Question about Car CD Changers
Alpine CDA-0855 radio reception
The unit powers up and plays cd's fine but when changing to am/fm I will sometimes get a station. Most of the time I get nothing (no stations) or just a high pitched noise
SOURCE: Ford 6006e cd player won't
code 6006e
Posted on Jul 16, 2010
0 characters
1 Points
Alpine S611 cd shuttle, 6 disk changer, is a OE honda equpment from dealer, car is year 98', player plays CDs purchased from store, copyrighted, but wont play CDs i burn from MP3 to standard red book...
This model is about ten years old and it can plays discs of CD format only. There is OM for it:
Feb 01, 2011 | Alpine CHM-S620 6-Disc CD Changer
I bought a '96 Mustang with an Alpine CHM 5620 CD player already installed. The unit appears in great shape and looks as if it were installed by a pro. It seems to load up the CD cartridge and change CDs...
This model of cd changer doesn't have the fm modual built into it. So I am wonder how this setup worked before. Most of these units had an FM tansmitter in them and you would just turn on your factory radio and set the fm tuner to a certain frequency like 89.5 or 91.3, not excatly sure on the right number, but somewhere low in the range. Turn on the stero and try tuning into differnet stations.
But like I said this model is desgined to be used with a aftermarket head unit with the proper wired connection going from the cd changer to the head unit.
Sep 21, 2010 | Alpine Car CD Changers
What fm station do I set my radio on?
i have a ford explorer, 1995 it came with a 10disc cd changer only trouble is we dont know what radion station we need to use for it can you help?
Apr 15, 2010 | Xtreme Sound WMS6100RW 10-Disc CD Changer
Alpine CHM-S620 6 Disc CD Changer Components
sounds like the changer was plugged into the antenna jack of the radio. this means that you can run it through any radio simply by sending a signal to a preset station on the radio and listening to it through tuner. the control unit ran the changer itself. you may be able to obtain replacement cables from
Apr 01, 2010 | Alpine CHM-S630 6-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
What radio station does the radio need to be on in
this varies from CD to CD player, just run the stations through the FM band until u find it.
Oct 28, 2009 | Pioneer Car CD Changers
I need to change the region code of Alpine CHM-S630 + BRLA3 from region5 to region2, or 1
You don't need a region code for play audio or mp3 CD's. The region code comes into play because there are diff. & for displaying images.
For a CD player, its universal anywhere around the globe unless you have a radio FM/AM radio installed too. Even then local stations can be picked up according to their broadcast frequency.
Thus only a DVD Player gas region codes since options include a decoding algorithm so that it can be used, like PAL/SECAM, etc....sodeep
Sep 25, 2009 | Alpine CHM-S630 6-Disc CD Changer
What radio station does the jvc ks-rf40 changer use
You must be using an FM modulator then - the easy way is to put a cd in and press play then do a tuning search on FM and it will find it. Then save that station
Aug 24, 2009 | JVC Car CD Changers
Car CD Changers Logo
180 people viewed this question
Top Car CD Changers Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Car CD Changer Expert? Answer questions, earn points and help others
