Question about Cameras
Lost bottom bar w/ menu.
I cannot get the bar @ the right side/bottom of the of the screen to appear w/ the menu. I was trying to change some settings & lost it. I also managed to change the screen size so large I cannot see most of any page I do get. I'm thinking that I can correct that when I can retrieve the menu. I'm not savy so please keep it simple. Any help would be greatly appreciated!!!
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
This is a camera or something else? Either way, what make and model?
Posted on Jul 24, 2013
  • 11967 Answers
SOURCE: When switching on I have a yellow camera icon on
In the setup menu, do you have an entry for "reset"? If so, try it.
Posted on Aug 30, 2009
  • 74 Answers
SOURCE: How do I retrieve lost pictures on my Olympus xD
There is software that can recover deleted files from a drive if that part of the drive hasn't
been overwritten since you deleted the files. If you lost them due to a bad hard drive then the
solution is much more expensive.
I have found that File Recovery is the most
effective.:http://www.magicpctool.com/product/data_recovery.htm
Posted on Oct 29, 2009
Kensolutions
  • 455 Answers
SOURCE: i have sony DSC-W190,i want
If the Menu settings in the camera is changed, then I suggest you to reset the Camera back to factory default. Initializing the Camera back to factory default will set all the settings in the Camera back to factory default.
To initialize the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
You can also try a manual reset;
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
The blurry image capturing can also adjusted by changing the ISO Settings or the Scene Selection modes.
Thanks for using FixYa!
Posted on Apr 07, 2011
t00nz
  • 4738 Answers
SOURCE: I have a Cannon PowerShot
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Posted on Jun 06, 2011
emissionwiz
  • 76673 Answers
SOURCE: my cannon ixus 130 is permanently blurred, i have tried resetting to factory setting using the menu
Time for a new camera. There is no reset hidden or otherwise.
Posted on Feb 20, 2012
Lenovo b640 model the tool bar is showing on the top but as is drag it on the bottom it is hide or not showing but it is showing on the right and left of the windows 7
Hi
Try right clicking on a part of the task bar and checking that the "Lock Task Bar" is not ticked in the menu that appears, untick it if it is. It shouldn't be as you can drag it to the left or right of the screen. Then click "Properties" and check that the "auto-hide task bar" is not ticked. Again it shouldn't be but untick if it is.
In these circumstances you should be able to drag the task bar to all four sides of the screen and it should remain visible at all times. If it is still not showing at the bottom of your screen, I would suspect that your graphics card is setup to show a larger screen than the actual screen can display, and you need to right click somewhere on the desk top and look at "Screen Resolution" (win7) to see what the settings are and what you can change them to to try and bring the task bar back into view when it is on the bottom.
Do any of your programmes lose their lower parts when viewed full screen?
On today's wide screen profile machines, I often find it better to have the task bar on the side. It takes a little getting used to at first, but after a while I found it more natural than at the bottom.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 09, 2014 | Computers & Internet
Tip
How to set your Desktop Screen Resolution?
Greetings, Welcome to Fixya!
So you need to adjust your Desktop Screen Resolution ey!!! It's a good thing you visited as today we are going to discuss just that.
We will be using our monitor to it's full potential, which will ensure we see the best picture our monitor can provide.
Follow the steps below:
1.)Right click on your desktop screen.
2.)A rectangular menu box appears.
3.)Select Properties, found right at the bottom of the menu box.
4.)Select the Settings Tab, found on the top right hand side of the window.
5.)On the bottom left hand side you will notice a slider bar under the heading Screen Resolution.
6.)Move this slider to the left to decrease the Screen resolution, less detailed, move the slider to the right to increase the Screen Resolution, more detailed.
7.)Ensure that the colour quality is set to highest, to give a more detailed and clearer picture!
Below: The window, see the slider bar on the bottom left and the colour quality on the right!
That should do the trick!
Now you will enjoy all the detailed, crisp, goodness that your monitor has to offer.
