Question about Electrical Supplies
Reset oil light - Electrical Supplies
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • 102,366 Answers
What make and model generator?
Posted on Jul 24, 2013
How do i reset my manint req's light after an oil change on a 2003 Honda pilot
Reset oil service light Honda Pilot. From years: 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012.
How do you reset oil service light Honda Pilot. From years: 2003, 2004, 2005.
  1. Turn off the engine. Press and hold the SELECT/RESET button in the instrument panel and turn the ignition switch to run (one position before starting).
  2. Hold the button for at least 10 seconds, until the indicator resets.
  3. Turn the ignition off and then start the engine to verify the indicator has been reset.
How to reset oil service light Honda Pilot. From years: 2006, 2007, 2008, 2009, 2010, 2011, 2012.
Resetting the Engine Oil Life Display if maintenance service is done by someone other than your dealer, reset the maintenance minder as
follows:
  1. Turn the ignition switch to the ON (II) position.
  2. Press the select/reset knob repeatedly until the engine oil life is displayed.
  3. Press the select/reset knob for about 10 seconds. The engine oil life and the maintenance item code(s) will blink.
  4. Press the select/reset knob for another 5 seconds. The maintenance item code(s) will disappear, and the engine oil life will reset to 100.
All information is taken from the Honda Pilot owners manual.
Mar 09, 2015 | 2003 Honda Pilot
How to reset the oil life monitor
1994-99 BUICK LESABRE
CHANGE OIL SOON Light
1. CHANGE OIL SOON light will come on when engine oil has broken down enough to require changing. After changing oil, reset oil life display.
2. To reset light, turn ignition on. Open glove box to access oil reset button. Press and hold oil reset button in glove box for at least 5 seconds, but not longer
than 60 seconds. The CHANGE OIL SOON light will flash 4 times to indicate light has been reset.
May 14, 2010 | 1999 Buick LeSabre
How to reset the change oil light for a 2007 lincoln town car. Hitting reset button doesn't do it.
FIRST press and release the setup button to display oil life= xxx
then press and hold the reset button for about 2 sec it should then display oil life set to 100%
Just pressing the reset button when the change oil light comes on while driving will not reset the computer
Feb 15, 2010 | 2007 Lincoln Town Car Signature Limited...
How do i reset my oil light? my husband changed
TURN THE IGNITION KEY TO RUN WITH THE ENGINE OFF.FULLY PRESS AND RELEASE THE ACCELERATOR PEDAL THREE TIMES WITH IN FIVE SECONDS.YOU HAVE TO DO THIS MORE THAN ONE TIME.ITS NOT GOING TO RESET FIRST TRY BUT DO THIS PROCEDURE.UNTIL THE CHANGE ENGINE OIL LIGHT WILL FLASH WHILE THE SYSTEM IS RESETTING.TURN THE KEY TO OFF.WAIT A FEW SECONDS.START CAR UP TO SEE IF CHANGE OIL LIGHT COME BACK ON.IF YES YOU HAVE TO TRY THE RESET PROCEDURE AGAIN.
Sep 26, 2009 | 2006 Chevrolet Equinox
How to reset the change oil light for lincoln town car 2007
Press setup on message center,
press select for system check,
At oil life, press reset
Aug 14, 2009 | 2007 Lincoln Town Car Signature Limited...
How do I reset the change oil soon light?
Hi to reset the oil life monitor
turn the key on engine off
push the gas pedal to the floor 3 TIMES WITH IN 5 SECONDS
the light will flash then go out
May 12, 2009 | 2005 Chevrolet Equinox
2006 ford exsplorer oil light did not go off after a oil change.
In the owners manual, you will find reset procedures.
I found this for ya, hope it helps!
Please Rate!
Oil Change Reset
A press of the OIL CHANGE RESET switch will allow you to
reset the oil life feature to 100% (or your Personalized Oil Reset
Percentage). After you have the oil changed, you must execute
the following procedure. Press the OIL CHANGE RESET switch
and hold for five seconds as the M/C counts down for five
seconds. After a successful reset the Message Center will display
“OIL LIFE RESET TO 100%.” If you have established a
Personalized Oil Reset Percentage, the display will show that
percentage instead of 100%. To ensure accurate oil life
indicators, perform this reset procedure only after an oil change.
Your Personalized Oil Reset Percentage allows you to establish a
smaller oil change interval than the manufacturer’s
recommended interval. To establish your Personalized Oil Reset
Percentage perform the following procedure:
1. Press and hold the OIL CHANGE RESET switch and press
the RESET switch while the display is still counting down
the 5 seconds to reset. The display will change to “START
OIL LIFE AT XXX%.”
2. Press the OIL CHANGE RESET switch until the displayed
percentage is the Personalized Oil Reset Percentage that you
desire. Your choices are 100%, 90%, 80%, 70%, 60%, 50%,
40% and 30%.
Mar 03, 2009 | 2006 Ford Explorer
Reset oil life display after oil change?
THIS SHOULD BE IT.
How do I reset the Engine Oil life monitor and how does it work? TO reset To reset the Engine Oil Life monitor do the following:
Reset Oil life in NAV/DIC by (with car running) going to INFO>Oil Life>RESET
Press and HOLD until XXX turns to 100%
How does it work? The oil life monitor is a pretty sophisticated algorithm.
GM "The GM Oil Life System will automatically adjust the oil change interval based on engine characteristics, driving habits and the climate in which the vehicle is operated."
Feb 09, 2009 | 2007 Cadillac CTS 3.6L
Change oil light reset?
Hi Shady, here is the procedure for resetting the light.
Resetting Procedure
Follow this procedure to reset the GM Oil Life System™
  1. Turn the ignition to RUN, with the engine off.
  2. Fully press and release the accelerator pedal three times within five seconds.
  3. If the CHANGE OIL SOON light flashes, the system is resetting.
  4. Turn the key to OFF after the light has finished flashing, then start the vehicle.
  5. If the CHANGE OIL SOON light comes back on, the engine oil life system did not reset. Repeat the procedure.
With Trip Computer
  1. Press the MODE button until the light appears next to OIL LIFE.
  2. Press and hold the RESET button for three seconds. The oil life percentage should change to 100 percent.
Nov 02, 2008 | 2002 Pontiac Grand Prix
Electrical Supplies Logo
16 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
