I have a Netgear NeoTV streaming player. Upon
I have a Netgear NeoTV streaming player. Upon initial set up it gives me network error 10000006 please check network settings and try again but it doesn't give me the option to check the network settings.
    Top Expert:
  • Computers & ... Master
  • 36,477 Answers
It wants you to go back and review the initial settings you made when you installed the router. You did note them, didn't you?
Posted on Jul 24, 2013
  • Desiree Jul 24, 2013
    It never let me get to that point. This is my initial set up.
    It never let me get to that point. This is my initial set up. It's not a router. Not sure why it's saying its a router. It's a steaming player.
sardanadixit
  • 813 Answers
SOURCE: airlink ar430w not giving a network address to netgear wpn111
Try assigning the IP address manually. To do so go to Network Connections, right click on the wireless connection and click on Properties, select Internet Protocol TCP/IP and click on Properties again. Select use the following IP address and type the address of the same range as of your Router's IP. In case you do not know the range try 192.168.1.5 or 172.16.1.5 with the subnet mask as 255.255.255.0 for both, and when you use the IP as 192.168.1.5 use the default gateway as 192.168.1.1 and for 172.16.1.5 use the default gateway as 172.16.1.1 Also select the lower option as "Use following DNS Server address" and for 192.168.1.5 use 192.168.1.1 and for 172.168.1.5 use 172.16.1.1 .Click on Ok. Click on Ok again and now check for the connectivity.
Posted on Jul 08, 2009
azz949
  • 55 Answers
SOURCE: NETGEAR WGR614v7 Network Security key
Hi, you need to connect to the routers admin pages to configure the wireless settings and security. Check out this page:-
http://kbserver.netgear.com/kb_web_files/n101676.asp
When you get to step 6, click the WPA-PSK security setting and it will give you a box to type in a password of your choice, make it memorable but difficult to guess, so a mixture of numbers and letters. I think its a min of 8 characters.
Hope this helps..
Posted on Jan 25, 2009
redhaze89
  • 854 Answers
SOURCE: Can Not connect to NetGear MR814 v2 Router with Acer Extensa 4420
Here are some troubleshooting steps that I suggest you try:
1. Check physical connections.
a. Connect the modem to the Internet port of the router. The Internet “i” LED on the front of the router should light up.
b. Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
Note: If you were unable to access the router's web-based utility, you may reset the router to restore the settings to factory default.
To reset the router:
a. Please push the reset button at the back of the router and release after 30 seconds.
b. Unplug the power adapter for 10 seconds and then plug it back in.
3. Configure the router.
If your Internet Service Provider is using a cable connection, please follow the steps below:
a. Click on Basic Settings under Setup tab.
b. Select No for Does Your Internet Connection Require A Login?.
c. Scroll down on the center page and look for the Router MAC Address section. Set it to Use computer MAC address and click on the Apply button.
If your Internet Service Provider is using a DSL connection, please follow the steps below:
a. Click on Basic Settings.
b. Select Yes for Does Your Internet Connection Require A Login?.
c. Select Other on the Internet Service Provider drop down box.
d. Enter your ISP's username (username@ISPdomain) and password. Then, click on Apply.
4. Configure the wireless settings.
a. Click on the Wireless Settings under Setup.
b. Change the SSID to any unique name.
c. Scroll down, look for the Security Options settings and select WEP (Wired Equivalent Privacy).
d. Set the Authentication type to "Automatic" and the Encryption Strength to "64bit".
e. Leave the Passphrase field blank, select Key 1 and enter a 10-digit number.
Note: The 10-digit number you typed in the key 1 will be the password or network key for the wireless connection.
f. Click Apply button to save the changes.
g. Go to Router Status under Maintenance tab and check if there is an IP address under Internet port. If it's 0.0.0.0, do a power cycle.
5. Power cycle.
a. Power off the modem, router and computers.
b. Turn on the power of the modem first and wait for it to initialize, the lights to stop blinking.
c. Power back the router and the computers. Check if it will be able to get online.
