Question about Drills
My charger for cordless 12 v hitachi drill got wet without realising pluged it into power point it went pop. Is it worth or at all possible to repair
    Top Expert:
  • 51,268 Answers
It will not be repairable as the electronics will be burnt.. Try e-bay for a replacement or get a charger from a dealer or on line from the manufacturer themselves
Posted on Aug 02, 2013
HELP2DIY
  • 12 Answers
SOURCE: Drill battery charger doesn't work
Hi Firemedic13; Most chargers like yours have a fuse inside them. Remove the screws that hold the charger together. The fuse will be on the low voltage side of the transformer. Un-solder and replace it with one of the same value. If the charger is not held together with screws (doubtfull) you will have to carefully cut along the seam where they were glued together. A dremmel tool works good for this. After repairing use some ABS pipe glue to re-seal them together. If the fuse is not blown then the unit will require testing by someone that is proficient with a multimeter. Most times it is the transformer that has fried a wire. If the sides of the transformer have any burnt spots on it then it will be the culprit. Hope this has helped. Best regards; HELP2DIY Please dont forget to rate my answer.
Posted on Jul 10, 2007
SOURCE: bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Posted on Jan 31, 2009
SOURCE: Kawasaki 19.2 cordless drill
Re: Burned trigger switch: call the number on the drill (800.590.3723) and tell them what happened. They will offer to send you a new switch or have you send the drill in for replacement of the switch--although the person I talked with said they would probably just replace the whole drill.
Posted on Apr 24, 2009
  • 3 Answers
SOURCE: fixing a cordless drill battery charger
usually transistors have three legs, diodes have two arms all very confusing isn't it? resistors have two arms as well but not three legs or only two legs and no arms its all about arms and legs isn't it do not attempt this repair if you live at home
Posted on Aug 27, 2009
  • 11 Answers
SOURCE: I have a JobMate cordless drill and 2 batteries.
I found the Ryobi charger fits the jobmate as well.
Posted on Apr 17, 2010
I have a Black & Decker 12 volt cordless power/hammer drill. I think it needs a new battery & possibly changer. Can I purchase a new battery & charger or is the drill too old?
try this parts supplier
Black and Decker Cordless Drill Parts
see if your model has a parts list for battery and charger
if discontinued
look for tha same used drill in better condition
or toss in the bin
Oct 20, 2016 | Drills
Brand new hitachi 18v, one battery charged fine the second is completely dead it was in the drill from the factory and the charger won't recognize it when attached.
I have just had a similar issue I left the drill unused for a period and when i placed it in the charger the charger showed the battery as charged after about 15 secondseconds.
Following a internet search i found a site that suggested for a imlar problem with a camera jump starting the low battery with a 9 v battery. I had a spare from the drill which was fully charged so placed a contact from + to + and - to - and held for about 2 mins. I then placed the battery back in the charger and it started charging. Running the battery down as we speak to recharge again well worth a try. If you dont have a spare maybe the 9 v would work
Sep 03, 2011 | Hitachi DV18DL 18V Liion Cordless Combi...
I have a hitachi cordless 18v hammer drill, the high gear went out first after an inexperienced person with power tools was using it. Then after that first gear started and the drill started going out....
YOU BET, ITS POSSIBLE THAT ITS EVEN COVERED UNDER WARRANTY, THE TOOL HAS A FIVE YEAR WARRANTY ON IT, SEND IT TO A HITACHI SERVICE CENTER, LOOK ONLINE FOR ONE CLOSE TO YOU, ITS A COMPLETE ASSY, YOU CAN ORDER THE PARTS AND INSTALL IT YOUSELF IN ABOUT 10 MINUTES, PARTS SHOULD RUN LESS THAN $50
JIMS TOOL SERVICE
Jan 09, 2011 | Hitachi 18V Lithium Ion Cordless Hammer...
Have a workforce brandname drill/hammer cordless that the charger no longer works is there any place that still sells or repairs these in nova scotia canada
Replacement batteries for the Workforce 18V cordless drill are available @ 888-315-3080 for $15.00+
I currently have 2 on the way via UPS
Note: This drill is no longer marketed under the WorkForce name (and Home Depot won't help you) but is marketed under several other names including Hillman.
Jan 24, 2010 | Hitachi 12v 3/8" Driver Drill Kit with...
I have a NiMH rechargeable battery for my Makita drill. It is a 9.6V 2.2Ah battery - they don't charge anymore. I don't know if it's the battery or the charger - how do I find out.
This happens regular with Makita battery powered tools Try putting the battery in the frezer overnight this remedy worked for me once with a Hitachi battery if not you would be cheeper buying a new drill rather than a new battery.
Dec 17, 2009 | Makita 12 Volt Cordless Drill/Driver Kit
Charger is not working please give the service center adress in chennai
Here is the link for Hitachi's power tool site which has a locator function to find a service center.
http://www.hitachipowertools.com/
Mar 28, 2009 | Hitachi DS12DVF3 Cordless Drill
Chargers
went to blackanddecker on google and found everything I needed. Thank you
May 26, 2008 | Hitachi 12v 3/8" Driver Drill Kit with...
Jul 03, 2007 | Hitachi 12v 3/8" Driver Drill Kit with...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