Thanking you
Till next time!
damnor01
on Dec 14, 2010 | Computers & Internet
Tip
How to change the mouse sensitivity
<p>Click on the "Start" button in the lower left corner of your computer screen to open the Start menu so you can change the mouse sensitivity. Locate the control panel link on the right-hand column of the Start menu and click on the link.<br /> <p><br /> <p>Wait for the Control Panel manu to open and then locate the "Search Control Panel" bar at the top of the menu on the the right-hand side. Type in "mouse" (no quote marks) in the window and locate the mouse menu at the top, left side of the menu.<br /> <p><br /> <p>Locate the link that says "Change Button Settings" at the bottom of the mouse menu and click on the link. When the mouse properties window appears, locate the tabs at the top of the window and find the one that says "Pointer Options."<br /> <p><br /> <p>Click on the "Pointer Options" window tab and locate the heading that says "Motion." In the Motion section, find the slide ajustment bar that is labeled "Slow" on the left side and "Fast" on the right side of the bar.<br /> <p><br /> <p>Move the bar according to your desired speed and preferences, and click on the "Apply" button on the lower right-hand side of the window.<br /> <p><br /> <p>Click the "OK" button on the lower left-hand side of the window, which will take you back to the default window. Verify that the mouse sensitivity is according to your needs and readjust if necessary by repeating these steps.<br />
on Dec 07, 2010 | Computers & Internet
Need to get into control panel to change settins
Click on the triple bar, below the X in the upper right corner of your screen...... a drop-down menu will appear........click on the word "settings" near the bottom of the drop-down menu........if you can't find the settings you're looking for.........scroll down to the bottom of the screen until you see the words "advanced settings" (in blue).......click on the words "advanced settings" and additional options will appear below.....continue scrolling down until you find the settings that you want.
Apr 03, 2014 | Acer C7 Chromebook
Sidebar has suddenly moved to side affecting size of screen. How do I return it to bottom???
You are probably talking about the windows Task bar that normally resides at the bottom of the screen:
Two ways of moving this task ba, to top/bottom/letft/right position of the display:
  1. Move the cursor on a blank/inactive area on the task bar, usually in the largest blank area towards the right, click and hold the right mouse button and drag the Task bar to the bottom of the screen.
  2. Go to the Task Bar 'Properties' (You can get this context menu by clicking the left mouse button after putting the cursor on a blank/inactive area on the task bar) and change the 'Task bar location on screen' option.
Hope it helps: let me know how you go.
Dec 17, 2010 | Toshiba Computers & Internet
Mouse sensitivity is slow.i want more then more speed of mouse pointer,i already search but nothing...pleas SIR
These are the steps to change the mouse sensitivity
Good luck
do rate the solution if got help
Dec 07, 2010 | HP P2360AA Keyboard/Mouse
FACEBOOK IS NOW WRITTEN CHINESE
YOU CAN CHANGE THE LAUNGUAGE,
FIRST SIGN IN---------}THEN GO TO THE HOMEPAGE----------------}THEN SCROLL THE MOUSE TO THE BOTTOM OF THE PAGE AND THEN YOU CAN SEE AN OPTION ON THE RIGHT BOTTOM AT THE LAST CORNER OF THE PAGE IT WILL BE IN THE SECOND LAST MENU ON BOTTOM RIGHT SIDE CLICK IT A MENU BAR APPEARS IN WHICH WE YOU CAN CHOSE THE LAUNGUAGE
Jul 15, 2009 | Facebook Social Network
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Lost task bar
try to use the second key on the bottom left of your keyboard to see the location of the task bar on the screen, if the bar appears and disappears once the key is released bring the mouse pointer on any place where the task bar appeared and then right click on it go to properties and uncheck the option auto hide the task bar.
Jun 25, 2008 | Computers & Internet
Screen Adjustment
On your monitor at the bottom there is 3 buttons. The one all the way to the left is the "menu" button. The next one (going right) is the "NEGATIVE" button. The next one (going right) is the "POSITIVE" button.
You can move your screen around. First, start by pressing the menu button.Then, a menu in blue, with a bunch of little white icons will appear. Next, go over two icons by pressing the positive button twice. Then, proceed to push in the "menu" button again. A bar will appear. By pressing your negative button, your screen will move left. Pressing your positive button will make your screen move right. Adjust your screen until the black on both sides are of even proportion. Then, press the menu button to return to the orginal menu you started at. Proceed to press your positive button two more times. Then, press your menu button. Then, once again, use your positive button, and your negative button to adjust your screen to even out the black on the top and bottom.
Dec 24, 2006 | HP Compaq FS 7550 17" CRT Monitor
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
