ASUS laptop keyboard "insert" key not working
Pressing the Insert key itself won't work. I tried to follow the common way to press the fn key at the same time and it still won't work.
SOURCE: keyboard problem
I've been looking for the solution for an hour till i found it. it's so simple it makes me feel like an idiot. You just need to press numlock (Fn+F11) to solve the problem :)
good luck
Posted on Jul 30, 2009
SOURCE: my laptop keyboard is stuck using the Fn keys
is your number lock on? if it is turn it off and everything should be fine...
Posted on Dec 07, 2009
  • 4 Answers
SOURCE: How to control Asus A6R Fn keyboard? when I type
It looks as though you have Numbers Lock turned on. On my Asus x58C this is tuned on and off using the blue Fn and NumLk keys. When its turned on there is a padlock symbol located above the keyboard which is lit. If it is, then hold down Fn then press NumLk and it should turn off. Hope this helps you
Posted on Feb 14, 2010
SOURCE: I just got my asus G73Jw, and my keyboard dosen't
SOLUTION by Arun Sangal
1. As said by others above, if its just that you have turned the lights completly off.. then press "Fn" key + F4 key (keyboard light increase) button.
2. If the above doesn't do anything or-- if Fn key + any other F? key (like F11/F12) for sound decrease/increase don't do anything ... meaning your FN key driver is messed up, then dont worry, See Hannah Montana and relax.
After seeing it, go to your computer desktop, there you'll see, "e-driver" shortcut/icon. Click it and you'll see a new pop-up window. In this windows, ASUS various ACPI/etc drivers will "AUTOMATICALLY" download (provided you are connected to internet) and it's fast.
I did the same, and system automatically restarted/rebooted during the "e-driver" update process. Finally I restarted my system/laptop (G873JW) and "HOLY HYENAS".... my system is running like a pony ***. AWESOME, it worked for me and my problem got resolved.
NOTE:
1. In case you dont see "e-Driver" icon on your desktop, then usually the file is stored at "C:\eSupport\eDriver\InstAll.exe" on my laptiop. Try runing the above file from "Windows" command prompt or double clicking on this file by going to "C:\eSupport\eDriver" folder and double clicking on "InstAll.exe" file.
GIGA, you should be good to go with this FN problem on ASUS G73JW or any other series of laptop.
2. During the update process, if you see "ASUS live update" green color window comes up and starts downloading something, hang on, look at it if it's doing anything, if it does some download and hangs at the particular point (i.e. downloading not progressing), then, you can cancel it. BUT make sure the update pop-up window that came after you clicked / ran "e-Driver"/InstAll.exe file, that should complete successfully.
Good luck.
Once the keyboard "FN" key problem is resolved, then you can go to their site and see if they have any updated version of drivers for your video/blah/blah ... thingies.
cheers, Arun Sangal
Posted on Dec 27, 2010
SOURCE: function keys directly not working
SIR ,
MY LAPTOP MODEL 3000G430 KEY BOARD IS TOTALLY NOT WORKING . KINDLY GIVE ME SUGGESTION HOW I MAY REPAIR THIS PROBLEM?
Posted on Aug 08, 2012
Fn key - how to change
try pressing the "num lock" key. if that doesn't work try taping "fn" key 4 or 5 times to pop up a sticky key option windows. if else is fail try pressing "fn+num lock" key simultaneously.
Jan 09, 2014 | ASUS Computers & Internet
Fn+num lk not working
There is no standard meaning to any Fn +Fx key combinations. It depends on the manufacturer and the laptop model.
Usually the Fn key works in combination with the Function (Fn) keys F1-F12, and maybe ESC.
In my Toshiba, there is an overlaid numeric pad that can be activated by pressing Fn +F11. Once the sequence is pressed the F11 key led remains lit, and the overlay active. Pressing the F11 key restores the normal keyboard. Fn+Num Lock does not do anything.
Please check you laptop's manual to familiarize yourself with the uses of the Fn key on YOUR computer.
