No power to my TV when I switch on
My Orion tv is swiched on at the wall but when I press the button on top of it to switch it on, nothing happens. Please, help! Do I need to ask an engineer to fix the problem or do I need to buy another tv? Hopefully, not!
    Top Expert:
  • Televison & ... Master
  • 74,243 Answers
It sounds that the main power supply regulator board inside the TV has damaged. You surely must contact any service technician.
Posted on Jul 24, 2013
Cant switch on my Irion TV
Maybe things will improve if you leave your TV permanently receiving power from the wall switch and do the actual on-off switching at the TV. Your Orion TV draws standby power even when it is off. When you flip the wall switch off there is no standby power
Jul 24, 2013 | Televison & Video
Need remote code for orion tv
Hello
Three digit universal remote code for Orion are:
035/ 121/ 135
Four digit universal remote code for Orion Tv are:
0121 0135 0035
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON your TV, with its FRONT PANEL POWER CONTROL SWITCH EACH TIME before tring an other code.
OK.
Mar 12, 2011 | Orion Televison & Video
What is a code or some codes i can use to program my remote to the orion1934 19" TV
Hello
Three digit remote codes for Orion are:-
035/ 121/ 135
Four digit remote code for Orion are:
0121 0135 0035
Direct Code Entry
NB: Switch OFF and switch ON the TV, with its FRONT PANEL POWER SWITCH each time before trying an other code.
OK
Jan 16, 2011 | Orion1934 19" TV
I have an sony rm-ez2 and i want it to work with my orion Model #tv1934 whats the code or will it work
As far as I can tell, Sony doesn't have any codes for Orion TVs. You can try searching through all of the codes in the remote. Turn on the TV, press and hold the Set button and then press the Power button. Release the buttons. Then press TV button (component button). Press the CH+ button followed by the Power button. Repeat the CH+ and Power combination until the TV responds (powers off, changes channel). Then press ENT. Check if the TV responds to the remote on other functions. If it doesn't repeat the steps from press and hold the Set button.
This can take up to 70 tries.
Alternatively, try a replacement remote for the TV or a USB programmable universal remote. http://www.remotes.com/store/orion/tv1934.html is a substitute remote that should handle all of the functions.
I hope this helps.
Sep 06, 2010 | Sony RM-EZ2 Remote Control
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Apr 06, 2010 | Orion STV2763 27" TV
Have 8 yr old Orion tv-new remote control for satilite Dish network wont turn tv on--need to know what orion tv codes are.we tried everything tech said to do ,need to know what orion tv codes are..lost the...
We would be happy to help you with getting your new DISH Network remote to control your TV. We're going to start by pressing and holding the TV button located on the top of your remote until all mode button back lights come on, and then release. Use the number buttons to enter the codes for your Orion TV; here are some of the codes we currently have for it: 720, 748, 748, and 748. Press the pound (#) button. To check that the code works try several different functions on the remote to make sure it will properly operate the TV. Remember that some codes may not be compatible with your equipment. If this is the case, try the other codes listed for your Orion TV until you find one that is compatible with it.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Feb 11, 2010 | Orion1934 19" TV
Problem to switch on the cpu
Disconnect the UPS from your configuration,
and connect the AC power directly to a wall outlet.
Press the ON/OFF button and release it.
If nothing happens, press and hold the ON/OFF button for 10 seconds, until the computer turns itself completely off.
Then, press the ON/OFF button, to restart the computer.
Dec 08, 2009 | MSI K9MM-V Motherboard
Orion Code for Uverse
1382, 3213, 1383, 3202
try one of those
Mar 12, 2009 | Orion FTDV2004 20 in. TV/VCR/DVD Combo
Trying to set my Directv remote to control my Orion TV........
Orion code is 11911 and to program your tv to work with a directv remote then follow these...
Setup Instructions
  • Set the "Mode Switch" to TV.
  • Press and hold the "Mute" button and the "Select" button until the visible LED blinks twice.
  • Enter the 5 digit Code above.
  • Slide the "Mode Switch" back to Directv and try adjusting volume and turning tv and receiver off using the off button and then back on with the on button just above the off button
  • Dec 28, 2007 | Orion1934 19" TV
    Orion tv
    Hello, follow this link to download the manual and the codes for your remotes:
    http://www.ofausa.com/remote.php?type=URC4330
    just right click and save as on the download links.
    if this does not work you can try the search method,
    you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
    then press the keys 991 then the power button.
    you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
    Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
    (if you press ch+ too many times you can go back by pressing ch-)
    When complete press the magic or device key again to save the settings (light should flash twice to confirm)
    Many thanks
    Mark
    (www.sparky-uk.com)
    Oct 03, 2007 | One For All URC-4330 Remote Control
    Televison & Video Logo
    155 people viewed this question
    Top Televison & Video Experts
    Electro Med Services...
