Question about KitchenAid KSSP48QMS Side by Side Refrigerator
Holiday mode refrigerator
KitchenAid side by side water/ice dispencer keeps going into holiday mode automatically, meaning that it shuts the lights, and does not dispences water nor ice. PLEASE HELP
  • KitchenAid Master
  • 15,640 Answers
If it is on Holiday Mode, press the key just once more. Page 8.
KitchenAid KSSC42QMS01 Use Care Manual
Posted on Oct 27, 2015
  • Desiree Cesarini
    Desiree Cesarini Oct 27, 2015
    Thank you, tried and it came back on by itself after a few minutes
  • Andrew Taylor
    Andrew Taylor Oct 27, 2015
    Great. Pleased to help. Please mark post as Helpful :>)
watugot
  • 290 Answers
SOURCE: Kitchenaid ice maker
Is it sticking all the way up in off position?If so there is a redesigned arm to stop this problem. Instead of just a wire arm, it has a plastic flap on the bottom that hinges. This keeps the arm from jumping into the off position when it cycles. Any whirlpool/kitchenaid servicer should have one and show you how to replace it. Takes just a few seconds. If it is sticking half way down or lower, then it is binding up somewhere. You should be able to raise it about 2" and it fall freely back into place. Post back if this is what is happening.
Posted on Oct 07, 2007
  • 12 Answers
SOURCE: ice and water dispencer is not dispensing ice or water and the ystem s not locked.
I have seen this problem before .the wires locted near the bottom hinge have all broken from the constant open and closing of the door causing it to break the wires.
eeggman
Posted on Mar 10, 2008
mikedurland
  • 481 Answers
SOURCE: kitchen aid superba fridge - ice maker not working .. water dispencer is
The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser (if equipped). The valve that the ice-maker relies on may be bad, or it could be the ice-maker itself.
Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees. In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering. The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
Posted on Jul 06, 2008
huuum
  • 750 Answers
SOURCE: kitchenaid fridge (ksrw25crss02)icemaker slowly stopped
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Posted on Sep 23, 2008
SOURCE: KitchenAid KSBP25FKSS Side by Side Refrigerator Ice & water dispenser ondoor not working
I had the same problem and had to have the entire door replaced. I thought it was a random thing since sometimes it would just start working again, but finally it just stopped for good. The wires that
are below the door on the left hand side (you can see them better when the lower front piece is removed) were severed and they can't be put back together without replacing the door. My repair guy (the refrig. was still under warranty) told me it was a design or installation defect and that he has seen it time and again. Evidently, when they install the wiring, they don't leave enough room to stuff the wires out of the way of the closing door and eventually, it severs them over time.
Posted on Feb 02, 2009
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
Ice maker/ water dispencer "locked"
have whirlpool ice and water waterand ice will not come come out--right no ice wil come push the ice have ice ill not go back to water
Sep 26, 2011 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Turned the water dispencer on after holiday and nothing is being dispenced just an internal humming noise
You can buy individual parts for icemakers, but your best bet would be to replace it. How old is the unit? Depending on the age, it might not be worth it.
Jan 29, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
ICE MAKER NOT GETTING WATER AND ICE IS NOT DISPENCING EVEN IF WE
first check if you have frost build up in freezer 2 could be ice maker 3 water valve
Apr 05, 2009 | Kenmore 57029 Side by Side Refrigerator
Icemaker
Do you hear it trying to draw water into the ice tray? If so, there might be an internal problem you can't fix yourself. especially since the fridge is dispencing water. Is the arm inside the ice maker pushe down? This is what tells the ice maker to fill and make the ice.
Let me know if this helps.
Jan 02, 2009 | Frigidaire FRS266ZDSB Side by Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Kitchen aid superba fridge - ice maker not working .. water dispencer is
Jun 26, 2008 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid KSSP48QMS Side by Side Refrigerator Logo
277 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
