Question about JVC KW-AV50
I somehow tried to move from NTSC to PAL, detached the screen and then after turning on, no signal all the time, I can not even listen to radio now. What have I done wrong ?
    Problem Solver:
  • 8 Answers
The good news is that you did not do anything wrong.
The bad news is that this is a common fault with this model and will need to be sent back to the supplier for a firmware upgrade.
Disconnect the unit from the power source for 15 minutes then reconnect and it will come back on, however the problem will come back again as it is a firmware fault.
Posted on Jul 23, 2013
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
Please advise me what to do: recently I moved to Hungary with Sony TV Bravia KDL-40VL130 bought in the USA. I thought that this advanced TV would work anywhere in the world. However, it turned out it is...
Sorry u can't use this tv,because the US,Mexico and Canada tvs use a signal which run in call the NTSC signal frequencies.The European Union,Asia and the Middle East tvs use a signal which run in call the PAL signal frequencies.So,Pal or NTSC tvs signal frequencies can't not be mix.Can't modtifies these tvs it a PAL or a NTSC tvs and all it eclectronics circuitries run on that signal design frequencies.Those tvs,that call regions free tvs,Those tvs are design to run all over the world.Run on NTSC or PAL signals frequencies.
Oct 24, 2010 | Sony KDL32L4000 32 in. LCD HDTV
NTSC TO PAL
Sorry, so far as I know this cannot be done. They are two completely different formats. They dont even have the same timing scemes.
Apr 15, 2009 | Philips 42PF9431D/37 TV
The display screen is rolling and is in black and white.
Hi
You switched to PAL mode from NTSC or vice versa. Most DVDs will only output PAL or NTSC, not both. So even if the disc is region ffree, the fact that it's encoded in PAL (50hz) makes it appear like you describe - no vertical hold / black and white.
Some set top players [Apex, Phillips] will convert PAL to NTSC on the fly or vice versa.
Remember, PAL/NTSC is not the same as Region.
Here's some detailed info:
http://www.michaeldvd.com.au/Articles/PALvsNTSC/PALvsNTSC.asp
http://www.sjbproductions.com/web_pages/tip_video/ntsc_pal.htm
http://www.dvdcity.com/codefree/codefree-ntsc-info.html
You can convert the DVD to NTSC, and strip the region code by following http://www.videohelp.com/guides/how-to-convert-interlaced-pal-dvd-to-ntsc-dvd-id1107#1107
-or-
http://forum.videohelp.com/topic221928.html
[This is very time consuming.]
You
What DVD
Most players are either NTSC or PAL, however increasingly DVD players from the Far East (Apex, Phillips etc)
, which is 50hz instead of 60hz, hence the lack of vertical hold
Mar 23, 2009 | Televison & Video
How do you change the DVD player mode from PAL to NTSC ?
I just found the way to change the setting from PAL to NTSC.
While the unit is turned off , press the EZ View button on the remote control. Press alternatively the select between the PAL or NTSC setting on the unit display. That's it.
Mar 17, 2009 | Audio Players & Recorders
Picture Rolls
anteetina,
most probably your problem is within color system settings. It's either PAL/NTSC or PAL SECAM signals being produced by your player.
1) try to check your TV screen with regards to color system it use, check the color setting if it does indicate "Auto" "PAL" or "NTSC" try to choose "auto" and see if any changes will occur.
note: you can also check the service manual of your DVD player of what color system it produce and if it's match with your TV screen
cheers.
mark
Jan 15, 2009 | Digix HT1056A DVD
Can't display Pal on My Sony 57" KP-57WS520
There are probably a few problems here. What are you using to play the disc? Some NTSC players will "play" a PAL disc but interpret it as NTSC with the symptom you are describing. You need a DVD player that will play PAL. Many of those will output NTSC directly when set up to do so. The other alternative is to have a PAL compatible player that will output PAL into the converter. To narrow this down specifically, please post the model numbers and the connection scheme for your equipment. Once I understand your current setup, I should be able to describe a method to get this to work for you.
Dan
Dec 16, 2008 | Sony KP-57WS520 57" Rear Projection...
Cant see Picture
Nope. The AV inputs except a composite video signal that is either NTSC or PAL. You will need to convert the PAL signal to NTSC.
Dan
May 09, 2008 | Philips 50PF7220A Television
JVC DR-MX1S
It's likely to be an incompatible signal. You have PAL (UK) and NTSC (Belgium), the DVDR/VCR combo may not be compatible with PAL causing it to seem like it's not receiving any signal, when in fact it is - but not in a recognisable format. You may try and get an NTSC to PAL signal converter like this: http://cgi.ebay.co.uk/NEW-TV-AV-Video-System-NTSC-To-PAL-Converter-Converor_W0QQitemZ270163920912QQihZ017QQcategoryZ32837QQtcZphotoQQssPageNameZWDVWQQrdZ1QQcmdZViewItem That'll solve your problem.
Sep 09, 2007 | JVC DR-MX1S DVD Recorder/VCR
Pal/Ntsc playing problem
is your tv is the same tv that u playing before? coz according to you if u play ntsc there is no problem. if ur tv is multisystem, u can change the tv system menu to auto, but if not u cannot watch coz ntsc tv only accepts ntsc signal.
Jan 08, 2007 | Pioneer DV-373 DVD Player
JVC KW-AV50 Logo
109 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
