Infra Rede Codes Recording
Need to record several I.Red codes from TV , Ar conditionig,Remote Controler .
  • 4 Answers
Yes
Posted on Jul 24, 2013
SOURCE: i need the list of 3 digit codes for tv,vcr,dvd, cabl
rt76
Posted on Jan 03, 2008
  • 2427 Answers
SOURCE: Remote codes
for universal or supplememnrt
please supply the remote bran and model you are looking for..
Posted on Jan 27, 2008
SOURCE: Need code for Viore TV to program LG RC897T DVD/VHS Recorder
If your oneforall remote didn't come with the page that gives you the set codes, you can try 991 as the code. So in this order ;
Press tv, wait fir it to blink
press 9 9 1, then power
(it should blink again)
press tv again - it should set
***IF THIS DIDN'T WORK***
SLOWLY press power, then tv, wait,
then power, then tv, wait,
After several times it should set.
(Each time you do this, it tries yet another code to set)
Posted on Jan 14, 2009
SOURCE: need remote control for LG dvd/vcr recorder..misplaced code sheet
Code numbers of controllable TVs
If more than one code number is listed, try entering
them one at a time until you find the one that works
with your TV.
Manufacturer Code Number
LG / GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
Posted on Apr 06, 2009
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Posted on May 30, 2009
Remote control will not turn of a/c
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Oct 11, 2015 | Televison & Video
Correct code for universal remote will not turn off tv. On the 50" digital led model ELEFT502. Original remote always had a weak signal worked only when pointed a foot away from infared reciever. Then quit...
No universal remote control will work with any TVs as well as the original ones. If the original remote control do not get range, there are two reasons for it; and can be repaired to.
1. Battery weak [Replace with new batteries]
2. The infra-red light emitting diode at the front of the remote control is weak.[Can be replaced with a new one. It can be bought from most of the electronic spare part selling shops]
Feb 06, 2015 | GE Televison & Video
My Thomson digital tv recorder 500GB DT16021TUT is not taking commands from remote control after freezing when trying to set timed recording
First of all, check the remote control handset for its infrared emission. If found OK, try a reset to this set, and check further. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked above.
Jan 30, 2015 | Thomson Televison & Video
Need Remote Controler Codes to set TV Toshiba Model TP61H60? ALSO, NEED remote Codes for RCS Remote Controler to set TV as backup till my New Toshiba Remote Controler arrives, please help Thanks.
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 25, 2014 | Televison & Video
Need Remote Controler Codes for Toshiba Remote for Toshiba Model TP61H60 a 1998 Big Scrren
Your Toshiba remote should have the necessary codes to control your Toshiba TV unless one is much older than the other.
If your RCA remote is programmable, you can use its "code search" feature to find an applicable code or codes. If a complete search of all codes stored in your RCA remote fails to find a code, you may have to try another programmable remote or simply wait until the replacement Toshiba remote arrives.
What is the code for a yamaha dsp -ax 620receiver codes
PS3 BD remote is Bluetooth, not infra red. Bluetooth and Infra red are two different ways of transmitting signals. They are not cross-compatible. So there's no code to allow a PS3 BD remote to operate any Infra red device becuase the PS3 BD remote does not issue IR commands.
Aug 17, 2014 | Audio Players & Recorders
Remote does not respond to any function, tv is on and cannot change chanel or anything, frozen
you need to check the battery contact with the battery terminal make sure that the terminal is clean.
check open the cover of your remote and check the solder of the battery terminal from the pcb board use a soldering iron resolder it.
using your cellphone camera test the infra red emmision of your remote control aim the camera to the infra red of your remote.you must see at the screen of the camera that the infra red is lit when any button is pressed..if not the infra red is busted.
using your cellphone camera again to test the infra red emmision of your TV. Aim the camera to the infra red of your TV.you must see at the screen of the camera that the infra red is illuminating.if not the infra red sensor of the TV is busted.
Jun 21, 2011 | Universal Remote Control MX-3000 LCD...
My tv will not pick up any universal remote codes plz help
No one can help you with this if you dont specify the TV brand. If the codes that came with the remote don't work on the Tv there may be other factors assoiciated with the problem. Eg Infra red eye is damaged on the TV
Aug 01, 2009 | Televison & Video
I need codes For my Remote Control
PHILIPS ..... 002 009 109 202 209 210 310 402 408 508 510 807 901 914 917
These are the codes I have located for your universal remote (philips) I sure hope this is of some help.
May 11, 2009 | Televison & Video
Tv won't operate off remote control
Unless you had the remote tested by Samsung, the test isn't comprehensive; it will only tell if the remote is putting out infra-red of some kind, that type of tester cannot determine if the codes are correct or complete. The only true test would be one in which you had a second TV or a second, known working remote. Even using an oscilloscope with an infra-red detector wouldn't help unless one had the specific code sequences available, it would only appear as a pulse train.
Aug 18, 2008 | Samsung Remote Control
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
