Question about Balance CM2017 17" Monitor
Balance monitor all color flushes and flashes with pic host link
Sorry this will be long but I want to give enough details. I have used this BALANCE CM2019 monitor on two different systems and it has showed the same problems. The first system was windowsXp Pro with a NVIDIA 6800 oe graphics card in a desktop tower with plexiglas side door sitting next to the monitor. The 2nd system is the same type plexiglas door tower running Vista Ultimate, duel core SLI and running a monster NVIDIA GeForce 8800 GTX The monitor is plugged into the GeForce 8800 graphic card using a DVI to VGA adaptor. The old first tower is now sitting over on another computer desk in the same position to a different monitor and running just fine. I only mention this because I thought I was getting some interference from the plexiglas door towers being close to this balance monitor but that can't be since I am having no issues with the old system in the same position on the other desk. The towers are identical models. I am beginning to think that I should just get a new monitor as this cheap one seems to be unfixable. I have set the monitor settings to what the manufacturer suggested and the refresh rate and I have made sure the graphic card is also set for the monitor specs. Here's a picture online of the login icon on the starup screen, I am using the bonzi icon but it is hard to tell. http://www.photolava.com/code/5y66.html Any help or idea would be appreciated! VaL in Texas
  • texasoasis Aug 30, 2007
    I am pretty sure your right, that was what I was thinking and having a second opinion is what I needed.
    I will start shopping for a new monitor, I don't feel like hunting down a replacement lcd.
    Thank you jmorgan123,
    VaL
    President:
  • 317 Answers
Sounds like the lcd on your monitor is bad. This link shows how to replace one: http://www.fonerbooks.com/laptop_4.htm The link shows a laptop, but it's pretty much the same as with your monitor. The hard part is finding a replacement lcd to put in there. My advice would be to buy a new monitor.
Posted on Aug 29, 2007
When i take pictures they show with a pink color? i reset the camera to factory settings but still same pink pics advise?
This FE-340 Olympus is a great camera. Lots of features and usually great results
  • Indoor pictures with flash set on auto WB (white balance) should not be a problem
  • Indoor pictures without flash requires setting the WB to match the light source in the room (incandescent, florescent etc) Outdoor pictures WB on auto generally not a problem
For more help Include a photo with the metadata of the photo from the image data file
Dec 02, 2015 | Olympus FE-340 Digital Camera
How do I adjust the color on monitor?
Instructions
  1. PC Monitor
    • 1Check the color balance options on your monitor. Typically, there is a button on the monitor itself that can be used to enter the Settings menu and configure color. The color balance may have somehow been changed, resulting in the pink image.
    • 2 Calibrate the color system for your monitor through Windows. Press "Windows-X" to open the Power User menu and select "Control Panel." In the Search bar, type "calibrate display" and click on "Calibrate Display Color" when it shows up. Provide your administrator password or confirmation if prompted.
    • Sponsored Links
    • 3 Check to see if the cable connecting the monitor to the computer is loose by lightly jiggling the connector at both points. If it's loose, this could be the cause of the display error. Secure the connection and see if the issue has cleared up.
    • 4 Check the connectors themselves for bent or damaged pins. A damaged pin can cause a faulty connection, which can lead to errors like a pink-tinted screen. If the pins are just bent, you can try to bend them back into place with a pair of needle nose pliers. If they are otherwise damaged or missing, you'll have to replace the cable itself.
    • 5 Perform a factory reset of your monitor if replacing the cable has not repaired the issue. Instructions for a factory reset vary from one model and manufacturer to the next, so consult your owner's guide for detailed instructions.
    • 6 Connect your computer to a different monitor if the problem persists after factory reset. If the problem persists with a new monitor, the issue is likely with your video card. If this is the case, consult the card's manufacturer for detailed diagnosis and assistance. If not, your monitor may be damaged and incapable of rendering a properly colored image. Take it to a repair professional for repair or replace it.