If you have wireless computers, you can connect them wireless to the router. Kindly follow the instructions below:
6. Connect wireless computer to the router.
If you are using Windows XP with Service Pack 1, please follow the steps below:
a. Please right click on the Wireless icon on the right lower end portion of your computer.
b. Then click on View Available Wireless Networks.
c. Click on the Advanced tab.
d. Please delete all the preferred networks then click on OK.
e. Right click on the Wireless icon again and click on View Available Wireless Network. Please select your network and click on Connect. It will ask you for the network key.
f. Please type in the network key and then confirm it. Network key is the password you type on the key 1 of the wireless settings of the router.
g. Make sure not to enable IEEE and then click on Connect.
If you are using Windows XP with Service Pack 2, please follow the steps below:
c. Click on the Change Advanced Settings.
d. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
e. Right click on the Wireless icon then click on View Available Wireless Networks.
f. Select your network and click on Connect.
g. It will ask you for the network key. Type in the network key and confirm it. Then click on Connect. Network key is the password you type on the key 1 of the wireless settings of the router.
If you are using Windows Vista, please follow the steps below:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network and click Connect.
d. It will ask you for a network key. Type in the network key and confirm it. Then click on Connect.
From the above configuration, please check if you can now access the Internet.
Posted on Aug 13, 2009
cyber07x
  • 18 Answers
SOURCE: I INSTALLED A TRENDNET ROUTER FOLLOWED ALL
try to return to the manufacturer, cause sometimes a gadgets has a factory defect.... you can return and changes that....
Posted on Aug 31, 2009
Testimonial: "RETURNED THE ROUTER, WAS DEFECTIVE, BOUGHT ANOTHER, INSTALLED IT, WORKING FINE. THANK U"
  • 394 Answers
SOURCE: Im trying to connect my
Sounds like a firmware problem on the router. login to the router and check the firmware version against the latest from 3com - the router should be able to check automatically.
Double check the universal plug and play (uPnP) is enabled - it should be under security settings on the router.
Posted on Dec 15, 2010
Remote for my neotv is broken,, what can I use
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability.
Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the site http://electrohelponline.blogspot.com/ Check this site too. http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops.
Type in the "brand name only" of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
May 06, 2015 | Netgear, Inc NETGEAR NeoTV Streaming...
How do I get neo tv to work again , bottom of screen says fatal: internal storage failure
Sounds like the internal hard drive has failed. Most places that know how to fix computers should be able to help. I don't know how much your neo is worth, but a new hard drive could cost anywhere from $60 on up.
Dec 22, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Why doesn't my neotv netgear remote no longer communicating with box?
What do the different Remote control front LED lights mean?
  • Blink blue color twice per second: Remote control has paired NeoTV PRIME and is trying to connect NeoTV PRIME.
  • Blink blue color once per second: Remote control is trying to pair the NeoTV PRIME.
  • Orange blinking: Remote control battery is low. Please replace a new set of AAA battery.
go to page 15 of the following document:
http://www.netgear.com/landing/stream/img/gtv-specs/GTV100_IG_25Oct2012.pdf
Sep 09, 2014 | Computers & Internet
Netgear streaming player
Sounds as if it has found an open Wi-Fi connection, but the device it is connecting to doesn't have an internet connection.
Make sure the Netgear player is connecting to your wireless network, and that you have a live connection to the internet.
Aug 30, 2014 | NetGear NeoTV NTV300
My neotv will not let me watch anything
Check to see if there are any physical obstacles that might interfere with your WiFi signal, things like metal wall studs, metal cabinets, etc. if that is the case and you can't move your neoTV setup, you might need to get a WiFi booster. That worked for us.
Jul 25, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Factory reset setup ERASED EVERYTHING NOW CANT GET TO ANYTHING
Go into settings and search all channels will have to be downloaded again.
Jul 18, 2014 | NetGear NTV300SL NeoTV Max Streaming...
We have a netgear neotv streaming player ntv300. We had it connected to the tv and then it had a message that it needed to be updated, so I checked it to be updated and it started updating for a whil
We had this problem too. It turned out our wi-fi signal was too weak. After we installed a wi-fi signal booster, the netgear update was completed with no further problems.
Mar 10, 2014 | Netgear, Inc NETGEAR NeoTV Streaming...
Neo tv not loading
Reset the box.At the back of the box you can find a small hole.With a paper clip press gently for 10 secs and power off/on the box again.
Jan 23, 2013 | Netgear, Inc NETGEAR NeoTV Streaming...
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
