Modems
Problem for Modems
Generic problem for all Modems
802.11g Network Adapter Radio Control Swi...
By Cateline on Aug 29, 2007
I'm trying to connect to the internet on my laptop. It's a Gateway 7415GX and it's supposed to have a 802.11g network adapter in it. I've done everything I can to set up a wireless network but I get the message "Te radio on your 802.11 network adapter is still disabled. Use the hardware radio control switch to enable it"
We have a 2Wire wireless modem through SBC. Our other laptop works just fine with it. If I plug the Gateway in with the cord, it has internet access. This is driving me insane!
I've looked all over and I can't find any switch anywhere on the computer! The only switch on the bottom releases the battery!
Comments:
Aug 29, 2007
- The nervous twitching is slowing down now! Thank you! Good grief they should make that a little clearer!
Same Problem
Feb 27, 2009
-   thanks man -   Guest
Jan 18, 2009
-   I have a gateway with the radio contol switch problem also, how do I fix this problem. my computer was working great until yesterday.
-   Guest
Jan 11, 2009
-   I'm trying to connect to the internet on my laptop. It's a Gateway 7415GX and it's supposed to have a 802.11g network adapter in it. I've done everything I can to set up a wireless network but I get the message "Te radio on your 802.11 network adapter is still disabled. Use the hardware radio control switch to enable it"
I've looked all over and I can't find any switch anywhere on the computer! The only switch on the bottom releases the battery!-   Guest
Dec 04, 2008
-   I have the sameact problem how do I resolve this-   sistavaljohn
Sep 12, 2008
-   SAME-   Guest
Best Solution
posted on Mar 10, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Thanks Dylan....
I had the same problem.... did a "google"... found this entry and tried the fix. Worked for me also on the Acer Aspire 3000.
Have a wonderful day........thanks a bunch!
Debbi
Solution #2
posted on Aug 29, 2007
Very Helpful)
Dyllan
Rank: Guru
Rating: 88%, 160 votes
It's not a physical switch, and they really should put more thought into the error messages they write.
To "flip" the "switch" you hold down your function key and hit F2 (you'll notice a little symbol on the F2 button - that's the "radio switch"). After that, just right click on your wireless connection and choose repair.
Was this helpful?
Yes
No
20 people thought this was helpful
Solution #3
posted on Jun 19, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hit Fn + F2 3 times.
I had the same problem with my Broadcom card. This enabled the radio.
Solution #4
posted on May 13, 2008
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Which key is the function key you refer to?? I have an Acer Aspire 5000 laptop
Solution #5
posted on Nov 17, 2007
Not Helpful)
kwheelz
Rank: Apprentice
Rating: 40%, 3 votes
it works thank you
Was this helpful?
Yes
No
Solution #6
posted on Oct 14, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Dylan thanks you saved me lots of headaches.
   Dennis
Solution #7
posted on Oct 13, 2007
Not Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Dylan,
You rock!  Your additional detail on "right click on your wireless connection and choose repair" gave me a tip on right-clicking on the inverted V like icon in the lower-left corner of Windows and choosing  Connect To then Wireless Network.  Problem resolved.  Woohoo!
Thanks a million!
Tien
PS My niece's laptop is a Gateway MX6214.
Solution #8
posted on Mar 28, 2009
Helpful)
pawwavingpup
Rank: Apprentice
Rating: 94%, 4 votes
Excellent is wasnt the F2 on mine, but another top line key, this gave me an enormous clue.....also the 'not looking for a physical switch'
Brilliant......Many thanks
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Modems
Questions and Unsolved Problems for Modems
Answer
I recently changed to a 2wire modem, and was previously able to access via network my windows vista... (More)
Answer
I have a siemens 4100 modem and a lynksys router. They were working fine until I switched the pc to... (More)
Answer
My modem keeps on going out. It will work correctly for a couple of hours and then it will not be... (More)
Answer
incompatible modem codec detected on my gateway laptop model# 7326gz i cant connect to the internet... (More)
14 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jun 16, 2008
same exact problem
Comment by dippy42, posted on Jun 03, 2008
Im having the same problem!!!! but i do the Fn + F2 thing and then i go to repair and the system freezes! any suggestions?
Comment by kaz1888, posted on May 09, 2008
I have the exact same problem, when I try to connect to the internet using my wireless connection my broadcom 802.11 utility keeps saying the radio swotch is still disabled please use the hardware radio control switch to enable - I have searched the whole computer and cannot find any reference to a control switch
Comment by Guest, posted on Mar 18, 2008
radio switch is disabled
Comment by saveme, posted on Dec 04, 2007
can't find my hardwere radio conrol swich i cant enable it untill i find it
Comment by Guest, posted on Nov 25, 2007
I have the same problem
Comment by kwheelz, posted on Nov 17, 2007
i can not connect via wireless on my laptop it says turn on the hardware radio control switch??
Comment by antonamerica, posted on Nov 17, 2007
Exactly the same problem, just laptop is Acer Aspire 3000.
Comment by SHELBEL, posted on Nov 09, 2007
MY WIRELESS RADIO ADAPTER IS OFF..HOW DO I TURN IT ON?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Modems:
Top Modem Experts
Rank: Guru Guru
Solutions: 3663
Experience: Semi retired, was network administrator, proficient with hardware, software, networks, CAD systems
Ask Me
Find more Modem Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
