Question about Hunter 54"" 1912 Mission 5 Blade Ceiling Fan"
Reverse hunter mission fan
I need to reverse direction on the fan but controls show no such operation.
    New Friend:
  • 3 Answers
Need to know how to programme carib 880e remote
Posted on Jul 24, 2013
Lights come on at random .has a remote how to fix ?
The fan remote control receiver used in the Hunter 25730 model fan (see picture) is not available from Hunter. Remove the fan from the ceiling. Remove the receiver and take it to recycling. It can be replaced using a readily available and inexpensive replacement universal remote and receiver controller. There are limitations though. The Hunter receiver provided fan reversing functions. The universal controllers do not. You therefore have two options.
Option 1: The universal receiver can be installed such that the fan direction is fixed, either up or down, all other functions operate normally.
Option 2: A reversing switch can be purchased from Radio Shack for about $4 and installed in the fan. This does require cutting a square hole and drilling two bolt or rivet holes in the side of the cylindrical housing which previously housed the Hunter receiver. I'd suggest the Radio Shack DPDT slide switch part number 275-403.
Refer to the wiring diagrams and connector pinout diagram for connections. Please note that the connector pinout diagram is the connector that is soldered to the circuit board as shown in the photo of the Hunter receiver. If your motor wire colors are different then with the connector unplugged from the receiver use a multimeter to probe all the motor wires in order to identify two pairs of wires that indicate approximately 70 ohms each pair. These will be the motor windings. 6b0a1409-5a20-4efe-a059-c600652e9512.jpg 5da8e4ef-1b54-40d0-a8a4-21d4608b1d23.jpg 9fc8772d-3ac3-41b7-aa55-78ccc6e5ea00.jpg 0759e340-6464-4c4b-90f5-6d9926e74e42.jpg
Jan 23, 2014 | Hunter Ceiling Fan Light Remote Control
Wall switch control not working
Fan speed and light intensity are controlled by the remote as indicated in the instructions for the fan.
Dec 12, 2013 | Hunter 1912 Mission 21978 Ceiling Fan
Hunter ceiling fan 22450 no reverse switch manual says there is.
The reverse switch usually is in the lamp housing directly under the motor. With a vaulted ceiling installation, you would need to use a ladder to get access to the switch
Jan 04, 2013 | Hunter 52" Ceiling Fan With Light And...
Hi I need to know if I can switch the direction my hunter green Lasko fan is turning it is going clockwise and I would like to reverse it for the summer can't find a switch we've have it for...
Turn the fan off. Locate the reversing switch. It is on the base of the fan near the fan speed and light switches. if its not on the remote control. have a good day !!
If it does not have a revesing fan switch and its older, You may have to physically(with fan stopped)
Push blade in from end and twist blade for reverse air.
Jun 22, 2011 | Hunter Traditional Southwest 52" Ceiling...
Just installed a hunter 27227 remote for use with my Hampton Bay fan. The fan was electronically reversable via a F/R switch on the old remote. Everything is working great except that the thing is running...
I recently had Hampton Bay fans installed with the Hunter remote and the electrician showed me that there is a small switch on the fan and you turn it either up or down depending on whether it's hotter months or cooler months because it changes the direction of the airflow to cool down a space or help spread heat. That may be what your issue is-- it's probably set to help spread heat rather than cool things down. I hope this helps!
Apr 19, 2010 | Hunter 27185 Remote Control
Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
Jul 21, 2009 | Hunter Ceiling Fan Control Switch
Cannot change the direction of my fan...
Your reversing button for that particular model is on the remote control. There is no button on the fan body itself.
Jan 03, 2009 | Hunter (25417) Ceiling Fan
Hunter Bayport Fan
You need to get the running capacitor replaced then it will work fine and its a very low cost part.
Jun 16, 2008 | Hunter 20404 The Bayport Bright Brass...
Hunter 54"" 1912 Mission 5 Blade Ceiling Fan" Logo
145 people viewed this question
Top Hunter Televison & Video Experts
pblo
Level 1 Expert
Paul Bade
Jim Goldsmith
Jim Goldsmith
Are you a Hunter Televison and Video Expert? Answer questions, earn points and help others
