Question about Samsung Dryers
Dryer won t stop running
Dryer continues to run. No lights on display. Every time door shuts dryer comes on.
Try this video about door switch repair. http://www.youtube.com/watch?v=r47mDJ2MqtU
Posted on Jul 24, 2013
  • 1028 Answers
SOURCE: Whirlpool commercial gas dryer
replace push to start switch
Posted on Aug 30, 2008
  • 1122 Answers
SOURCE: Kenmore 110.96588210 Electric Dryer
you can take the top panel back off and check the start button with omes meter,push button in you should get a reading,let button out no reading ,if it fails the test replace,let me know what you find
Posted on Sep 22, 2008
lenwest
  • 150 Answers
SOURCE: Whirlpool duet electric dryer - drum turns; no heat
Turn off the breaker and check the heating element.
for more help go to live chat.
hope this helps
len west
Posted on Jan 30, 2009
jumptrout51
  • 3361 Answers
SOURCE: Maytag dryer timer keeps running
Your dryers timer contacts have fused to gether.
The only repair is to replace the timer.
Posted on Mar 25, 2009
SOURCE: I have a Frigidaire Gallery Electric Dryer Model #GLER642AS3
The identification label from a Frigidaire Gallery Commercial Heavy Duty Moisture Sensor drier has come off. I need to download operating/user manual. How can I get the serial no. or model no. The drier is 4 years old.
Posted on Jan 17, 2011
Dryer won't turn off
Relay stuck closed in control circuit, usually the door interlock. Slam the door shut a couple of times to see if it frees the contacts.
May 15, 2012 | Washing Machines
DRYER WILL NOT SHUT OFF. CONTINUOUSY RUNS AND IS OVERHEATING.
The control board regulates the timer functions, yours may have failed
Nov 11, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My dryer stopped drying and the timer quit all at once... is this 2 random problems? or
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a broken door latch, a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad
Oct 27, 2009 | Kenmore 63942 Dryer
Maytag performa just stopped in middle of cycle and won't start
If a dryer is not working at all that's not good! But it doesn't mean you need to go appliance shopping just yet. It may be something very simple like a bad door switch or even a broken door switch actuator, in a kenmore dryer there is a tab thats sticks out of a hole in the wall that allows the dryer to run only if the door is shut, other models may have button that protrudes out of the dryer and when the door is shut, this allows the dryer to run. These switches go out from time to time, also if a dryer is full of lint build-up over time this will cause the dryer high limit or fuse to blow. The fuse is located near where the blower is in most cases. When the air in the dryer gets way too hot the fuse/hi-limit will blow and the house wont burn down.
Sep 22, 2009 | Zanussi TD4112W Electric Dryer
Whirlpool LER8620 electric dryer, shuts off at random. When it
Whirlpool Dryer Won Start
Sounds to me like a thermal fuse. The link gives you multiple scenarios and you can even order replacement parts. I have used it myself with success on washers and dryers. Good luck!
Sep 13, 2017 | Whirlpool LER7646E Dryer
Drum runs continuously
Sounds like you have a shorted relay in the door switch. If you know a good electrician or repair man I'd give them a call.
Nov 16, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Aug 29, 2008 | Whirlpool Dryers
Dryer won't stop running
the dryer wont stop running only when open door will it start a fire?
Sep 14, 2007 | Kenmore 62802 Electric Dryer
Dryers Logo
462 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
