 | Furuno 1650wf/Nt...
Furuno GP 30-35 GPS
je viens de prendre possession d'un gps furuno 30/35 Jje n'arrive pas a afficher ma route pour allaer d un point a un autre merci de m'aider
Jun 14, 2008 | Furuno GP31 GPS Receiver
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Furuno FCV627 5.7" Color Sounder 50/200KHZ Logo
78 people viewed this question
Top Furuno Home Experts
Donni Steen
Tom Chichester
Are you a Furuno Home Expert? Answer questions, earn points and help others
