Magnavox ps3 how can i get my ps3 to work?
  • 3,799 Answers
Plug it into the mains socket and connect it to your display, then press the PS3 power button, Followed by the Display power button. Job done.
Posted on Jul 24, 2013
I cant get my ps3 to connect to the magnavox t.v. in my hotel room
are you using the standard playstation to rca jack, if so it should have no problem connecting to the tv rca inputs unless your in the usa visiting from germany, or england or something, and the ps3 wouldnt care if that was the case because that connection is an output only your ps3 has no idea what your connecting it to. that 'does not support format' message has to be about something else
Mar 10, 2013 | Magnavox Televison & Video
Magnavox 42" plasma no picture or sound when hooking up ps3 to hdmi
try to adjust your resolution to the highest level, ps3 is a very high grapics device..
thanks.
Dec 05, 2012 | SNK Televison & Video
Will PS3 damage
No, the tv accepts the standard signal that the ps3 delivers.
Jul 16, 2011 | Philips Magnavox 13MT143S 13" TV
Can't get the play station to work with the tv. The av is plugged in correctly and the ps is turned on. Don't know which channel to go to, and when EXT we tried all different inputs and it still doesn't...
Which generation playstation are you referring to The PS2 or PS3. The PS2 would be connected with a composite cable by default i.e red white and yellow cable. Connect the cable to the corresponding input on the TV, match color codes. Switch to correct input by using your remote controller. Press the AV button and a list of inputs come's up.Select av1 or av2 and check if you get a picture. If you use a ps3 then same as before press AV button on remote and select appropriate option on screen HDMI,Component or Composite.
HDMI looks like this
Component
And Composite
Jan 16, 2011 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Hdmi from PS3 doesn't get picture or sound on magnavox LCD TV but worked for the last 6 months fine.
If the video output settings on the system do not match those of the
cable or TV in use, there may be no picture. If the screen goes
blank, turn off the system. Then, with only the system and the TV
connected, press the system’s power button for more than 5
seconds to turn the system back on. The video output settings will
automatically be reset to the standard definition (SD) resolution.
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
I have a RCA Universal RCU430-needcode for Magnavox TV
Code 000 for Magnavox TV Code 004 for Magnavox TV Code 006 for Magnavox TV Code 008 for Magnavox TV Code 019 for Magnavox TV Code 062 for Magnavox TV Code 068 for Magnavox TV Code 069 for Magnavox TV Code 075 for Magnavox TV Code 076 for Magnavox TV Code 077 for Magnavox TV Code 088 for Magnavox TV Code 130 for Magnavox TV Code 132 for Magnavox TV Code 133 for Magnavox TV Code 134 for Magnavox TV Code 183 for Magnavox TV Code 219 for Magnavox TV Code 235 for Magnavox TV
Jun 03, 2009 | RCA Universal Remote Control
I want to connect my ps3 via hdmi cable to my magnavox 51mp392h/17 hdtv but theres no hdmi jack on my tv what to i do?
If there is NO HDMI on the TV, There are 2 options to still get HD. 1. Check if your TV has a DVI input, If it does you need a DVI to HDMI converter. This can be a problem with some TV models it might not sync up 100%. 2. I recommend doing this, Purchase the Component Cable For the PS3 from Best Buy or any Game store. Make sure it is the ONE for the PS3!!!!!!!!!!!!!! This cable will give you up to 1080i resolution and stereo Audio. Plug in the Red, Green and Blue into the Component (R,G,B) Input in the TV, The Red and White (audio) will follow into the same Input (White and Red) just match the colors from the cable to the TV. On the PS3 in the Menu go to the 2nd row from the Left and down to DISPLAY SETTINGS. Select Component (under HDMI) check off everything except 1080p and then SAVE by pressing X. If you have a Receiver (AMP) that your Audio goes into, Then you can buy an Optical Cable for Surround Sound. Plug in the Optical cable then on the PS3 go into the menu, 2nd row, Sound Settings, Choose Optical, Then choose Auto and SAVE! Hope this will Help!
May 04, 2009 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
