My AV cables are plugged into my TV and into my VCR properly, yet when I switch the TV source to AV, it says "weak or no signal." I don't know why. Please help.
SOURCE: how to associate the av sound with the HD video out
DVI connections do not carry sound. The only feasible way to get sound from the PS3 is through a standard twin phono-phono lead (red & white RCA)
SOURCE: No Signal or Check Signal cable?
did you make sure tv was on the right channel or on the right line (1, 2, or3,) channel? if ao, how old is the ps3? try wiggling the cable in the back of the ps3. it might get the signal to come through. if it that works then the prot on the ps3 is bad. find out if it is still on warantty.
SOURCE: Problem with AV Input and TV signal distorted but i know signals are fine from source
change devices to other ports, if you are sure some ports are not working properly then you will need to replace the mainboard.
SOURCE: 50" Vizio Plasma reads "No Signal" on all inputs?
Well, your TV is still under warranty. That's the good part.
The only thing I can recommend without voiding the warranty is leaving the TV unplugged for 30min. That way, the TV can reset itself and hopefully correct the problem.
If that doesn't solve the problem, it's time to use the VIZIO warranty.
Here's contact info if you need it.
Technical Support
Toll-Free: 877.698.4946
(877 MY V I Z I O)
Technical Assistance Emails:
[email protected]
Customer Service
Toll-Free:888.849.4623
(888 VIZIO CE)
SOURCE: only av input is working LG 42LC7D TV
I may put money that some one did stole your internal cable from the power supply to the main board !
Don't be surprised they did it to me at LG company .
It was a faulty VCR. Never mind. Please disregard my question.
