Question about DeLonghi PAC L90 Portable Air Conditioner
What does f e on screen mean - DeLonghi PAC L90 Portable Air Conditioner
How can I make the screen smaller when I want to.?
adjust your screen resolution. Higher numbers mean more dots per inch, and that means smaller images on screen.
Sep 19, 2014 | Computers & Internet
What does it mean when your 42 inch TV has a blue screen
The blue screen means that the back light is on. There is no signal coming to the screen to modulate a picture though. Also since there is no sound it means that the main pc board in the unit is probably bad.
Sep 11, 2014 | Mitsubishi Lt-40164 40 Inch Unisen Led Tv
SCREEN BLANK, UNABLE TO ACCESS ANY APPS AND CONTACTS
Hello there,
If the screen of your phone is blank, that you are not able to access any folder, file or application on the phone, it means the screen is damaged, if the screen still looks intact, then it means the ribbon that connects the screen to the main board of the phone is damaged.
That means you will have to replace the ribbon that connects the screen to the main board of the phone.
Thank you for using fixya
Caseytech
Jul 06, 2011 | Cell Phones
How do i close my browser window
You can close your browser window by clicking on the red "x" in the top right hand side corner of your screen. The red "x" means "close". The "square" in the center next to the "x" means make "bigger". The - key next to the square in the upper righ hand side corner of your screen means "minimize". "Minimize" means bring the window to the bottom of the screen. It's like tucking it away or hiding it. If your window is full size and you click the minimize button, it will make the screen a smaller square in the center of your monitor. If you click it again, it hides the window at the bottom of your screen. You can see which windows re open by reading the labels at the bottom of your screen. To bring a screen back up to regular size when its minimized on the bottom - just click on it with your mouse.
Mar 03, 2011 | Mozilla Firefox
My screen is so small cant see anything?
If you mean the size of the webpage content then go to that particular webpage and hold CTRL key in the keyboard and scroll down the mouse.
If you mean the size of the browser then you have to maximize it by simply hitting the maximize button in the upper left corner of the browser.
If you mean the size of the main screen then refer to the screen buttons that usually situated in the bottom part of the screen.
Sep 01, 2010 | Facebook Social Network
How to repair white screen of n70
it depends if its a screen problem or a virus problem.
Those are one of the things that can make a phone screen to be white.
Put on the phone and use another line to call your phone. If it rings, then it means its a screen problem. But if it does not ring, then its a virus problem.
In the case of screen problem, loose the phone first and check it the screen is well fixed. If well fixed, then it means you have to buy another screen.
But in the case of virus, this means you have to flash the phone.
Best regards.
Feb 19, 2010 | Nokia N70 Cellular Phone
Screen stays red
If you mean the bottom screen, replace it. If you mean the top screen, replace it.
Apr 22, 2009 | Nintendo DS Lite Console
My screen starts going white at the bottom and works up the screen untill all white. I turn the moniter off and on again and it works for a few minutes then does it again.
hello :-) I am guessing that its your screen's problem of what is happening not the computer's. If you want to make sure that its the screens problem look down at your computers tower ( while this white screen problem occurs)  and see if the little orange/yellow light is solid ( that represents the processor ) . If the light is solid that means that it might be the computers problem. but if it isn't solid that means its the screens problem. I would recommend trying a older screen ( you or a friend might own ) and hook that up to your computer/tower if the screen doesn't do what you are describing in your problem that means that its the screen's problem and that you need to buy a new screen.
Jul 10, 2008 | Computers & Internet
Black lcd screen
Does the phone still work? can you make calls? If so, yes, a screen replacement will work.
A white screen usually means no signal is being received by the screen. A black screen means the lcd back light probably died.
sidekick LCD screens
Jan 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
DeLonghi PAC L90 Portable Air Conditioner Logo
19 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
