Three days before I brought it to the dealership I had alternator, spark plugs, spark plug wires and a coil put in and it was just fine. It sounded like this when my husband came home from picking it up.
SOURCE: Ford Windstar SE, 3.8L V6, 1999, front seat heat/defrost is cold
the blendor actuators strip out the gear inside the actuator cases on these all the time. replace the actuator.
SOURCE: service engine light was on - took to dealership
they make a spark plug repair kit you can do your self in your drive way, Napa Auto Parts has it...
watch video...
http://www.timesert.com/html/ford_sparkplug_faq.html
SOURCE: 2002 Ford Windstar spark plug orientation
For the 3.8L:
Firing Order:
1-4-2-5-3-6
Cylinders:
....(back)
3............6
2............5
1............4
....(front)
Ignition Coil Pack Connections:
(back)
3....4
2....6
1....5
(front)
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com.
SOURCE: 2005 chevy cobalt 2.2 is running rough (putting)
Number three cylinder is miss fire,it does not mean it is the coil,although it could be,remove the coil,and boot,and spark plug,inspect them to see if the plug,or boot look bad,replace the spark plug,and if the boot is burned or distorted,replace it,a fuel injector can cause a miss fire also,but change the spark plug and see if this solves the problem,if not replace the coil,if it is a dead miss,then the coil might be bad,as for the water in the fuel ,the cap is missing,,and 5 dollars worth of HEET will not hurt,also,fuel from the fuel station,can have water in it.It happens a lot.
SOURCE: We had a recall 03 windstar ABS light was on all
I own a 2001 Windstar. Your noisy brake problem could be nothing more that new brakes being broken in. I have done many brake jobs on my 2001 Windstar as well as other vehicles that I have owned. To prevent this problem from occuring, I apply a thin film of Disc Brake Quieter directly to each brake pad during the installation process. This quiets the brakes during the break in period. I hope this helps.
Welcome to FIxYa.com
Yes there is
Fuel related- speed sensor and Seat to latch recall
Thank you for using FixYa.com
Regards, Lee Davidian
