Question about DISH Network Televison & Video
Box keeps turning on then after 5 seconds it turns off
All plugs are plugged in.
  • Official Brand Answer
  • 263 Answers
Ryan, it sounds like there is a power problem going on with the receiver. In most cases we would have to replace the equipment, though there are a few things we can try first.
If the receiver is plugged into a power strip or surge protector, try bypassing that and connecting directly into the outlet. If it is already plugged into the outlet, try a different one if possible. You can also try unplugging it for about 15 seconds then plugging it back in.
If the problem persists, email me at thomas.faust@dish.com and I would be happy to see about getting a replacement receiver out there.
Tommy Faust
DISH Social Media Representative
Posted on Jul 25, 2013
Dishwasher go,s on and on. Two lights flashing . Help please
Try unplugging the unit for a few seconds then plug back in to reset the circuit board. If you can't get to the plug then go to the fuse box and turn of circut breaking leading to the dishwasher for a few seconds then turn back on.
Sep 20, 2014 | Washing Machines
HDCP AUTHORIZATION FAILURE- HDMI PORT DISABLED
i just had it happen half hr ago and pulled power cable out of box for few seconds and plugged it back in...turned it on and it basically reset itself works great now
Apr 15, 2012 | Televison & Video
I cant use my controler because the green part keeps bliking and wont turn on so i cant play my xbox 360
I had this exact same issue the other day. Changing the batteries did not work for me, but don't cross that off of the list quite yet. This worked for me:
1.) Pop the battery pack off of the controller. This is the only way you're going to be able to turn it off. Wait about 5 seconds and put the battery pack back into the controller.
2.) Turn on your X-Box with the power button ON THE CONSOLE. It should turn ON. If it doesn't, unplug the X-Box for 30 seconds, plug it back in, and try again.
3.) When your X-Box turns on, go ahead and hit the controller's power button. Things should function normally from this point forward.
Please let me know if this works for you!
Sep 30, 2011 | Microsoft Xbox 360 Controller
My gateway profile 5 won't turn on. Checked plugs
Try to power drain it. Unplug all the power related devices that are connected, like a monitor data cable or external printer, just unplug all the cables in the back after you shut down your computer, press the power switch of your computer and keep it pressed for about 45 secs, release it, plug everything back and check it if its working. As well double check if that particular socket is usable, plug something else in to see if its working.
Jun 30, 2011 | Gateway Computers & Internet
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
2003 saturn vue service light on with wrench how do I reset
Open the hood. You will notice there is a large black box on the right-hand side directly behind the battery. This black box is the fuse box. Pull the top of the fuse box off. There are two clips on either side; once you pop one side, the other comes off very easily. In the top left-hand side of the fuse box where all the fuses sit, you will see a large orange/red block. Below this block is a button that says "reset." Press this button for 5 seconds. Turn the car on and wait for a minute. If the light does not go on, turn off the car and set the key to ACC on the key ring. Push the reset button again, holding it for a total of 15 seconds. Turn the key to off, take out the key, return the key and start the car again. Allow the car to run for 2 full minutes. It is taking the system a few minutes to register that this button has been pressed.
Sep 01, 2009 | 2003 Saturn VUE
Some popups all of a sudden were saying that i needed to download their programs or i was under attack by many viruses and when i said no to the downloads then my computer just shut down and will not even...
First and simplest thing to try is make sure printer, monitor, and anything else attatched to your computer is turned off and the main box (of course. switch off at the socket and remove plug-plugs
next check no wires have come loose in the back of your computer- leave for a few minutes (go and make a cup of tea, coffee whatever) plug something else into the socket like a radio or hairdryer to make sure a fuse haasn't blown or something.
plug everything back into sockets switch plugs back on, turn on monitor and other bits and bobs but leave the main box till last switch this on and hold the button down for about the count of 5, and hopefully all will be well. Good Luck
Nov 26, 2008 | Computers & Internet
Lexmark poering out!
sounds like either a bad internal control board, or a bad power supply..power supply is easier to check..voltage needs to be as specified on back of power unit
Apr 29, 2008 | Lexmark X5470 All-In-One InkJet Printer
My TV won't turn on. The Green light just keeps on flashing
1. Check for no 8.4 volts DC at pin 3 of PC9A10 on the Power PCB, if low or missing replace PC9A10 part # 268P058020. 2. LED does not blink at plug in. Check for 3.3-volts DC at connector RF pin 3 (system reset) if low or missing suspect the reset switch S7L20 part # 432P109010 on the Control PCB. 3. LED does not stop blinking after plug in. Verify the standby supplies, 12-volts at connector KA pin 17, 6-volts at KA pin 18 and the 28-volts at KA pin 19, if the supplies are present suspect the DM PCB part # 934C067002 4. LED does not stop blinking after plug in. Check C9B01, C9B02, C9B10, and C9B11 (1000 UFD 16) on the DM PCB, if they are bad replace them with part # 181P734030 (680 UFD 16 V). 5. LED stops blinking after 70 seconds of plug in but will not power on. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds 6. LED stops blinking after 70 seconds of plug in but will not power on. Check for 3.2 volts DC at connector RF pin 4 and 5 on the Signal PCB if low suspect problems with the switches/buttons on the Control PCB part # 935D736001 7. LED stops blinking after 70 seconds of plug in but will not power on. Keyboard is not locked and key inputs at connector RF pin 4 and 5 check good suspect the E2P PCB part # 934C061001
Jan 30, 2007 | Mitsubishi WS-73713 73" Rear Projection...
Televison & Video Logo
150 people viewed this question
Top DISH Network Televison & Video Experts
brian soufane
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
