Question about Pool & Spa
Model f700c swimming pool pump
Came home plug was disconnected from wall plugged back in and pump isnt working
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
SOURCE: Need help installing filter pump model 635 for my swimming pool
Just go to the Intex Corp link below. Choose the appropriate pool and/or pump. At the bottom of the page you will see a link for instructional manuals and videos. Hope that helps.
http://www.intexstore.com/ProductList.aspx?categoryID=30
Oh yeah, by the way...you may want to start looking around for another pump for that pool if you plan on using it more than a year. I have had mine for 3 years and I spend more time in the pool vacumming than I do in the house!! The 635 pump is not strong enough for the 18x52 pool nor does it filter out fine silt and sand...it sucks it up and spits it right back into the pool thru the return. Good luck to you
Posted on May 22, 2009
drifter2600
  • 3 Answers
SOURCE: Pool pump starts then stops working
Your internal circuit breaker is shutting the motor down. When it overheats it breaks the flow of electricity to the motor. You need to replace your motor.
Posted on Jun 18, 2009
lonewolf1996
  • 142 Answers
SOURCE: Intex Easy Set 530 Gallon swimming pool filter
You will need to go to the manufacturing web site and get a new seal for the pump.They cost some where around $1.00 to $2.00.
Posted on Jul 03, 2009
protek480
  • 1714 Answers
SOURCE: My pool pump is 2 months old. It is a Hayward 1hp
The capacitor is probably bad. It's under the cover on the side of the motor, Take a look and smell it. A motor shop has them, or Grainger
I need to find a drain plug for my old blue little tikes swimming pool.
Here's a site I found about how they made a drain plug,I looked all over and couldn't find one,home depot or lowe's has plumbing fittings that will work. Converting Little Tikes pool into duck pond
Jul 16, 2017 | Pool & Spa
Water out let plug
You should be able to locate the drain plug somewhere near the bottom, where the wall meets the floor. Normally it is located on the same proximity of where the two holes are for inlet and outlet hoses.
Mar 02, 2014 | Intex Easy Set Deluxe Above Ground...
I have a A.O. Smith pool pump (Model #C48L2PA105C5 & Serial #04609FM) and there is no suction at all
hayward ?? good chance the impeller is broke or it could be plugged with trash make sure you pump basket has no cracks , see picture on how 2 remove your pump .find your local pool pump motor repair guy and ask him how 2 take better care of your pump.. he can save you thousands of dollhair$ over the years .. jay pump guy longwood Florida9_30_2011_7_43_54_pm.gif
Sep 23, 2011 | AO Smith Pool Pump Motor Hayward Swimming...
HOW TO WINTERIZE AQUAMATE ABOVE GROUND SWIMMING POOL PUMP
Open the plugs on the bottom front of the pump pot and on the pump housing itself. These two plugs will do the pump and just the pump. You should have simmilar plugs on the filter, heater, chlorinator and any other equiptment on the system.
Oct 13, 2010 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Have lost charger or the 2 prong adapter. Not sure as we have a 16 volt charger with single prong that may be for our light. Need to know what voltage required for the light to be sure.
According to the instruction manual for these swimming pool lights, the charger specifications are the following:
USA and CANADA: 14 VAC,1.5A UL/CSA-approved wall plug
adapter and charger
AUSTRALIA and NEW ZEALAND: 240VAC 50Hz/14VAC 1.5A wall
plug adapter and charger
EU: 220-240VAC 50Hz/14VAC 1.5A CE-approved wall plug
adapter and charger
SOUTH AFRICA: 220-240VAC 50Hz/14VAC 1.5A wall plug
adapter and charger
UK: 240VAC 50Hz/14VAC 1.5A CE-approved wall plug adapter
and charger
Aug 13, 2009 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
My pump stopped working after 1 month. It was running loudly then kicked the GFI in the plug and wont reset now.
unplug from gfi reset and plug something else in and see if it works, no then bag GFI, yes then sounds like pump is faulty return to place of purchase i would not recommend trying to fix yourself as some one could get electrocuted in pool if theres any mistake
Jul 07, 2009 | Intex Easy Set 530 Gallon Swimming Pool...
Jun 13, 2009 | Intex Wet Set Water Filtration Filter Pump...
Pool & Spa Logo
22 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
