Question about Vehicle Parts & Accessories
I have a 1990 eagle talon tsi awd, I Started it and the timing belt broke How would I line of the time? Where is my motor shot?
    New Friend:
  • 53 Answers
The pistons may have smashed into the valves.
Posted on Jul 25, 2013
  • jessy Jul 26, 2013
    Can it be fixed ?
  • tomcleveland Jul 26, 2013
    Yes it can be fixed but it's going to be expensive. The pistons may have bent or broken valves, it may have also cracked the head or broken the pistons or caused damage to a rod. My opinion is, replacing the motor may be the most economic choice.
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Turbo 93 eagle talon
i have fitted a new thermostat heat working fine. but temperature gauge not working
Dec 10, 2013 | Cars & Trucks
Electrical problem - 1990 Eagle Talon TSI
the controllers in the vehicle draw a small amount of power even if the car is not running, probably enough to drain a battery over a long period of time, when you store a car it is recommended to charge the battery at least once a month
Jul 21, 2010 | 1990 Eagle Talon
No power to fuel pump 1990 eagle talon tsi awd turbo 5 speed. checked all fuses and ecu for damage and all seems fine, new fuel pump so i know thats the the problem the mpi/mfi relay is not clicking when...
I hope this helps? Are you missing anything else? Engine cranking you have spark at the plugs and fuel injector pulse? Any applicable trouble codes? Battery has a full charge? See load side of mfi relay, that line with arrow head, with key on, good voltage at upper wire? If so, if you use a jumper wire between proper wire colors, the pump should run.
Jul 03, 2017 | 1990 Eagle Talon
Starter location on a 1996 eagle talon tsi awd
Should be on the front top area of the transmission where it connects to the motor. Should be easy to reach but you probably overlooked it because that area gets very dirty.
Mar 16, 2010 | 1996 Eagle Talon
I own a pristine '91 eagle talon tsi awd 5
check buscher racing.com or call them they know it all when it comes to talons and dsm's
Oct 29, 2009 | 1991 Eagle Talon
I cant get my timing marks to line up.
take it to a shop before you destroy the engine
Jun 02, 2009 | 1995 Eagle Talon
Hi, I have a Eagle Talon TSI AWD 1990 175000km bought new. the motor runs flooded & the turbo is always on but sometimes it falls back to running normal, like new, the gas pump pressure was checked, the...
they fail sometimes you need to make sure the snail has good bearings ..plus after its been boosting if its been turned off right away thats not good..with higher milage i would do drivability checks before i tear up a wastegate or charger ..your timing should be retarded a bit to boost correctly.
Apr 07, 2009 | 1990 Eagle Talon
1997 Eagle Talon TSI AWD oil pressure goes from zero to normal and back
Te 1st thing to do is replace the oil pressure guage sending unit, most times that is the problem, if press remains low use a mechanical test guage to verify what the oil pressure is, hook this tester up at the port the sending unit is screwed into.
Oct 29, 2008 | 1997 Eagle Talon
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
