Question about Garden
Kohler cv725s engine is running rich at idle
Cleaned carb and it runs but runs rich at idle and no adjustment screw.
wadembly
  • 448 Answers
SOURCE: have a 1996 mtd 18.5 hp 46 inch deck riding
it sounds like the needle screw could be bent at the tip if not try turning the screw all the way in & out 1-1/2 turns & try that if i can help further let me know thanks wade
Posted on Jul 05, 2009
backwoodsctr
  • 169 Answers
SOURCE: Kohler engine carburetor adjustment on John Deere Model 112
When u adj a kohler carb you adj fuel not air. Always adj the high speed then low speed. Then adj the curb idle. 1.5 turns out is a good starting point. Then tweak it after its warmed up. Hope this helps
Posted on Nov 20, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Snapper yard cruiser with a 15HP Kohler
Correct that there are no adjustments, but try cleaning the carb jets first, as many times a small amount of debris in the fuel can cause a performance problem. A replacement carb will be close to $200, and NO carbs will be adjustable. A gasket kit is available if you need. Contact your local Briggs dealer to procure the part.
Try cleaning the jets first.
Fuel Starvation - Float Bowl Carburetor
1) remove air filter assembly
*be cautious of tearing the mounting gasket. If it does tear, you HAVE to replace it. It is part of the priming system
2) remove the float bowl fastener. This is the main jet
3) carefully remove the float bowl, the rubber o-ring/gasket will not be able to be used if it is removed, you WILL have to replace it
4) using a spray 'carb cleaner'
spray up thru the center of the carburetor
spray and clean the main jet with cleaner and 'tag' wire
(tag wire is very thin, and can be used to clean the hole in the center of the main jet)
5) clean any debris from inside the bowl or carb body
6) re-install bowl and center bolt, air filter assembly
*if you need gaskets, your Briggs dealer can supply. The kit is cheaper than individual gaskets, and all the parts needed to finish the above repair are in the kit.
Posted on Nov 21, 2009
SOURCE: 14 hp kohler engine (Cv14s 1451) runs good for 5
I had this issue on my 14hp kohler and it was the ignition module. Would run until it heated up then shut down.
Posted on May 18, 2010
suzukiracing
  • 200 Answers
SOURCE: nikki carb runs real lean engine runs rough pops
Try turning the mixture screw up a little or if nothing else ive heard of the plug that goes into the carb nees to have the long needle trimmed to the height of the shorter needle in the plug
Posted on Jul 19, 2010
600 carb. Why is it idling poorly and popping?
Sounds like it is running far too rich. Verify proper spark, verify that the float bowl is not overflowing (replace the float and/or the needle & seat if necessary), and adjust the idle mixture screw clockwise to make the idle mixture more lean. (Many tutorials on carburetor adjustment on Youtube.)
May 23, 2015 | Honda Motorcycles
I need to know the proper tuning of ucal mikuni carburetor with mixture adjusting screw on bottom of cabr (beneath float bowl), an idle adjust screw and pilot screw (hopefully pilot fuel screw since s
Why did you need to clean the carb? Routine servicing of the aircleaner would keep the carb clean for life. The pilot screw should be 1.5 turns out approx. with a small adjustment either way. Idle speed is set to a smooth low idle.If this doesn't fix it have you got something in the carb not replaced correctly? The float needle/float assy? How did you clean it? Have you introduced fluff/dirt into the carb and did you blow it clean with an airline?
Oct 09, 2014 | Motorcycles
How to adjust a carburetor
this sounds more like you need the carb rebuilt to clean out all the dirt in the small passages and replace the needle and seat as well as the float. the idle air mixture screw are at the front of the carb at the base one for each barrel the carb has. this year should have tamper proof plugs covering the mixture screws which the carb will have to come off to remove them.
Aug 28, 2014 | 1985 Chevrolet Chevy
Carb is running rich and dont want to rebuild the carb 4bbl dynaflow
you should be able to adjust the idle screw a quarter turn at a time until it runs
Mar 27, 2012 | Cars & Trucks
328 gts 1986 very rough idle, running rich you can smell the gas from the exhaust . runs fine once the throttle is pressed
you need to adjust your idle screw on your carb i could tell ya how on that type of car but your running to high of an idle and flooding your cylinders thats y it is idleing rough and you can smell the gas, adjust your idle screw back a little and then you might want to check your plugs and make sure you didnt fowl and of them with it running rich
Apr 21, 2011 | Ferrari 328 Cars & Trucks
Unburnt fuel come out of muffler while saw is running
There is a number of reasons why this can happen, running the saw on too rich a fuel oil mix, most modern two stroke oil is ok to run at 50-1, air filter blocked creating over fueling, clean the filter, carb mixture screws set too rich, re set the H screw on the carb, carb flooding due to needle leaking, service carb, ignition system fault, miss firing, replace plug, or ignition unit.
Always try the easy stuff first before fitting new parts.
Jan 24, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a yamaha venture 1986. It runs too rich. My dealer tells me I have to change the diaphragms. Could it be something else ? Thanks THE YEAR IS 1986
Try and see if you air cleaner unit is in need of replacement or a clean .You could try adjusting your fuel adjustment screws but you will need a set off carb balancers ,to do the job properly .
Mar 17, 2010 | 1996 Yamaha Royal Star XVZ 1300 A
Its running too lean..there is a plastic cover over the carb adjustment screws
That may be to keep dirt out. One of the screws should be for the richness setting and the other for the idle speed.
Adjust the richness setting so the tool runs the best (fast) then turn the idle speed down to normal.
Make sure you always keep the air filter cleaned or dirt will get into the carb and cause you to have to clean out the jets in the carb.
Nov 07, 2009 | Homelite Consumer Products Backpack...
1993 nissian p/u run rich and it running real rough
If it is a carb engine have the air fuel mixture corrected by adjusting the screws on the carb. Try also adjusting the idling.
For EFI engines see if you can check the Idle Control Solenoid Valve, have it cleaned. You can also check the oxygen sensor if it is working or not
Jun 04, 2009 | 1993 Nissan Pickup
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
