Question about Dryers
Kenmore gas dryer model #79838
The heat on my gas dryer isn't working. I am trying to check the thermal fuse but can't figure out how to take the front off or do I take the back off. I have disconnected the electricity and turn off the gas valve. The lint trap is located inside the dryer just below the door. I don't see any clips on the top and tried prying the bottom panel out. The back has lots of screws but don't want to disconnect gas line if I don't need to.
Try this video it may help. http://www.youtube.com/watch?v=Q8j6fQM3P34
Posted on Jul 24, 2013
  • tbonbright Jul 24, 2013
    Anna, This is a great video but the back of my dryer doesn't look like the one in the video so I still can't get inside to figure out if it is the thermal fuse or not. Any help you can provide would be appreciate.
SOURCE: removing front panel on kenmore dryer
I was able to fix my dryer on my own. the problem was, i was instructed to access an area that wasn't correct for the needed repair.
Posted on Mar 10, 2008
  • 131 Answers
SOURCE: Dryer runs but doesn't heat up when sttings call for heat.
You may need to do some troubleshooting. This can be done with the machine unplugged - you may have to activate the start switch, belt switch (if it has one) and the motor centrifugal switch manually.
Tip for troubleshooting 220v systems - clip one lead of a ohm meter to either L1 or L2 on the terminal block. It doesn't matter which one. According to the tech sheet (under console) follow the path for current from your clipped terminal, through the heating element, to the opposite terminal. All the readings should be less than 100 ohms, until you reach the failed part. Confirm failure by disconnecting a lead from the suspected part, and test only that part.
Live troubleshooting is sometimes slightly easier, but much more dangerous than the procedure described above. - It is definitely not recommended for beginners, or for professionals, if it can be avoided.
reg501
  • 413 Answers
SOURCE: lint trapped inside dryer housing
SHUT OFF POWER AND GAS
1. Begin by opening the door removing the two screws on the left side of the door opening.
2. Then remove the screws that secure the door hinges to the cabinet. Lift off the door (may take some wiggling)
3. Grasp the outer top sides of the front panel and pull toward you.
4. Lower the front panel and lift off.
5. At each top corner remove the screw and latch that hold down the top.
6. You should be able to do the rest from here.
Posted on Jun 14, 2008
ronpar
  • 27 Answers
SOURCE: Whirlpool Duet Dryer - Working but no heat
it sounds like your heating element is gone bad. there is no heat if they burn out or get corroded
Posted on Jun 29, 2008
  • 148 Answers
SOURCE: I have a Kenmore 110.74812200
its the flame sensor,or the coils on your gas valve
Posted on Jul 08, 2008
Dryer not drying
another user's Q&A for the same issue try that or call may tag, they are supper helpful
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
8574d88.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
d5b5af3.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
77d6bd4.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
    Oct 08, 2012 | Whirlpool LGQ9858P Gas Dryer
    I have a kenmore elite dryer model # 11070952990 that will not heat up, I replace the glow bar ignitor, I don't know what i'm missing.
    Check the thermal fuse. You can temporarily bypass it by hooking its two wires together then see if it heats.
    Sep 24, 2011 | Kenmore Elite Oasis 7808 Gas Dryer
    I have a Kenmore gas dryer model 110.77670400. The ignitor lights, but gas valve doesn't open. I tested thermal switches in back for continuity and all checked good. Flame sensor is good and I replaced...
    Thank you for contacting fixya.com.
    If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.However unplug your Kenmore gas dryer from its electrical outlet. Make sure that all electricity has been disconnected from your dryer.
    Turn off the gas valve that supplies gas to your Kenmore gas dryer. Remove the gas flex line at the shut-off valve using an adjustable wrench.
    Remove your dryer's back panel. Take out the screws on the back of the dryer and the panel will come free. Set the panel and screws aside until you are ready to replace them.
    Locate the thermal fuse between the dryer's blower housing and exhaust. The thermal fuse looks like a white plastic strip with two connected wires.
    Please get back to us if you have further query else please accept the suggestion.
    Jun 15, 2011 | Dryers
    Sears Kenmore gas dryer not heating up
    Remove all duct work and inspect for lint trapped inside. If you get a very good handful the moister sensor shuts down the burner automaticlly until the vents are cleaned thoroughly
    May 03, 2010 | Dryers
    My Kenmore Gas Dryer does not heat. It looks like
    You can use an ohm meter to check t-stats and thermal fuse.
    Apr 04, 2010 | Kenmore 74902 Gas Dryer
    Kenmore Elite 110.7208201 won't heat up.
    Hi
    Please check the things that could stop a electric dryer from heating:
    - House fuse or breaker (needs two of them), heating element, burnt wire, thermostat(s), thermal fuse (not all models), motor heat switch, timer, selector switch, burnt power cord/plug.
    And also check the things that could stop a gas dryer from heating if you have a gas dryer:
    - Glow bar igniter, thermal fuse (not all models), coils on the gas valve, gas valve, thermostats, motor heat switch, timer, selector switch, sensor.
    Please do rate the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Aug 29, 2009 | Kenmore Dryers
    Not heating
    Hi
    Things that could stop a electric dryer from heating:
    • house fuse or breaker ( needs two of them )
    • heating element, burnt wire
    • thermostat(s), thermal fuse ( not all models ),
    • motor heat switch, timer, selector switch,
    • burnt power cord/plug.
    You can check these things using an ohmmeter/multimeter from here.
    Things that could stop a gas dryer from heating:
    • glow bar igniter,
    • thermal fuse ( not all models ),
    • coils on the gas valve, gas valve, thermostats,
    • motor heat switch, timer, selector switch, sensor.
    A page for checking gas dryers is here.
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 20, 2009 | Kenmore 62802 Electric Dryer
    Kenmore gas dryer model #76812690 will not heat.
    does the dryer heat initially when you first turn on the dryer Or no heat at all?
    the first thing i would check is tthe thermal fuse thats located on the back of the unit. test it with a multimeter and see if it has continuity, if it doesnt then replace that and your operating thermostat. the check to be sure you venting to the outside of your house is not clogged
    Apr 29, 2009 | Kenmore Dryers
    Dryers Logo
    65 people viewed this question
    Top Dryers Experts
