Question about Dometic Refrigerators
Why does my refrigerator stop working when i drive my motorhome
    Top Expert:
  • Dometic Master
  • 6,465 Answers
Check transfer switch or house batteries
Posted on Oct 11, 2017
My motorhome generator keeps sputtering and dying.
Check the fuel system e.g.the filter the hose and tap, also the on of elec. switch.
Sep 16, 2014 | Rv Motorhome Dual Co & Lp Gas Alarm...
1978 chev motorhome brakes are hard to push down to stop
If they are standard power brakes, check the vacuum booster. The diaphragm may be broken. If it holds a vacuum it's OK. If the brakes run through the power steering pump, make sure the belt is tight and the steering is smooth.
Jun 29, 2014 | 1998 Chevrolet S-10 Pickup
My motorhomes Eberspacher combitronic heating no longer works on 240v although still heats water and heats on diesel.
Hi l had exactly the same problem with my combitronic, tried virtually everything, asked & took my motorhome to several places found one that could find the fault. Apparently there was a break down of a wire under the sheathing stopping the heating working on 240v. Agency supplied if required.
Jul 23, 2012 | Dryers
Our electrolux fridge in our motorhome sometimes works and sometimes doesn;t on either electric or gas but works when the engine is running would changing the mains board cure the problem we have had...
Not sure exactly what type of fridge your talking about here, as heading says dometic, your comments say electrolux, but I will say this. If it works good with engine running then I'd be looking at my charging circuits and auxiliary batteries circuit. Look for a battery isolator in the circuit as well.
Jul 31, 2011 | Dometic RM2452 Refrigerator
Fridge/freezer in a motorhome has stopped working on gas any help & advice would be greatly appreciated.
I am guessing this is a "three way fridge" 12 volt, 240 volt and lpg gas.
This is an absorbtion refrigerator and it uses heat to drive the cycle.
The things to do are;
Clean the gas jet, Piezio starter and thermocouple.
Also clean the rust, carbon and scale away from the heater tube and chimney.
Hopefully all will be good again
May 02, 2011 | Refrigerators
Ref/freezer quit working. looks like somekind of liquid in back leaked out.. fuses ok.is this repairable? motorhome Domestic RM2852
motorhome refrigerators are a different system entirely than residential style refrigerators. I would do a search for dometic, not domestic, refrigerator repair
Feb 07, 2010 | Dometic RM2852 Refrigerator
Motorhome fridge works on gas but not electric
I thik that whoever advised you of an underlying problem is very muich correct. It sounds like you are getting quite a bad short somewere in your system. I would strongly advise not turning things on as you may fry your entire electrical system. I would also get it checked by a qualified electrician. I hope this is helpful.
Nov 04, 2009 | Refrigerators
I have a Dometic fridg in my 2005 motorhome and when I start my f
You need to unpush the gas button on the front control. If the gas button is pushed in, then it is trying to run on gas and with the tank empty, it is unable to light. That is why the check light is coming on. If you turn the gas side off and have it on auto, it should switch to the AC side and work fine.
Hope this helps,
Jeff
Jul 05, 2009 | Dometic RM2652 Refrigerator
Refrigerators Logo
24 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
4stevetaylor
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