Read more : http://www.ehow.com/how_8446307_fix-color-pink-hue-everywhere.html
GOOD LUCK.
May 11, 2014 | Acer V193w LCD Monitor
FUJIFILM FINEPIX T400 COLOR NOT BRIGHT ENOUGH
If it's a green cast, try adjusting the output (if such a command exists). Or, if there is a toggle for PAL or NTSC. You may need to change that.
Nov 25, 2013 | Fuji FinePix T400 16.0-Megapixel Digital...
I have a lumix, model no dmc-fs15, and the photos keep coming out red. What could be the problem?
Hi Joanne:
You can check menu settigns there? This pics/videos this appears under red color in the pc monitor after transference or download pics/videos at pc? If your answer is yes, your problem isn't a LCD problem.
The other choice, could be a malfunctioning CCD (Charge Coupled Device) image sensor... in both cases (LCD or CCD) this isn't a job that you could solve yourself; this wrong include distorted images or abnormal colors, scratchy purple lines, blank or black pictures, and/or black videos with good sound being recorded on the camera's flash card.
I suggest check this link for additional details in this previous solutions for an Defective CCD and next contact your Panasonic service. Additionally,
I strongly suggest (taking into consideration the age of your camera) to evaluate the cost of repair versus the cost of a new camera with similar features, before making a final desicion.
In order to correct this issue, the repair facility needs to replace the CCD. Check this links that could give you additiona details: imaging-resource.com/badccds
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 18, 2011 | Panasonic Lumix DMC-FS15 Digital Camera
I am not getting the correct colors from my SLR camera. Is this due to my computer monitor?
Yes, the monitor need to be calibrated using an optical attachment (looks like hockey puck) that is placed on the screen using software, but the monitor must support automate software calibration. You can google for LCD monitor color/white balance calibration tools.
Apr 07, 2010 | Balance CM2019 19" LCD Monitor
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
LG Flatiron monitors.1st one on Dell pc works great. 2nd one in same household to Compaq pc still flashes faint pink on parts that should be white.
Probably just some color balance is of. Reset white to something different on the compaq. Try downloading nvidia-settings and see what happens when you mess with color balances. Mess around with some settings til it looks right, or see if you can reset the white balance to a different preset on the monitor's menu
Oct 26, 2009 | LG L1920P 19" LCD Monitor
Is full EXIF available for W1? Menu Items
You might try the free exif viewer: http://www.opanda.com/en/iexif/index.html Once installed, just Right Click on your image and select View Exif
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
White Balance
What is White Balance? The human eye captures white as white, red as red and blue as blue, regardless of whether you are outside under the sun or inside under incandescent lighting. Although this is something that we take for granted, the human eye actually adapts to correct the changes in color under different light sources. In reality, when light sources vary, colors caught as the reflection of those light sources also vary. For instance, films for cameras that use film are designed to capture the most appropriate coloring outside under the sun. Thus when you take pictures under incandescent or fluorescent lighting without using a flash, the colors in the resulting picture may seem strange. Digital camera and digital camcorders are equipped with a handy feature called "White Balance" that corrects the changes in color under different light sources, just like the human eye. One of the white balance settings, "Auto White Balance" (AWB) automatically adjusts to correct the changes in color under different light sources. White Balance and Coloring The White Balance feature on Canon digital cameras and camcorders is set to "Auto White Balance" at the time of purchase. If you prefer different coloring, if you want to adjust the coloring more in detail, or if you want to change the coloring on purpose, we recommend that you change the white balance setting.
Sep 04, 2005 | Canon Optura 500 Mini DV Digital Camcorder
White Balance
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Balance CM2017 17" Monitor Logo
173 people viewed this question
Top Balance Computers & Internet Experts
Jaime Hernandez
Steve Allison
Steve Allison
pankaj rautela
pankaj rautela
Are you a Balance Computer and Internet Expert? Answer questions, earn points and help others
