Question about Electrolux Dishwashers
Er 03 code
Display e 03 code which says wash pump
  • Official Brand Answer
  • 4,342 Answers
Hi Trish, thank you for your inquiry! Typically error code E03 indicates that there is a failure with either the wash motor or motor hall sensor. I suggest checking for suds in the tub and siphoning. A further diagnoses is recommended to have a professional check the wiring between motor and main control board since either part could need replacing.
Posted on Aug 01, 2013
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: Electrolux Dishwasker error code Er 03 model # EIDW6305
this is error E03 is short WASH pump. You need to replace it. the cost is about us$150,00
God bless you
Posted on Jul 25, 2013
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
I have a hoover silver pulse inverter e03 came up on the display then changed to e16, what do I need to do?
Hoover dyn8144 and related machines
Error code 03 followed sometimes by Error code 16
Check the usual drain pump and resistance of heating element
On my machine I've discovered that on the motor if the brushes are not bedded onto the commutator it will cause the above codes to display and stop the machine.
The problem is not related to the drain pump or heating element so the codes displayed are not correct. If the brushes are not bedded to the commutator the motor cannot get to spin speed but will happily wash away. Watch the machine during a quick wash to ensure it does actually spin
Jul 10, 2015 | Hoover Washing Machines
Model EIDW6305GSI error code 03 comes on after about an hour after cycle starts could anybody tell me why this happens thanks
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
Dec 04, 2014 | Electrolux Dishwashers
What the code 03 means
if this is a bosch machine -03 error code is the drain. starting at the tub disconnect the drain hoses and check for blockages-also clean the trap and the pump-also are you using the correct detergent-cleaning should keep you running ,if the machine stops then you have a pump problem-cheers Denny
Oct 19, 2013 | Washing Machines
God bless you
Jul 24, 2013 | Dishwashers
Er 03
Good Morning Trish, typically error code E03 indicates that there is a failure with either the wash motor or motor hall sensor. I suggest checking for suds in the tub and siphoning. A further diagnoses is recommended to have a professional check the wiring between motor and main control board since either part could need replacing.
Jul 24, 2013 | Electrolux Dishwashers
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Dishwasher fdb4315lfc stuck with eco wash led and a pump running
Sounds like the Anti-flood switch has been triggered - possibly due to overfilling. Check seal of water level pipe at each end.
Feb 28, 2010 | Washing Machines
Error code of "Er s" appears on the display and inside the light remains on at RINSE Low. HELP!
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
Service Test
Let me know how this works out for you.
Benjamin
Dishwashers Logo
276 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Garth Jackson
Colin Stickland
Colin Stickland
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
