Question about HP Officejet Pro L7680 All-In-One Printer
Factory reset Do you repair these printers I am having problems with the power cord settings
Code L4-01
Posted on Jul 24, 2013
Lexmark x9575 all in one keeps restarting after slecting scan\copy and fax I have un-installed and re-installed the drivers + reset printer to default factory settings - no change
Try to unplug the power adapter from the printer. Then unplug and replug the power cord into the power outlet. Replug the power adapter into the printer. This will help reset the printer. Check if problem continues.
May 31, 2011 | Lexmark X9575 InkJet Printer
Service ticket 8017416743
Can you please confirm us the main problem you are experiencing with your printer?
Oct 22, 2008 | HP Office Equipment & Supplies
I am getting 'carriage Jam' message and being told to clear it. but i dont know how
Hi
1. Open the cartridge access door and try to move carriage manually back and forth.
If issue not resloved
2. Unplug the power cord from the back of the printer and while the printer is tuned On, Now press and hold OK and CANCEL, while holding them plug in the power cord once the printer is On release the buttons
This will RESET your printer to factory settings and it should fix your problem
Note : As I told you that it will Reset your printer to Factory Settings so if you have IP address saved in it then it will deleted.
Jan 08, 2011 | HP Photosmart 2610 All-In-One InkJet...
Error message Oxc19ac3ff
Perform this reset or go for a new all-in-one
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by following these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord.
If this does not solve your printer issues then check out the articles we have posted on our web page at: http://www.ccl-la.com/blog/index.php/category/printer-repair/hp-printer-repair/ Usually the "ink system failure" is caused by air in the k feed tubes. This can be caused by allowing all of the ink to run out in a cartridge so it sucks up air or using poorly filled ink cartridges that have air bubbles. Our web site articles have step by step guides that show you how to do the ink line purge. It should take you about 10 minutes to do.
I hope this helps if so please rate our solution.
good luck
Nov 29, 2010 | HP Photosmart C6100 All-In-One Printer
The relpacment printer locked up even before i hooked it up. to the lap top same problem as the first printer. it freezes and will not even turn off. hp officejet wireless 6500
Perform this reset
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Jul 11, 2010 | HP Officejet 6500 Wireless All-in-One...
I have a system failed error code Oxc19a0013
2. Press and hold Plus (#) and 6 while plugging in the power cord
Jul 10, 2010 | HP Photosmart 3310 Printer
It will not turn on
I have to ask.......
Power cord plugged in correctly?
Power coming out of the wall outlet? Try a lamp or radio to be sure.
Is the power adapter cord fully seated in the printer?
Can you chesk the power adapter with a mutimeter to be sure there is voltage at the printer end of the cord?
Sorry to ask such normal questions, just making sure.
You may also try this
Resetting to factory defaults
You can reset your printer to the original settings without using the printer menus. NOTE: Resetting to factory default settings will delete all the printer settings you have previously selected.
Step 1
Make sure the printer is not in Power Saver mode. Press and hold the power button for two seconds to turn off the printer. If you have set the Power Saver timeout in the Setup menu, press and hold the power button according to the time you set in the menu.
Step 2
From the printer control panel, press and hold the green button and the red X, and then press the power button to turn the printer on.
Sep 25, 2009 | Lexmark X6650 4-In-One Wireless InkJet...
6310 all in one printer
Thank you for contacting Fixya.
Please perform the steps given below in the given order to resolve this issue.
Perform a power reset of the All-in-One
1. Press the Power button to turn off the product.
NOTE: The product might not turn off after pressing the Power button. Continue to the next step regardless
2. Disconnect the power cord from the rear of the product.
3. Disconnect the power cord from the electrical outlet.
4. Wait 30 seconds.
5. Reconnect the power cord to the electrical outlet.
6. Reconnect the power cord to the rear of the product.
7. Press the Power button to turn on the product.
If issue still persists then please perform a partial reset on your unit. Please follow the instructions given below to perform a partial reset on your unit.
NOTE: A partial reset resets the following settings:
· All user menu settings are reset to the default values.
· All telephony parameter values are reset to the default values.
· Country and language user interface is reset to the default values.
· Fax memory is cleared.
Performing a partial reset of the All-in-One
1. Unplug the power cord from the product, and wait 20 seconds.
2. Press and hold # and 3 while plugging in the power cord to the product.
3. Release the buttons after the product starts up. The product will now be reset to factory defaults.
If issue still persists then please perform a semi-full reset on your unit and verify the results.
NOTE: Semi-full reset resets the following settings.
  • All user menu settings to default
  • All telephony parameter values to default
  • Initiate select country and language UI
  • Clear fax memory Clear fax journal information
  • Clear all speed dials/broadcast lists
  • Clear personal header information
  • Instant Share Settings
  • Wireless Settings Cleared
Performing a semi-full reset of the All-in-One
  2. Press and hold # and 6 while plugging in the power cord to the product.
Sep 04, 2009 | HP Officejet 6310 All-In-One InkJet...
How do i reset a canon mp210 to its factory settings. It is flashing E3, which indicates a paper jam, but there is no paper in the machine or a jam.
Buddy its simple, Just remove the power cord and printer cord. Keep it like that for 5 minutes. then restart your printer thats your factory reset. It its not working then your paper sensor is u/s you need to replace it.
Kindly vote if it solves ur problem.
Jun 28, 2009 | Canon PIXMA MP210 InkJet Printer
Cannot turn printer on
might as well do a reset:
for partial reset:
1.unplug the power cord wthout turning the printer off
2.while the cord is unplugges, press # and number 3 simultaneously
3.hold the 2 button for 10 seconds while inserting the plug back
4.release the 2 buttons when the printer reinitialized.
for semi-full reset:
follow same steps but press # and number 6
semi full means the printer is set back to factory settings or default settings.
Mar 04, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Officejet Pro L7680 All-In-One Printer Logo
Seeker5211
Seeker5211
