Frozen boot up
Energize CPU to begin boot up. Green light on CD/DVD unit. Biostar logo comes on screen Green light on 3 1/2" floppy drive unit screen freezes on Biostar logo and green light stays on floppy drive. I have disconnected the power and data leads to the floppy drive and tried power up again but CPU will not energize.
    Brigadier General:
  • 3,400 Answers
Answerd
Posted on Jul 24, 2013
CoachTim
  • 202 Answers
SOURCE: Your CPU may have a problem
Have you removed all memory, other cards and unhooked all other drives to see if a short exists there? With a 300W PS some other component may be pulling too much that the CPU can't start so it tells you the problem is with the CPU or The CPU its refering to is on the video card? Good Luck, Tim
Posted on Feb 10, 2007
antiochpc
  • 1314 Answers
SOURCE: Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Posted on Jun 21, 2007
  • 452 Answers
SOURCE: computer powers off while booting, green light stays on!
1. check the cpu fan is properly working with normal speed..
2. go to bios setup and restore all settings to default.
3. if windows start and problem comes after some time , then it might be virus. so, go for a virus scan.
Posted on Oct 15, 2007
  • 40 Answers
SOURCE: windows xp won't load on new biostar motherboard, please help
go to biostar web sight and download sata driver. You may need to run disk that came with motherboard first. Driver may be located on the disk. if not get it from biostar.
Posted on Jun 21, 2009
  • 263 Answers
SOURCE: Asus p5kpl-cm boot problem
Could possibly be a fault on your hard drive the same happened to me ,I checked the hard drive on another pc and it was dead..Good luck John
Posted on Aug 02, 2009
Why wont my xps 700 boot?
Not sure on the beep side but this is what the lights code refer too.
Ensure that all hard drive and CD/DVD drive cables are properly connected to the system board.
If there is an error message on the screen identifying a problem with a device (such as the floppy drive or hard drive), check the device to make sure it is functioning properly.
If the operating system is attempting to boot from a device (such as the floppy drive or CD/DVD drive); check system setup to ensure the boot sequence is correct for the devices installed on your computer.
If the problem persists, contact Dell (see "Contacting Dell" in your Owner's Manual).
May 18, 2014 | Dell Computers & Internet
CPU freezes on boot up
try reset CMOS.or re-wiring the electrical wires,make sure they are seated tight.
Jul 24, 2013 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Green power light comes on but disk drive lights keep blinking and my screen is black on my dell dimension 4700
Remove ALL media from the machine DVD, CD, USB, etc. Check/reseat all Monitor cables. Reboot. If that fails, unplug , plug back in in 30 seconds or so. reboot, if you get a Dell Logo, Open the boot Menu and select Boot from HDD first.
Dec 23, 2012 | Dell Dimension 4700 PC Desktop
No power through mb. CPU and case fans start then stop. Monitor does not come on, HD does not kick. HD access light is constant. green light in back stays on, but computer does nothing else.
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Nov 28, 2010 | ASUS M2N-MX Motherboard
My cpu is not booting on my desktop computer
If you mean your computer is not booting
Replace your PSU power supply unit or
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Sep 22, 2010 | Computers & Internet
Windows xp won't load on new biostar motherboard, please help
Jun 21, 2009 | Biostar K8M800-M7A Motherboard
Biostar motherboard or processor dead?
have you also tried different video cards? or the onboard built into your motherboard?
Jun 11, 2008 | Biostar P4M80-M4 Motherboard
Windows loads on every other boot.
Let's try running a memory test program. http://memtest.org/
Scroll down till you see the three screen shots. Just under them pick you're choice of bootable media to test you're memory.
Download - Pre-Compiled Bootable ISO (.zip)
or
Download - Pre-Compiled package for Floppy (DOS - Win)
Luck!
Mike
May 15, 2008 | Biostar GEFORCE 6100-M9 Motherboard
How can i get rid of the compaq logo even after i format my hard drive .
The screen that I think you're referring to is the OEM BIOS splash screen.
This particular logo / image has nothing to do with your hard drive... it is embedded on a physical chip (EEPROM or ROMBIOS) on your motherboard.
It is possible to make modifications to this particular splash screen (through a hardware hack), but I don't recommend doing it. The screen shouldn't be a problem; it sounds like you might be experiencing a "Boot Order" issue.
I'm assuming you might be having problems with the Boot Order if you're having issues with loading your OS from CD. When you have the Windows CD in the CD ROM and you reboot the system, you should see the following message flash up on the screen (immediately following your OEM BIOS Splash screen):
"Press any Key to Boot from CD..."
If you don't see this message and your CD ROM Doesn't spin up and begin to load windows...you might have a Bad CD ROM, bad CD "Disc" or...you might not have your BIOS Boot Order set up correctly.
HOW TO FIX IT:
To get into the BIOS Setup on a Compaq Presario system, do the following:
When the OEM Logo Splash screen appears, press F1 to enter the BIOS Setup.
Note: On certain Compaq Presario PCs (prior to 2002) press the F10 key at the logo screen to enter setup.
To change the Boot order:
Here's the URL for Compaq's Online FAQ for Changing the Boot Order:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07110&lc=en&cc=us&lang=tr&man_lang=en&product=1843681&dlc=tr#N1310
Try changing the Boot Device Priority in the BIOS Setup: Make sure that the "CD ROM" entry is moved "Before" the entry for the Hard Drive and Network PXE:
Example Boot Order:
  1. CD ROM or Removable Media
  2. USB
  3. Floppy (if you have one)
  4. Hard Drive
  5. PXE (Network Boot)
This should help you load the OS successfully from CD (if you're not being presented with the "Press any Key to Boot from CD..." notification when rebooting with the Windows CD in the CD/ROM drive.
Please repost if this fixed your problem and rate my response!
Good Luck,
LounaTech
Apr 17, 2008 | Compaq Presario SR1800NX Desktop PC
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