Dec 19, 2013 | ASUS Eee PC 1000H Laptop
Asus Laptop Touchpad trouble shooting
Step 1:
Touchpad Not Working in Laptop b> Locate the "Fn" key in the lower right or left corner of the laptop keyboard. The "Fn" key typically has different colored text on it or the key itself is a different color. Locate the function (F1 through F12) key at the top of the keyboard that disables or enables the touchpad on the laptop. The key typically has an icon that resembles a touchpad with a finger touching it or a touchpad with a diagonal line through it. Press both the "Fn" and touchpad Function key simultaneously to reactive the touchpad on your laptop. Move your finger along the touchpad to verify that it works. Press the combination at any time to disable the touchpad again.
Feb 06, 2013 | ASUS Computers & Internet
My keyboard won't light up on an ASIA G73J. I have tried the function keys and they won't work.
Did you hold down the [fn] key, in combination with the function keys? If not, you have to hold down the [fn] key in combination with pressing the function key's that are associated with the keyboard back-lighting (usually [F3] or [F4] on an ASUS G-series).
Aug 03, 2011 | ASUS G73JHA1 Notebook
Keyboard of myASUS K50IJ-XA1 15.6-Inch Versatile Entertainment Laptop (Black) is locked How to unlock the same? Kindly help
Well, do you mean only the keyboard is locked? Can you boot the system properly? Is the mouse working? Which Operating System is running on your Laptop?
Here are a couple solutions you can try before you let me know the above queries.
1. Press and hold down the Windows Logo key on the keyboard while pressing the L key on the keyboard once. In other words, Press Windows Key + L once. If this doesn't work, don't forget to include the Fn key while pressing these two keys. Windows+Fn+L. Still nothing?
2. Turn off the Machine, remove the battery and unplug the charger. Leave it for at least 10 seconds, you can press the power On button on the laptop without the battery and the charger installed/plugged in. Now re-install the battery, and turn back On the machine. It should work.
If you need further help, if the problem persists, Let me know with the details.
Good Luck.
Thanks for using FixYa.
Jul 24, 2011 | ASUS K50IJXA1 156Inch Versatile...
What do I do if my Asus 1005 will type like im pressing the fn key but im not. Im trying to type but the numbers would show up instead of the letters like if im pressing the fn key. I don't know what...
Well this seems to be obviously a keyboard problem, that sort of things happens when the keyboard is extremely dirty or water or other liquids get to the keyboard circuits, there's no practical way to make it work as good as new since it's a laptop keyboard and it's all sealed, there are two options get the laptop to technical service or buy a compatible keyboard and follow this tutorial or this one.
If you have any other problem don't hesitate to ask.
May 09, 2011 | Computers & Internet
Asus netbook type letters it put numbers
This issue is due to you having activated the "Number Lock" function of your keyboard !
To revert to full keybaord function:
Press Fn+NumLock. The numLock shares it's key with Insert
Note: Fn key is the Blue Key at the base left of the Keyboard.
May 08, 2011 | ASUS 90-A4C1K1000 Keyboard
I am trying to use the "insert" key on my asus k52f but can't get it to work. "Insert" is shown on the "0" key, I would think "shift + 0" would be insert but that...
Please check if you have a Fn key in the left side of the keyboard, press that and then simultaneously press the Insert key. Please check if insert is in a different color. All keys or functions present in a different color on top need to be pressed along with Fn key.
If you still face issue please reply to this post.
Thank you for contacting Fixya
Mar 15, 2011 | ASUS M6NE (BBASUSM6NE) PC Notebook
My laptop keyboard not working normally, keys not display the keys i want to type, display the other character on the keyboard...my laptop model ASUS eee PC 1001
This is because you have Num Lk activated.
To deactivate, hold down the Fn key and press NumLk (it's the same key as insert)
Now you will have the normal characters when typing.
Regards,
katharsys_i
Mar 02, 2011 | Computers & Internet
I can't find the "FN" key on my wireless logitech S 510 keyboard
buy another keyboard which have FN key... theres a kind of keyboard that are not using FN key...
Jun 16, 2009 | Logitech S 510 (967555) (DH967555)...
Computers & Internet Logo
143 people viewed this question
David Payne
David Payne
