Question about Haier HLP21E Top Load Washer
Water is running out of the hose - Haier HLP21E Top Load Washer
  • 35 Answers
What hose? Intake or drain hose?
If the drain hose makes sure you follow the user manual and set the drain end to the proper height. If it is too low you will not be able to fill the washer. It will just continue draining.
Posted on Oct 15, 2013
How to flush coolant from a 2003 holden vectra zc
Disconnect upper and lower radiator hoses while vehicle running. Insert water hose on upper hose and let it run water until you no longer see coolant coming out. Remember to have heaters running to also clean heater core.
Once clear water comes out of lower hose, turn vehicle off and re-attach both hoses. Fill with proper coolant and run vehicle with heaters on. Take for a drive to remove any air from system. Then top off with coolant.
Dec 07, 2016 | Cars & Trucks
How to flush a radiator in a 1998 ford expedition
Depends whether a problem is suspected or whether the radiator is definitely the cause of the trouble.
Flushing a radiator requires it to be no worse than moderately blocked because without reasonable water flow flushing is doomed to failure and even then it is nearly impossible to clean the interior of a radiator without taking it apart and rodding out the tubes or using either an acidic or a caustic additive.
Flushing the old coolant out and a small percentage of sludge is as much as can be accomplished unless an additive is used and even then with variable success. I do this by disconnecting the heater outlet hose and fitting the (turned on) garden hose to it and then running the engine until the water runs clear. Once this is done I transfer the garden hose to the top of the radiator (top hose disconnected and plugged) and also plug the disconnected heater hose. Start the engine and run until the water runs clear from the heater outlet.
A more thorough cleaning will require the radiator to be removed and laid flat on the floor. This is definitely a kill or cure process but no less risky than using a caustic additive.. The results are usually quite impressive but beware - you and anyone nearby is likely to get wet.
I have the poor-man's pressure washer, officially entitled a water-air gun, but as long as the radiator is filled with water and water is running through it and the inlet is sealed apart from the water-air gun or other arrangement that allows compressed air to be introduced into the filled radiator while water continues to flow will have the desired effect. I kneel on the radiator to keep it stable and sometimes I feel it grow under me when I give it the full air tank pressure.
If it breaks, the reason is it wasn't much good in the first place...
May 08, 2016 | Ford Cars & Trucks
Get water to run through inlet hose
Remove the hose.
Turn the water on very gently, having put a bucket underneath the pipe. If water then flows, there is an obstruction in the pipe. If there is no water, then maybe the pipe has been disconnected or the valve has stuck.
Jan 30, 2015 | Washing Machines
Unit keeps cycling off and on with the "bucket full" light blinking
It appears as if the water may not be flowing through the hose.
* When you use a hose the unit must be located near the drain. If the hose is to long the water will not flow freely and cause the water to back up in the hose triggering the bucket full.
* If the unit is lower or the hose runs up hill even the slightest incline will cause the water not to flow backing up to the machine
* Hose must remain flat and in a down hill flow to the drain if you are running a longer hose than recommended. If you are have a long distance to run the hose elevate the dehumidifieer by placing it on a stand, milk crate, anything that will hold the unit. Be sure it is large enough and strong enough to support the unit to prevent it from falling. This will help siphon the water from the unit and prevent any water to back up the unit.
* If your using an old hose make sure there are no kinks and water flows freely through the hose. Any kinks or type of pinch in the hose will cause the water to back up
I hope this helps resolve your issue. This is the most common mistake when using a hose.
Nov 30, 2013 | LG Dehumidifier LD650EAL
Water will not flow through the radiator
take off upper hose -run car drain fluid-when draining stops add water hose to radiator top- run clear water out for 5 minutes-temporarily re-attach hose run for 3 minutes-open hose and let drain again for a few minutes with water hose inserted-take out hose and drain-do not let engine get hot-spray off front of radiator-reaatach hoser and top off at least 1 gallon antifreeze.
Sep 16, 2010 | 1997 Cadillac DeVille
2001 kia sportage is over heating but has no leaks. the radiator has been flushed but is very rusty inside. The water is rusty inside the radiator. We have checked the resevoir, it is fine. the water...
Rusty is from running a bad or no mix of coolant. (PH level is off) You may have a water pump that has corroded impellers, and can't move the coolant as well any more. I would start by making sure to flush the engine block again, and make sure you flush water through every possible hose, and where you can get at it.
Jun 14, 2010 | 2001 Kia Sportage
Whats the hose assembly running from the water
that would be your heater core hoses
and if I remember correctly the aftermarket parts are cut-to-fit and the factory parts are only available as an assembly
May 20, 2010 | 1999 Mercury Sable
No water going through the heater hoses.
I would assume the water pump blade,on the inside,has come off,the car should be running hot also,if not,run a water hose threw the heater hoses to clear it out.
Jan 16, 2010 | 2000 Saturn SL
Cold water run into washer slowly. Pull off cold
water may flow fine through the hose itself, but you prob. have a damaged water inlet valve on the washer.. ( what the hoses are conected too... hope this helps...
Oct 27, 2009 | Washing Machines
Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Apr 11, 2009 | 2002 Chevrolet Suburban 2500
Haier HLP21E Top Load Washer Logo
46 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
