DVD won't eject and tv turns off when it tries
    New Friend:
If it doesnt eject,it might mean that its broken and might want to have an expert take a look at it.
Posted on Jul 24, 2013
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
DVD won't eject or play
Use a bent paperclip and insert it into the small hole on the front of the player. This should cause the disk to eject. Reload the DVD and try again.
Jan 25, 2013 | Coby TF-DVD1540 15 in. TV/DVD Combo
LG v181 won't eject - it tries to load even when there is no disc and won't slide out the tray at all.
It's likely a belt that drives the tray has snapped or come off! If you take the top off you might well see it!
Dec 23, 2012 | LG V181 DVD Player/VCR
Dvd won't eject from RCA tv/Dvd combo
While hitting the eject button use a small flat screwdriver or butter knife to ease door open, probably the rubberband like belt broke or the gears jammed up!
Jun 17, 2012 | RCA 22LA45RQD 22-Inches 720p LCD TV -Black
Sylvania 730SVD flat screen with built in dvd... Can't eject dvd inside and when turned on the digital words show up and keep flashing black gray green red... The remote won't even work..
Try resetting the TV by disconnecting it from the mains outlet for 1/2 hour, then connect to the main outlet and switch on the TV.
Feb 03, 2012 | Televison & Video
I can't get my DVD disc to eject. It will play but won't eject? Any suggestions
You should try unplugging the DVD player from its power source then plugging it back in. Now try to open it and if that doesn't work than you'll probraly have to take it apart to get the disk out but sometimes the DVD players can get worn out or if you have a cheaper DVD player it might just be freezing up on you. I have had these problems before. I just took the DVD player apart to get my disk and then trashed it.
Jan 23, 2012 | GoVideo DV2150 DVD Player/VCR
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
I have an LCD/ DVD combo and the DVD won't come out. The tv still reads the DVD but won't eject it. I've tried on the remote and the unit :(
then there is a problem with your cd case .........................................................
ON THE BACK OF DVD THERE IS A WIRE OR SUM PIECE PULLED IT BY USING SOM CLIP THEN THE DVD'S DOOR OPEN EASILY..........
Aug 07, 2011 | Televison & Video
My daughter put the blue ray DVD into the Toshiba 14DLV75 instead of the regular DVD and now it won't eject it. It just keeps spinning like it wants to eject, but won't. How can I get it out?
Hello
Just switch OFF the set by its front panel power control switch, and then switch it On and press the eject button without any delay. Sometimes the tray will eject, and try to close. If so switch OFF the front panel power switch, while it is out, and take away the blu-ray disc. the switch it On. All will be ok then.
May 21, 2011 | Toshiba 14DLV75 14 in. TV/DVD Combo
Televison & Video Logo
75 people viewed this question
Top Televison & Video Experts
