Canon e510 error code e03
  • 224 Answers
SOURCE: error code e03-40
---Copy Density Sensor output adjustment-----
1. Sensor connector is disconnected.
2. Sensor is defective.
3. SPC PCB connector is disconnected.
4. SPC PCB is defective
there is a sensor in the drum unit that measures/sensors toner density on the drum. the sensor is usually dirty and needs a clean. there could be a number of causes so a technician needs to be called.
Posted on May 04, 2010
  • 17 Answers
SOURCE: E03-40 error code
panasonic dp-4520 copier. e4-02 error code
Posted on May 19, 2010
  • 9 Answers
SOURCE: getting error code E03-40. What does this mean?
E03-40 - faulty toner density sensor try the following press function the original size then 3..... your screen should display f1 service mode then press 8 then start now you should see f8 ..... now press start and scroll down to option 09 and press start now you wait till machine runs the process... after that you need to switch the machine off wait 1 minute and switch it back on
Posted on Jun 05, 2010
  • 352 Answers
SOURCE: my canon MP258 show error
That is due to the clear plastic strips inside the printer, the one that run behind the cartridge holder, being dirty or damaged. This plastic strip with black marking on it, is used to tell the printer where the cartridges actually are. Unfortunately it could also be the sensor that reads this strip being damaged. Inspect the strip with a bright torch to see if any ink or dirt is on this strip, use a bright torch when doing so, it makes it much easier. Also check behind the cartridge holder for any torn bits of paper that could be jammed in it. Make sure the printer is unplugged from the power during this!!
I hope this helps
Regards GM
Posted on Apr 08, 2011
hattinghbr
  • 214 Answers
SOURCE: canon printer mp495 error code e03
* E03 error means that it may have something to with a clogging of the paper feed sensor.
try to clean every theing in the paper path and check if there is no sensor broken or bend or stuck
Posted on Nov 15, 2011
Tip
Error E03 Canon Printers
At this error E03 you need to know that the paper sensor is blocked or skipped.To repair the printer you need to unzip the printer and go to the paper sensor and try to replace or to unlock.
on Apr 05, 2011 | Office Equipment & Supplies
Canon e510
mijn lap top opend niet door errow caNON MY IMAGE,WAT MOET IK DOEN,MOEILIJK IK BEN 76 JAAR HELP
May 25, 2013 | Canon Office Equipment & Supplies
Canon pixma mp280 error code E03
the solution is http://archer-pcaldia.blogspot.com/2012/11/error-e03-impresora-canon-mp280.html
Apr 27, 2012 | Canon PIXMA MP180 All-In-One InkJet...
Canon pixma mp495 error code E03
e03 is paperjam or out of paper error, make sure you have a decent amount of paper in the tray. open up all the doors on the printer and make sure there's nothing stuck inside the machine.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
Apr 03, 2012 | Canon Office Equipment & Supplies
Canon printer mp495 error code e03
Nov 10, 2011 | Office Equipment & Supplies
What is Error Code E05 Canon MP258? and Error Code E03 Canon MP258?
Hello and Welcome to FixYa!
E05 Kindly see this link, (In Parts) E03 Kindly see this link.
Concerned, Nooh
Aug 12, 2011 | Computers & Internet
Error code
the inlet motor m1 is faulty
Jun 09, 2009 | Canon Office Equipment & Supplies
Canon NP6545
E 510 is the paper feed motor error.Inspect the paper feed drives and gears.If nothing feels wrong change the paper feed motor.you can try to get the motor repaired
Sep 26, 2007 | Canon NP 6545 Copier
1,189 people viewed this question
k24674
jasbo
jasbo
